Blue Ribbon 4x4 Build Thread
Discussion in '2.5 Gen Builds (2014-2021)' started by BlueRibbon4x4, Jul 25, 2020.
  1. Aug 26, 2021 at 6:44 PM
    #361
    BlueRibbon4x4
    BlueRibbon4x4 [OP] Let’s color match it
    Geno
    2015 Blue Ribbon 4x4
  2. Aug 26, 2021 at 6:49 PM
    #362
    RobertD
    Robert
    DFW, Texas
    Does it still record when vehicle is parked?
    Rica25 likes this.
  3. Aug 26, 2021 at 6:55 PM
    #363
    BlueRibbon4x4
    Geno
    It has a battery, and clicks on when the truck gets tapped.
    Rica25 and RobertD[QUOTED] like this.
  4. Aug 27, 2021 at 3:28 PM
    #364
    BlueRibbon4x4
    Geno
    I had to replace the amp volume knob that originally came with my amp. I think the epoxy ruined one of the terminals or something, making it scratchy sound while adjusting the volume or if I left the knob in a certain spot. This knob actually has a nut to hold it in place, the old one, I had to glue. The last pic is the old knob. 6D4405D2-385A-43E8-B14F-99C34A8CA8DD.jpg5B86F7FE-673A-4626-9473-0551088D40A2.jpg17CF1900-8993-4A81-AC0C-40A9F88C434D.jpgD2782249-5626-42A8-9D66-D298FFA671E7.jpg
    GAknight, Fotnot, Rica25 and 2 others like this.
  5. Aug 28, 2021 at 5:23 AM
    #365
    Convertedman
    Convertedman New Member
    Scotty
    Cumming, Ga
    2021 CM 4 wheeler Limited Cavalry Blue
    6in Ready lift, Toyo 35/12.50/20
    I have seen several of the guys on here installing these cameras. I've been looking at the rexing dual camera setup. not sure as to how to mount the rear camera with the roll down window. Any thoughts on that?
    https://www.amazon.com/gp/product/B07FCSMJZB?smid=A6UEJTLUY290N
  6. Aug 28, 2021 at 5:47 AM
    #366
    BlueRibbon4x4
    Geno
    I saw someone make a bracket that sat behind the rear seat. The camera came up to the side of the headrest.
    Rica25 and Hightide like this.
  7. Aug 28, 2021 at 6:02 AM
    #367
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    This one works to mount the camera at the top of the rear window: https://www.thedashcamstore.com/custom-folded-bracket-for-secondary-dashcam-lenses/
    I think mounting next to or behind the headrest would look better aesthetically, but up high probably gives the best field of view.
  8. Aug 28, 2021 at 10:11 AM
    #368
    Convertedman
    Scotty
    Cumming, Ga
    a lot of times I think, there has to be something someone has made for…
    And this is one of those things. Should be fairly easy to fab something like that mount up. Was totally having a brain fart with it.
    Thanks
  9. Aug 28, 2021 at 2:31 PM
    #369
    BlueRibbon4x4
    Geno
    Many times I have thought the small subwoofer box that came with the sub I purchased was hindering it’s performance. After looking at countless pics of subwoofer boxes, finding vague dimensions, I decided to go for it and build a new box.
    I started by removing the rear insulation pad and installing sound dampening material. I put the pad back on because I didn’t want rhe box to bounce against the rear panel.
    I mostly looked at installed subwoofer box pics and measured the areas in my truck where the other boxes landed. I could see the recess landed directly behind the seat mount, and the port went about two third down the height of the box. I grabbed a sheet of 3/4 mdf (price is going down!!), and chopped her up, placing the subwoofer centered in the passenger seat, pushed to the bottom of the box. I installed the port divider, and installed the old speaker terminal cup. The top depth is 2”, bottom depth 6. All other dimensions are written inside the box in the pics, and are inside dimensions. I used an online subwoofer calculator to figure out the length of the port - 16”. I rounded over the port exit 1/2” to keep port noise to a minimum. I don’t have any subwoofer carpet, so I just gave her a quick spray with black spray paint for camouflage, and I’ll just cover it later.
    After removing the woofer, I realized the old box is made of only 1/2” mdf, and the back panel had an area that is 1/4” to fit the damn woofer. The output honestly was ok, I was happy with it when I first installed it, and for the price I paid, it still was a pretty good box.
    Tested, and the damn thing rocks!!! So much more output than the other box, I’ll need to make some adjustments on the amp and LC2i, but right away it’s amazing. Super happy I rebuilt the box, it was worth the effort!!E98F6811-3A07-49BC-A727-77DFC5F285F8.jpg 8E97A3B7-ACC5-467F-84F3-D9DD01102277.jpg 368D3327-59CB-4DCC-B957-D1A6F0F6FF13.jpg 2C53DA3D-AB72-4970-A03E-791551FF6A01.jpg 6D451A30-7277-45FC-9879-08950EE60912.jpg D7C15896-A014-4F4D-8F6D-5B040B40652B.jpg 5021383B-42B4-4FA3-B0E6-1E3F510E86E2.jpg
  10. Sep 18, 2021 at 1:28 PM
    #370
    BlueRibbon4x4
    Geno
    Grabbed some used swing cases for a killer deal!! Got plans for these guys. E34C3D3C-AFC3-48D5-87AA-FB508D3A88AB.jpg
    GAknight, TRDFerguson, Fotnot and 2 others like this.
  11. Sep 19, 2021 at 1:19 PM
    #371
    BlueRibbon4x4
    Geno
    Well, my wife gave me our anniversary gift early. She said Halloween is too late in the year for this type of gift, so here ya go.
    She got a Karcher pressure washer, Chemical Guys Watermelon Snow Soap, 50ft pressure washer hose, and a Trinova foam cannon. I had done a bunch of research from detailers on choosing a pressure washer and foam cannon and had them in my Amazon wishlist.
