Kings Coilovers
Discussion in 'Suspension' started by Eangeles90, Aug 23, 2021.
  1. Aug 23, 2021 at 6:56 PM
    Eangeles90
    Eangeles90 [OP] New Member
    Eric
    Hello fellow ppl! I need your help. I own a 2021 Tundra sr5. Just days ago I've installed a Kings suspension set up. Now my issues is that I've noticed the bottom Coilover "cup"?? Has scratches that seemed to be caused by the Sway bar end links. It could also be from installation. If this is caused by the end link as I'm driving, what is best recommended? I was thinking replacing the front sway bar?? TIA!
  2. Aug 23, 2021 at 7:55 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Welcome!
    I’d remove the sway bar entirely until you figure out next steps or just decide to leave them off permanently.
  3. Aug 24, 2021 at 7:12 AM
    Eangeles90
    Eric
    How bad is the Ride without the Sway bar?
  4. Aug 24, 2021 at 7:15 AM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    Ride will be way better without the sway bar!
    Cruzer and monaco730 like this.
  5. Aug 24, 2021 at 7:15 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    My fox's did the same and i removed the sway bar. Ride is better in my opinion with the sway bar off.
    Cruzer and TG705 like this.
  6. Aug 24, 2021 at 7:18 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome
  7. Aug 24, 2021 at 8:35 AM
    TheBeast
    TheBeast The Beach
    same here when I installed the Kings few years back. Alignment got it much better. I also rounded off the sway bar ears similar to trd sport sway bar. Now it's fine.
    Pretty common issue with aftermarket coil overs.
    Hbjeff likes this.
  8. Aug 24, 2021 at 8:37 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    It is barely touching, a grinder and some black paint will fix it quickly
    snivilous and TheBeast like this.
  9. Aug 24, 2021 at 8:39 AM
    TheBeast
    TheBeast The Beach
    could also be from installation as you mentioned if nothing is touching it.
  10. Aug 24, 2021 at 8:42 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    In your photo it looks like the lower coilover eyelet is directly against the lower arm tab. There should be a spacer on each side of the eyelet to help center the eyelet, is there one?
  11. Aug 29, 2021 at 1:31 PM
    ultra1988
    ultra1988 New Member
    2019 tundra
    My kings look exactly the same, for me it’s from installation. I tried doing it the quick way instead of the right way. Once I disconnected the sway bar from the body mount I was able to install without causing anymore scratches.
  12. Aug 29, 2021 at 4:44 PM
    Shifless Joe
    Shifless Joe New Member
    Mesa AZ
    2016 TRD Off-Road
    Relatively harmless, it should only touch at full droop, the play in the swivel joints on the end links will prevent any serious issues beyond aesthetic conncerns.
  13. Aug 29, 2021 at 6:13 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Throw away sway bar, issue fixed. I’ve been driving with it off for about 5 years now even towed an RV. No issues, it’s a truck not a race car, I still go fast on the highway but I be smart about it.
    Cruzer and TheBeast like this.
