DirtyDeedsIndustries biggest sale of the year!!
Discussion in 'Deals & Group Buys' started by dirtydeeds, Jul 24, 2021.
Thread Status:
Not open for further replies.
  1. Aug 20, 2021 at 8:24 AM
    #241
    dirtydeeds
    dirtydeeds [OP] Exhaust Fabricator Vendor
    Keith
    USA
    more than I can list here
    Bump for an epicsale
    Rica25 and TucsonTundra1794 like this.
  2. Aug 20, 2021 at 7:42 PM
    #242
    Stant1dm
    Stant1dm New Member
    Dave
    Michigan
    2019 Limited TRD Off-road
    My 10” is lost in transit. Hopefully I get it soon. It was supposed to delivered on Thursday but it’s been in Chicago for 2 days with no new delivery date. :mad:
  3. Aug 21, 2021 at 7:22 PM
    #243
    NWPirate
    Zach
    WA
  4. Aug 22, 2021 at 8:38 AM
    #244
    dirtydeeds
    Keith
    USA
    Give a call in the morning brotha. 760-877-4234
    Rica25 likes this.
  5. Aug 23, 2021 at 9:43 AM
    #245
    Stant1dm
    Stant1dm New Member
    Dave
    Michigan
    Well after 2 extra days in Chicago and 2 more in Indy, my 10" showed up. Better late than never. Thanks Keith.
  6. Aug 23, 2021 at 11:02 AM
    #246
    dirtydeeds
    Keith
    USA
    Hello, unfortunately, there are a lot of logistically delays with USPS, UPS, and FedEx. Glad it arrived!!!
    Rica25 likes this.
  7. Aug 23, 2021 at 2:10 PM
    #247
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Anytime I see an order shipped by USPS,I just add two weeks to the delivery and sadly, it's usually "right on time" :D
    Rica25 likes this.
  8. Aug 23, 2021 at 3:18 PM
    #248
    dirtydeeds
    Keith
    USA
    We ship primarily with FedEx, but it is cross the board with shipping delays right now.
    Rica25 and Sarcastic Zword like this.
  9. Aug 23, 2021 at 4:03 PM
    #249
    Stant1dm
    Stant1dm New Member
    Dave
    Michigan
    Well I was thrilled to get it and wanted to jump right and get it installed. However, my bolts are way more rusted than I had imagined. Unless any one has any advise, it looks like I’m gonna have to pay for someone to torch them off.
    Rica25 likes this.
  10. Aug 23, 2021 at 4:18 PM
    #250
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    @dirtydeeds Thanks again for the great exhaust! I am doing you guys proud. Came into a corner today in manual mode, dropped to 2nd and got a big backfire, powered out. Bliss.
    Rica25, dirtydeeds[OP] and NWPirate like this.
  11. Aug 23, 2021 at 4:19 PM
    #251
    NWPirate
    Zach
    WA
    Kroil or PB and a 18" breaker bar won't budge them?
    Might were really tight with little or no rust on them.
    Rica25 likes this.
  12. Aug 23, 2021 at 4:22 PM
    #252
    Stant1dm
    Stant1dm New Member
    Dave
    Michigan
    I sprayed them beforehand but when I went to wrench down to try and loosen them the bolts pretty much stripped out.
    Rica25 likes this.
  13. Aug 23, 2021 at 4:27 PM
    #253
    NWPirate
    Zach
    WA
    Gotcha, so you might need new nuts welded on the Cat side flange also. Maybe Keith will have a suggestion. @dirtydeeds
    Rica25 likes this.
  14. Aug 24, 2021 at 7:18 AM
    #254
    dirtydeeds
    Keith
    USA
    I don’t run into that situation often. But when I do I typically start by welding 1/2” round bar to the bolt head. This provides a ‘handle’. Then, after a full turn, I’ll cut it off and hopefully finish it off with code grips. If that doesn’t work then I grind off the nuts on the mid pipe side. Unfortunately, there is no easy answer for this situation:(
    Rica25 and NWPirate[QUOTED] like this.
  15. Aug 24, 2021 at 6:06 PM
    #255
    Stant1dm
    Stant1dm New Member
    Dave
    Michigan
    Well I had to grind them off. Even after grinding everything off both sides I was only able to get 2 of the 4 bolts out the other two were just too rusted. Then went and tried to take the tailpipe clamp off and that bolt snapped in half. Not sure what my next move is. Maybe it will just fall off on my way to work tomorrow.
    Rica25 likes this.