    The pressure washer is super easy to setup and use, and the foam cannon works great. I’m undecided on the soap, as I think it stripped some of the wax finish off my truck. I usually use Meguiars ultimate wash and wax, and it leaves the truck beautiful. There’s definitely a difference in this finish. I will try the Meguiars in the cannon next time.
    Ultimately I love the setup, and will have to make a permanent setup inside the shed behind the truck, to isolate the pressure washer sound and so I don’t have to truck this setup around. The pressure washer isn’t loud, but I like to wash the truck at around 6am, so I’d like it to be as quiet as possible.
    7D163C07-EC5F-40B4-B2AA-5C7ABF04E541.jpg F4406B44-0F68-49E8-8C87-70CEB7B79C9B.jpg E63DCD98-CD8B-4ADA-BA67-70264679DF18.jpg 87AEB389-64CD-4610-BE90-637D79D207B9.jpg
    GWill, GAknight, HulkSmurf14 and 4 others like this.
  12. Sep 19, 2021 at 1:30 PM
    #372
    RobertD
    Robert
    DFW, Texas
    :101010:
    Keep that woman! She has been good to you
    BlueRibbon4x4[OP] and Rica25 like this.
  13. Sep 19, 2021 at 2:03 PM
    #373
    BlueRibbon4x4
    Geno
    Rica25 and RobertD like this.
  14. Sep 19, 2021 at 2:08 PM
    #374
    alwzdfiant
    alwzdfiant New Member
    2013 Tundra Crew Max
    Mine is next! :rofl:
  15. Sep 19, 2021 at 2:21 PM
    #375
    BlueRibbon4x4
    Geno
  16. Sep 19, 2021 at 3:54 PM
    #376
    alwzdfiant
    You have some smart neighbors :rofl:
  17. Sep 26, 2021 at 5:17 AM
    #377
    BlueRibbon4x4
    Geno
    A badly needed dirt escape yesterday. Up in Lake Elizabeth was beautiful.
    946B3FDC-AEC2-4005-B446-0670B57C7CCE.jpg D13CB370-3FE9-4A4B-A26F-FD0F75ADC849.jpg E2B29401-081D-41B9-966C-8873CCE21F28.jpg 5950A24E-6460-486C-8224-9E385E9AA801.jpg D4C5A8AC-2081-4E90-ADC0-36D76C2C659C.jpg 536B18C8-0B19-4A23-BF05-5789B66791CA.jpg 69EE32AC-3C79-4271-9B9C-28C95E6831DC.jpg
    GAknight, Cfincke, camron1039 and 5 others like this.
  18. Sep 26, 2021 at 5:34 AM
    RobertD
    Robert
    DFW, Texas
    Happy pup!
    Rica25 and BlueRibbon4x4[OP] like this.
  19. Sep 26, 2021 at 12:57 PM
    #379
    BlueRibbon4x4
    Geno
    Decided to wrap the subwoofer box. Did I do a great job? Nah. But it’s behind the seat, shut up. EEAB6EE3-C042-4220-8FB6-8A26170202EF.jpg3CE95E0F-761E-487A-A12D-C643EDD41DF0.jpg
    GAknight, Fotnot, Rica25 and 4 others like this.
  20. Sep 26, 2021 at 2:50 PM
    #380
    Rica25
    Ricardo
    Tulare
    I closed my eyes
  21. Sep 26, 2021 at 3:17 PM
    #381
    BlueRibbon4x4
    Geno
    Rica25[QUOTED] likes this.
  22. Sep 26, 2021 at 3:22 PM
    #382
    Rica25
    Ricardo
    Tulare
    Carpet on the boxes is not easy. I've done 3 boxes none ever came out perfect but most of my creases were on the rear where it could not be seen.
  23. Sep 26, 2021 at 3:23 PM
    #383
    Rica25
    Ricardo
    Tulare
    Is that port right up giant the side panel or is there some room?
  24. Sep 26, 2021 at 3:49 PM
    #384
    BlueRibbon4x4
    Geno
    Yeah, my seams are on the edges, the line across the upper front is where it came folded from shipping. I tried to even it out as much as I could.
    The port is about 10 inches from the side panel. Plenty of space to avoid port noise. It sounds even better now, I put some poly stuffing to even out the sound waves. Sounds a little tighter.
  25. Sep 26, 2021 at 3:52 PM
    #385
    Rica25
    Ricardo
    Tulare
    Nice. Yeah poly fill makes a difference.
  26. Oct 19, 2021 at 6:57 PM
    #386
    BlueRibbon4x4
    Geno
    Fartin around, getting ready for Sedona.
    B73D2945-DF2E-48B3-BF0D-A947F126E04C.jpg 9ABB45A9-FFB1-4165-BBB2-11AA39DAEB6C.jpg 837C6EA7-0DC6-4FF9-BC7C-CFD6C68B90A7.jpg
    mav7021234, GAknight, Rica25 and 4 others like this.
  27. Oct 19, 2021 at 6:59 PM
    #387
    alwzdfiant
    Sedona is fun! Just stay away from all the tourists. Drive safe bro
  28. Oct 19, 2021 at 7:03 PM
    #388
    BlueRibbon4x4
    Geno
    Thanks! I can’t wait, bro! Going Thursday.
    Rica25 likes this.
  29. Oct 19, 2021 at 7:31 PM
    #389
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’ll definitely know your rig when I see it up there! Safe travels.
  30. Oct 19, 2021 at 7:35 PM
    #390
    BlueRibbon4x4
    Geno
    Yessir! Hopefully we’ll run into each other. :thumbsup:
    Rica25 and TRDFerguson[QUOTED] like this.
