Remote oil filter relocation for ALL TUNDRAS
Discussion in 'General Tundra Discussion' started by JTP, May 4, 2017.
  1. May 4, 2017 at 8:11 AM
    JTP
    JTP [OP] The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    Searched the forums and have not found anything on remotely relocating your oil filter. I am going to do some R&D and see if I can engineer my own remotely located oil filter system.
    Found these guys and they have these adapters for 2010 - 2017 4.0 and for the 4.6 and 5.7 V8's all years. They are on the west coast and I am calling them to find where I can get the remote mount spin on oil filter plate.
    I ran something similar on my Old Taco's (before they put the filter up on top of the motor) and it was great. Carried 2 extra quarts in the system and the spin on oil filter plate was mounted up under the inside of the frame. The to and from lines acted like an extra oil cooler.
    Hime page link
    https://www.**************/home.html
    2nd Gen 5.7 link
    http://www.shop.**************/TR-301-BK-Cartridge-to-Remote-Adapter-TR-301-BK.htm
    15whtrd and NewImprovedRon like this.
  2. May 4, 2017 at 8:47 AM
    JTP
    The Big Black Moose
    Found these filter plates from Barns. They have the standard H filter size and the large 6" filter size.
    Wil do some measuring and location scouting. Closer to the stock filter location the better to not loose any oil pressure coming out of the engine through the filter housing.
    GNTundra and NewImprovedRon like this.
  3. May 4, 2017 at 8:51 AM
    JTP
    The Big Black Moose
    I can get some nice beaded stainless oil lines made to length and this should work great.
  4. May 4, 2017 at 9:18 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    2015 Platinum Super White Crewmax 4X4
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Curious to see how this turns out.
  5. May 4, 2017 at 9:21 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    Did I read it right in the other thread where you posted this that they cost about $200 and you would need another 2qts of oil? That's a lot of $$ for an alternative to dropping the skid plate a few times a year.
    Don't get me wrong...I hate having to drop the skid plate but it's much cheaper to just cut a hole in it or something.
  6. May 4, 2017 at 9:27 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    http://www.rcimetalworks.com/07-17-Tundra-Engine-Skid-Plate-Tun-07-01.htm
    Problem solved and about the same price
  7. May 4, 2017 at 9:32 AM
    SOB
    SOB Big Member
    Ohio
  8. May 4, 2017 at 9:38 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
  9. May 4, 2017 at 9:40 AM
    JTP
    The Big Black Moose
    I am to poor to go cheap. I plan on changing oil quite regularly and for a long time on this truck. Its the life blood of that engine. The time saved alone on just 10 oil changes pays for the rig, the extra oil, AND MY TIME OVER THE LIFE OF THE TRUCK. The whole mod including the oil lines will run just short of $400.00
    You can do the math and see what oil changes will cost over time going through a Dealer or through your local Quick Lube. Most auto supply will take your used oil. Over time I am saving money and time. 5 min do it myself oil changes that take 5 mins each is worth the initial $400 buck investment to me.
    My old Taco's NEVER suffered from running over recommended oil change time and they had the added protection of two additional quarts of oil and the oil was in theory cleaner longer because there was more of it. I bought filters by the case which also saved money and time.
    mattc and NewImprovedRon like this.
  10. May 4, 2017 at 9:48 AM
    JTP
    The Big Black Moose
  11. May 4, 2017 at 9:54 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    Why not just cut a hole in the skid plate for access, or fabricate an access door? :notsure:
    There is being cheap and being efficient.
    SOB likes this.
  12. May 4, 2017 at 11:15 AM
    LibertySand
    LibertySand IH Support Rig
    Montclair, CA
    07 TRD DC 5.7 Tow 4X4
    I'm liking this thread...
    Interested in doing this myself also. I like the ability to Add oil to the system, lets it run cooler to.
    NewImprovedRon likes this.
  13. May 4, 2017 at 11:53 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    So has anyone figured out a way to fabricate a filler hole on the top of the transmission with a dipstick. I saw on another tundra forum that someone fabricated a filler neck that went to the top. They then Fabricated a dipstick which could accurately measure the tranny fluid level. It only cost like 300$. I wish I could find the info again. I really want to do that mod.
    15whtrd likes this.
  14. May 4, 2017 at 11:55 AM
    SOB
    SOB Big Member
    Ohio
    Hey man...not trying to knock your idea - to each their own! I too am cheap and that's one big reason why I too change my own oil. But for 2, maybe 3, oil changes a year, $400 in initial cost and approx. $10 in extra oil each change, I will personally live with the skid plate removal or put in a hole/access hatch.
