  1. Aug 24, 2021 at 7:47 PM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    Thanks for the pics guys. Definitely going with 0 Offset to get the look I want. I’m looking at getting the Pro Comp Bandidos 18x9 0mm Offset. I want to stay away from the crazy expensive brands.
  2. Aug 24, 2021 at 8:03 PM
    outlaw.taco
    outlaw.taco New Member
    Houston
    35% front and I’m happy so far
    a_double[QUOTED] likes this.
  3. Aug 24, 2021 at 8:03 PM
    SAGE63
    San Diego County
    Count me in as the prototype
    sbxx312[QUOTED] likes this.
  4. Aug 24, 2021 at 8:17 PM
    King R 808
    King R 808 New Member
    2020 White Tundra TRD Pro
    Can't decide what lights. Decided to do a little mod once the vleds came in. What y'all think?
    White or Amber?
    45AC7F64-1805-473C-903B-172DB91FDE1F.jpg AFA82918-AC84-4B11-9DB3-B8C1CD66F583.jpg
    Bob_Wiley, YotaBro, Cosmoblu and 7 others like this.
  5. Aug 24, 2021 at 8:39 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Not yet ... I did cut the rear shock mounts back a bit as that seems to be the issue. I'll keep an eye on it though!
    HulkSmurf14 likes this.
  6. Aug 24, 2021 at 8:46 PM
    AZTundra
    Paul
    Phoenix, AZ
    White.
    a522467 likes this.
  7. Aug 24, 2021 at 10:50 PM
    swallace
    swallace Insert profound statement —> here <—
    Steven
    Tri-Cities, WA
    2014 Silver Sky Metallic CM 4.6L 4x4
    6112/5160, DD 10”, Amp steps, Alea leather, more…
    I like the amber.
    What product is this? Link?
  8. Aug 25, 2021 at 5:27 AM
    Amber
  9. Aug 25, 2021 at 5:30 AM
    Hamster14
    Hamster14 New Member
    Utah
    2014 Tundra Limited
    -46 gallon tank - shell
    amber
  10. Aug 25, 2021 at 5:31 AM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Amber
  11. Aug 25, 2021 at 5:32 AM
    King R 808 likes this.
  12. Aug 25, 2021 at 5:43 AM
    Eborseti22
    Eborseti22 New Member
    Evan
    2020 Toyota Tundra TRD Offroad
    See I had the same thought - All black truck, with red tow hooks out front. Eventually will have the red TRD sway bar too. My thought was if I don't like the red, I'll just platidip it. Would love to eventually have black tails and no Chrome up front too, but with a newborn, highly unlikely now haha.
  13. Aug 25, 2021 at 6:54 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    My son was in town this weekend and he drives my older 4Runner, so took the opportunity to clean it up a bit as well as my Tundra and the wife's SUV. Glad I got it all done in the morning, we have been having some serious HEAT in Richmond VA which will continue the next week or so.
  14. Aug 25, 2021 at 7:15 AM
    JmikeLKA
    JmikeLKA Loving the truck
    2021 Limited
    Undercover Ultra Flex Cover, Rear Sway Bar, LED interior lights, Cargo Bars attachments, Console Safe, Husky Floor Mats,
  15. Aug 25, 2021 at 7:16 AM
    JmikeLKA
    2021 Limited
    I would choose White.
  16. Aug 25, 2021 at 8:10 AM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Put stock size Cooper ATP2 tires on. Toytec kit comes off next Friday.
  17. Aug 25, 2021 at 8:49 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    Same question. Since my TRD won't have the optional cargo lights this would be a great mod. Even better if it work's like the cargo light.
    JmikeLKA likes this.
  18. Aug 25, 2021 at 8:56 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    https://mattgeckoleds.com/
    By default, the kit is wired to a switch in the bed. But it would be easy enough to wire them to the cargo light switch instead - you would just need to splice and extend the wires and run them up into the cab. You can download the instructions for the SET "factory" cargo lights from Sparks' website and sort of follow that routing, or make up your own.
    I used the "factory" lights for my truck, but also added a switch in the bed. That way the primary power is coming from the cargo light (per the factory setup), but they don't come on unless I also have the switch in the bed turned on.
    https://www.tundras.com/threads/caseys-2021-lunar-rock-trd-pro-build.77317/page-6#post-2038862
    Hightide, NWPirate and JmikeLKA like this.
  19. Aug 25, 2021 at 9:22 AM
    JmikeLKA
    2021 Limited
    Like the Red Tundra lettering!
    NumberOfTheDay likes this.
  20. Aug 25, 2021 at 9:27 AM
    DrZoidberg
    Dave
    Tesla MYP
    On that first one, do you know where the power draws from? I see it says bedside switch but I don't see where it says it powers from.
  21. Aug 25, 2021 at 9:31 AM
    AZBoatHauler
    So.Arizona
    The battery. That allows you to turn the lights on (via the switch) with the truck completely off.
  22. Aug 25, 2021 at 9:35 AM
    Eborseti22
    Evan
    Thanks Mike!
  23. Aug 25, 2021 at 11:01 AM
    BlancaLaGordita
    BlancaLaGordita New Member
    Blanca
    2021 Tundra TRD Sport
    Amber... will you sell me the white ones?
    King R 808[QUOTED] likes this.
  24. Aug 25, 2021 at 11:50 AM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Go to “Jomax custom” they are at least 4x stronger than OEM. If your gonna upgrade your suspension might as well do it right
  25. Aug 25, 2021 at 12:35 PM
    JmikeLKA
    2021 Limited
    Help!!!
    What are you all using for a front license plate holder?
  26. Aug 25, 2021 at 12:39 PM
    TWJLee
    TWJLee No Thanks
    J
    Midwest
    2020 Limited DC TRad OR 2020 F150 5.0 single cb 2001 Tacoma 4x4 2.7 5spd AC cab
    GFC Borla XS Ceramic Tint 2” lift on Fox 2.0 -aal- Methods on 33
    None for years and its ok
  27. Aug 25, 2021 at 12:40 PM
    jimbrophotodotcom
    jimbrophotodotcom New Member
    Hawaii
    2021 Lunar Rock Tundra TRD Pro
    IG: @LunaTheTundra, Coachbuilder kit and 35s soon
    slybrackets.com
  28. Aug 25, 2021 at 12:40 PM
    RobertD
    Robert
    DFW, Texas
    I had the one that came with the truck. What does your bumper look like? If it's aftermarket and has an opening for a winch, they make adapters
  29. Aug 25, 2021 at 12:41 PM
    1794TX
    Steven
    N.TX
    '20 1794
  30. Aug 25, 2021 at 12:42 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I got the holder from my 2017 in my garage if you need it. pretty much pay shipping and it is yours
    coldcanuk likes this.
