Home electrical question
Discussion in 'General Tundra Discussion' started by jeremyd, Aug 25, 2021.
  1. Aug 25, 2021 at 11:42 AM
    jeremyd
    jeremyd [OP] 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    What is this switch called? It has 5 wires and is a single toggle, I’m converting it to a wall rocker switch. C45AAD02-A42A-4C82-A631-5AEA4D026715.jpg
  2. Aug 25, 2021 at 11:48 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Looks like a GFCI from here. But if its a switch, then that's what it's called. appears to switch 2 circuits / outlets
  3. Aug 25, 2021 at 11:50 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    4 way switch it looks like
    Does it control a light along with other switches at different locations?
    jeremyd[OP] and NWPirate like this.
  4. Aug 25, 2021 at 11:51 AM
    Shanet421
    San Diego,CA
  5. Aug 25, 2021 at 11:51 AM
    NWPirate
    Zach
    WA
    Yep, 4 way. 2 other 3 way switches should control the same set of lights.
    Shanet421[QUOTED] likes this.
  6. Aug 25, 2021 at 11:58 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Yes
  7. Aug 25, 2021 at 11:59 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Ok, so it’s called a 4 way wall rocker when ordering right?
  8. Aug 25, 2021 at 12:00 PM
    Shanet421
    San Diego,CA
    Just swap like for like and you should be fine
  9. Aug 25, 2021 at 12:02 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I still have to order it
  10. Aug 25, 2021 at 12:04 PM
    NWPirate
    Zach
    WA
    4 way Decora is what you would ask for. Google that and see if it's what you're after.
  11. Aug 25, 2021 at 12:05 PM
    Shanet421
    San Diego,CA