    Good luck with the mod though - I think a lot of folks (including myself) will be curious to see the outcome :thumbsup:
    JTP[QUOTED][OP] likes this.
  15. May 4, 2017 at 12:23 PM
    JTP
    The Big Black Moose
    Baxter is coming out with the entire package to re-locate the oil filter and are incorporating multi ports on this set up so that you can also add an additional oil cooler. They are already producing these for the Diesels over seas that see hot weather, slow speed, hard pulling work. The inverted spin on filter can be located right behind the grill. They are even producing the set up for as big as 8" spin on filters.
    Looks like about a $500.00 mod not including an extra oil cooler when its all said and done. Here in Texas the additional cooling will be much needed and appreciated. I am assuming that the rock drawing, snow bashing, and Baja Racing crowd might be interested as well.
    Think that I will go ahead and spring for the kit. 5 min oil changes sounds good to me vs some quick lube or a two hour wait at the local Yoda dealer each time.
  16. May 4, 2017 at 12:55 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    JTP [OP]
    Thanks for posting this Jim. I've already got access in the RCI skid but I like the idea of having more oil in the system. Not sure if I can or will do this but it's nice to know I can if I want.:thumbsup:
    Bprose, NewImprovedRon and JTP[OP] like this.
  17. May 4, 2017 at 1:00 PM
    JTP
    The Big Black Moose
    I guess I got spoiled with 10 years of quick oil change capability on my old Tacos. I got even more spoiled with the top filter placement on my 06.
    This new Tundra set up with the filter being behind the grill vs back up under the truck mounted on the frame will only require about 1/2 a quart extra oil to fill the lines.
  18. May 4, 2017 at 1:10 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    What's the website? Keep us posted
  19. May 4, 2017 at 1:21 PM
    JTP
    The Big Black Moose
    BP Adapters dot com
    Thread will not let me paste the link for some reason???
    Will be under New Products on the Home page.
    They make these for all kinds of Toyotas including the overseas stuff.
    Ive got a kit on the way.
    My lift has a custom skid plate that covers my oil pan and I will be adding the front skid plate that ICI has for their Magnum line of bumpers. I do not want to be constantly taking all that crap on and off changing oil. So very much worth the expense and time savings to me at least.
    Dustydirt19 likes this.
  20. May 4, 2017 at 5:03 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Sounds pretty cool Jim. Little extra oil never hurt any engine. Question about the remote filter location, you were saying behind the grill. I assume you mean somewhere in the engine bay and not having to remove the grill each time. Do you have a spot picked out ?
  21. May 4, 2017 at 5:22 PM
    JTP
    The Big Black Moose
    MFG said that I can mount the spin on filter plate behind my grill. I am assuming that he said that because I have a 2nd Gen and the grill goes up with the hood to provide right there access to it. I was wanting to mount the spin on filter plate back under the truck on the frame some place but will look to see where might be a good spot behind my grill.
  22. May 4, 2017 at 5:27 PM
    CM-LENNY
    San Diego, CA
    Now that makes sense. I wasn't familiar with the 2nd Gen grill. Sounds like a great location and will get good air flow too.
  23. May 4, 2017 at 9:36 PM
    Help New Member
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    Aside from convenience, what are the pros/cons to moving the oil filter? Is the added cooling from extra oil/longer cooling run noticeable? thanks!
  24. May 5, 2017 at 6:51 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
  25. May 5, 2017 at 6:53 PM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    You want to mount it under the hood so it's easy to get to. That's one reason for the name "REMOTE ACCESS."
  26. May 11, 2017 at 5:03 AM
    JTP
    The Big Black Moose
    Got a response form the manufacture of this filter re-locate kit. Over $600.00 OUCH!
    Think that I will take the skid plate on and off and get the quick drain tube OR just drink coffee and wait in the lobby for a little bit at my local Toyota Dealer while they do it.
  27. May 11, 2017 at 5:25 PM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    They have one that takes a screw on filter. Don't know if it clearn the skid plate. Might need spacers.
  28. Sep 26, 2021 at 12:42 PM
    1794TX
    Steven
    N.TX
    '20 1794
    Bumping this thread, and adding a bunch of stupid questions. Has anyone done this with a 2.5-gen (falling in line with that '2.5'... Covid shots are next)? Are there any warranty implications? Is it really saving that much trouble? Any other comments?
