  1. Aug 25, 2021 at 12:43 PM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    t4r2tundra likes this.
  2. Aug 25, 2021 at 12:44 PM
    1794TX
    Steven
    N.TX
    '20 1794
    3xYOTA, Hightide and Fotnot[QUOTED] like this.
  3. Aug 25, 2021 at 2:05 PM
    Legbuh
    Legbuh New Member
    2019 Crewmax Limited
    Fuel pump recall and alignment. PO had put TRD Pro suspension on and not done an alignment. Should be good for 300k now with regular maintenance. :)
  4. Aug 25, 2021 at 2:27 PM
    Do58
    Do58 New Member
    I don’t even run a front plate haha
    coldcanuk and mgm16trdpro like this.
  5. Aug 25, 2021 at 2:28 PM
    AZBoatHauler
    So.Arizona
    Drove it out of warranty. Only used it once for a parking brake adjustment. Solid build.
  6. Aug 25, 2021 at 2:30 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    You should start receiving those phone calls directly.
  7. Aug 25, 2021 at 2:35 PM
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    Installed and setup the Ultragauge mx1.4. The 2016+ codes didn’t work but used the 2012-15 codes and can see the trans pan and post torque converter temps.
    coldcanuk and Fotnot like this.
  8. Aug 25, 2021 at 2:54 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Apparently you can wire it to the cargo light but I just used the regular switch connected directly to the battery.
  9. Aug 25, 2021 at 3:12 PM
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    Ditto for me on getting trans temps on my 2019 using the ultragauge.
  10. Aug 25, 2021 at 4:07 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    drove it a few miles to continue the break in of my 5.29 gears that I recently got installed, got them from the privateer group buy awhile back, supposedly they were were REM'd but after the whole issue with them I didn't trust if they really did, shop didnt say anything when they looked at them so just going through the regular break in process, better safe than sorry.
    also messed with my hypertech spedometer calibrator since I thought I had to input the gear change on it too on top of my 35s. Turns out there's no need to input a gear change since there's nothing to really tell the truck it got bigger gears?? dunno how true that is but works for me. was having an odd time trying to figure out why the speedometer was so way off since the calibrator had both the bigger tire size and the gear change input, did some research that's the answer I found/received. went back in, cleared out the gear change setting on the calibrator and just left the tire size change and speedometer is back to being accurate..
    BlueRibbon4x4, woods and Fotnot like this.
  11. Aug 25, 2021 at 4:13 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I had the instructions saved for the Matt Gecko ones at one point, but don't any more. AFAIK, you run power up to the engine bay and hit the battery directly.
    HulkSmurf14 likes this.
  12. Aug 25, 2021 at 5:34 PM
    What Toytec setup do you have and why are you removing it?
  13. Aug 25, 2021 at 5:36 PM
    You need the trans and torque codes for the 2020?
  14. Aug 25, 2021 at 5:38 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I had driven mine to the extended warranty of 75k, traded it in the following day. It was perfect timing actually, but I thought it was funny. The new Sequoia got a 125k warranty....so I guess I'll trade it in 150 miles after that one ends too lol
    AZBoatHauler[QUOTED] likes this.
  15. Aug 25, 2021 at 5:47 PM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    I have the complete Aluma series with the rear shackles. Getting the truck back to stock to trade in for a black 2022 Pro Tacoma. The Tundra's just too big for what my future plans are.
  16. Aug 25, 2021 at 5:50 PM
    Beer Man
    Beer Man @cement.tundra
    2021 SR5 XP CrewMax Cement
    I believe I bought my wireless charging tray from you. I’ll be lurking for your other items listed in the future. Got any 18” tires :boink:. Granted it wouldn’t be worth the shipping from GA to FL anyways ha
    CorsoTundra[QUOTED] likes this.
  17. Aug 25, 2021 at 5:54 PM
    CorsoTundra
    North GA
    Give me some credit, I've had 3 Tundras. I've also had 6 Tacomas and 4 4runners and 1 FJ.
    co2owen, Jpd0144, mgm16trdpro and 6 others like this.
  18. Aug 25, 2021 at 5:56 PM
    Degausser
    Degausser New Member
    Kevin
    GA
    2024 LR SR5
    Didn't you have Toyo ATs on? If so, what are you doing with them?
  19. Aug 25, 2021 at 6:00 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Well…you must really like them Toyota trucks then. It’s all good, I love them too. 1 Tundra, 3 Tacoma’s, and 3 4Runner’s. My 1st gen Tacoma’s and my current Tundra are by far my favorites.
  20. Aug 25, 2021 at 6:04 PM
    CorsoTundra
    North GA
    First truck when I turned 16 was an 82 toyota 4x4 with the 22re engine and I was hooked. It was white with a small lift and a black roll bar in the bed.
    Aught16TSS, Bprose and Oey12[QUOTED] like this.
  21. Aug 25, 2021 at 6:05 PM
    CorsoTundra
    North GA
    I did, but Discount took them back and swapped them for the ATP2.
    Degausser[QUOTED] likes this.
  22. Aug 25, 2021 at 6:13 PM
    RainMan_PNW
    Casey
    Clark County, WA
    So…you’re gonna change your name to CorsoTaco and stick string, right? ;)
  23. Aug 25, 2021 at 6:14 PM
    CorsoTundra
    North GA
    I'll have to change it on the Taco forum somehow. Maybe RoccoTaco to name it after my male Corso...lol
    Hightide and RainMan_PNW[QUOTED] like this.
  24. Aug 25, 2021 at 6:25 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Beautiful brakes!!!
    Speedkills119[QUOTED] likes this.
  25. Aug 25, 2021 at 6:30 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    7A81A3DE-0421-4325-BE51-8DF772E733FC.jpg Added an OEM bed mat, I just don’t fully trust the Line-X from chipping
    Jpd0144, Branden, TunBrun and 3 others like this.
  26. Aug 25, 2021 at 6:37 PM
    JmikeLKA
    JmikeLKA Loving the truck
    2021 Limited
    Undercover Ultra Flex Cover, Rear Sway Bar, LED interior lights, Cargo Bars attachments, Console Safe, Husky Floor Mats,
    What light did you install, looks great!
  27. Aug 25, 2021 at 6:52 PM
    Ó Brádaigh
    Ó Brádaigh New Member
    S. Polychronopolous
    21MGT
    Patiently waiting...
    Saves from denting
    Cl8NL[QUOTED] likes this.
  28. Aug 25, 2021 at 7:30 PM
    GreatBasinTundra
    Reno, NV
    2020 Tundra SR5 DC
    I used the codes from Ultra Gauge for the 2016+ but just kept getting error messages. If you have different info/codes it would be much appreciated.
  29. Aug 25, 2021 at 7:37 PM
    Gotcha. I have a friend of mine here in Fl looking into Toytecs for his but the rear shocks have been on backorder for a while now.
  30. Aug 25, 2021 at 8:30 PM
    King R 808
    King R 808 New Member
    2020 White Tundra TRD Pro
    Yea. They are about a year old run about an HR a day and paid $78. Sell them to u for $35 plus shipping.