  16. Aug 24, 2021 at 6:10 PM
    #256
    dirtydeeds
    Keith
    USA
    Order a clamp from Toyota. Then cut off the stock clamp.
    Rica25 likes this.
  17. Aug 25, 2021 at 1:53 AM
    #257
    CMB
    CMB New Member
    Cecil County MD.
    These posts remind me to start coating my fasteners with Nuts Off and PB Blaster. My 14" system should be here in a couple weeks!
  18. Aug 25, 2021 at 5:49 AM
    #258
    BlueCollar89
    BlueCollar89 New Member
    Wes
    New Mexico
    2021 Army Green Limited TRD Off-road Crewmax
    Tint, rear Firestone airbags, 285/70r18 Nitto Ridge Grapplers
    Did you get an update or are you guesstimating?
    Rica25 and dirtydeeds[OP] like this.
  19. Aug 25, 2021 at 5:56 AM
    #259
    CMB
    CMB New Member
    Cecil County MD.
    I'm guessing/hoping:D
  20. Aug 25, 2021 at 6:19 AM
    #260
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Heads up, I'm hearing some pretty crappy stuff coming out of state assembly in CA.
    Some CARB Nazi is trying to make anything we do to our autos illegal.
    I can't see this going through but, this is CA. where common sense is hard to locate.
  21. Aug 25, 2021 at 7:25 AM
    #261
    CMB
    CMB New Member
    Cecil County MD.
    Well, I'll be watching because, so goes CA goes MD. Our state is ruled be the Democrat Party and it's America hating leftists, just like CA!
  22. Aug 25, 2021 at 12:09 PM
    #262
    dirtydeeds
    Keith
    USA
    We are on time so far:)
  23. Aug 25, 2021 at 12:11 PM
    #263
    dirtydeeds
    Keith
    USA
    With the current momentum, and current steel price, and amount of steel we have procured, this sale continues!!! If momentum slows we will have to shut down this sale and go back to regular price. We need volume to support these prices. Anybody on the fence about getting a system, get your order in!!!!
  24. Aug 25, 2021 at 4:13 PM
    #264
    Stant1dm
    Stant1dm New Member
    Dave
    Michigan
    UPDATE!! Finally after about a total of 6 hours of work I was able to get everything removed. 30 minutes after that my new 10” was installed. Sounds great. Took the family for a ride and got the thumbs up from the wife. :bananadance::bananadance:
  25. Aug 25, 2021 at 4:37 PM
    #265
    dirtydeeds
    Keith
    USA
    Sweet!! Glad it worked out. Did ya get the resonator installed too?
    MTRock and Rica25 like this.
  26. Aug 25, 2021 at 5:04 PM
    #266
    Stant1dm
    Stant1dm New Member
    Dave
    Michigan
    Yes. The resonator is on too.
  27. Aug 26, 2021 at 11:47 AM
    #267
    raymond_hb
    raymond_hb New Member
    Oakland, CA
    07 Tundra Limited 2WD
    So I think I mentioned earlier the dilemma of old exhaust system from the previous owner. Quick recap:
    The old system was a FlowMaster and the tailpipe had been welded to the muffler and the cat back on the driver side had been reduced. Found a local shop and had them extend the cat and weld the old tailpipe to the new system. After a week of using it I kept hearing a hissing sound and behold the shop guy cut into the new system. So what I did as a quick fix was add some tape to seal it up. Hissing sound is gone but mentally I’m not feeling too well at low rpms the system sound BA I mean the growl but the higher I go the less the sound gets. Might be exactly how the system works but one thing for sure: this thing KICKS OFF now I mean it really takes off. Haven’t seen any MPG gains might be the pedal playing lately haha but so far I can say I’m happy just that cut man it stays in the back of my head
    MTRock, Rica25 and dirtydeeds[OP] like this.
  28. Aug 26, 2021 at 12:10 PM
    #268
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I would be promptly at their door asking for a repair. Nicely of course :fenforcer:
  29. Aug 26, 2021 at 12:15 PM
    #269
    raymond_hb
    Oakland, CA
    Definitely there with you. I just came back from my first off reading trip so I’m settling down physically and mentally I’d like my head to be as cool as possible. But I do have a to pay a visit to the shop real soon
  30. Aug 26, 2021 at 1:56 PM
    #270
    dirtydeeds
    Keith
    USA
    If it comes down to it, send it back to me and I’ll repair it as it never happened, for free. You’d just need to pay shipping. I can’t believe that happened. But shots are crazy these days, had to be an accident.
Thread Status:
