New purchase maintenance
Discussion in '1st Gen Tundras (2000-2006)' started by Lanco, Aug 22, 2021.
  1. Aug 22, 2021 at 6:56 PM
    Lanco
    Lanco [OP] New Member
    Connor
    South Jersey
    2006 Access Cab SR5
    Just picked this 2006 access cab. 135,000 This is my first tundra, and looking for advice for any preventative maintenance I should do. I plan on changing all of the fluids: oil, trans, coolant, diff. Is there anything I should look at?
    Darkness, RdKing and YardBird like this.
  2. Aug 22, 2021 at 7:02 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Timing belt and water pump.
    Lanco[OP] likes this.
  3. Aug 22, 2021 at 7:10 PM
    shifty` Animals and insects don't do drugs
  4. Aug 22, 2021 at 7:12 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  5. Aug 22, 2021 at 7:16 PM
    Welcome from NY.
  6. Aug 22, 2021 at 7:16 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Timing belt is the main thing. If you have the maintenance history it would be good to go through it, especially everything after about 90k miles. Some of the things might have already been done.
  7. Aug 22, 2021 at 7:33 PM
  8. Aug 22, 2021 at 7:33 PM
    Live in the rust belt? A lot, otherwise no beyond timing belt along with water pump.
  9. Aug 23, 2021 at 8:14 AM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    A few thoughts.
    IMPORTANT STUFF:
    Timing belt/ water pump first if the previous owner has no proof of it being done, If he had proof , note the mileage he had it done and burn the 100k mile limit into your brain. Use a aisin tb kit and wp from an authorized reseller like NAPA/Summit etc. not ebay/Amazon. Its not worth the $50-$100 savings to risk the life of the truck.
    Don't let anyone use a trans flush machine. Just drain and fill the the trans pan with Toyota fluid for your specific year/model( not from ebay/amazon) Don't drop the pan for old fashioned type filter cleaning either. More cost/headache than its worth.
    Get the trans fluid level right. Follow the FSM procedure and the fluid level should be at/near the cold mark at about 120 deg, and at near the hot mark at about 175 deg. Make sure you get the exact numbers from an 05/06 fsm.
    Use a quality toyota type pink/red coolant. This will probably happen at timing belt service. So if scheduling the TB/WP you can skip this.
    If you have LSD, drain and fill the fluid with a quality synthetic w/LSD additive. LSD plates wear faster as the additive ages, so you want that fresh. If not LSD, put this on the peace of mind list and do it as time allows, but sooner than later.
    PEACE OF MIND STUFF:
    at 125k I would want to know what the plugs look like so I would do those with a NGK/Denso copper, also not Ebay/Amazon ( important). The cheap ones in the owners manual. Not the $12 Iridium's. Then I would pull and inspect them in 20-25k miles and decide then if I wanted the long life plugs. Personally I use coppers always, for the higher intensity spark, and I like looking at them more regularly. Since I save alot compared to irridiums, I throw on a new pcv valve at every plug change. Its cheap and convenient when doing plugs. Similarly, I check the valve cover bolts at the same time, they have a history of rattling free. I re-torqued mine once and they haven't ever loosened since, but I check them every plug change.
    Lube the driveline regularly, it really smooths the ride, and prevents a lot of problems.
    15 years and 125k is a long time. I would make sure all the brake fluid is fresh. 100% new.
    Also, 1st gens eat front rotors (not as much on your 06, but it is a thing) if you don't keep the rear pads/parking brake/LSPV dialed. You will notice alot of hate for the 1st gen brakes, but once the rear is dialed, they work great. 1st gens came set up expecting people to put weight in the back, people don't anymore, so rears last a lifetime and the fronts get cooked fast. Saves a lot of trouble to just learn how that rear stuff works and get some rear contribution now. Fronts will last longer, and braking performance and pedal feel will improve once the rears are set properly.
    Nothing else I can think of 06 specific that isn't true on any used car purchase.
    Have Fun.
    Brinkerro, Gravy, Darkness and 4 others like this.
  10. Aug 23, 2021 at 8:25 AM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    Welcome from Delaware
    Nice score
  11. Aug 23, 2021 at 8:30 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    First rule of 1GT club: get wp and tb
    2nd rule of 1GT club: get bj’s
  12. Aug 23, 2021 at 8:39 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome
  13. Aug 23, 2021 at 8:39 AM
    10 blue trucks
    04 4WD RCLB
    LOL I like this, I would add specifically add, ONLY TOYOTA LBJs. But, I think also he's likely got time at 125k. But worth mentioning and monitoring for sure! Were low mileage critical failures a thing on 06s?
  14. Aug 23, 2021 at 8:41 AM
    10 blue trucks
    04 4WD RCLB
    My truck is checking out good, so now I will follow rule 2 and I am off to get a BJ.
    Gravy and Cody06tundra like this.
  15. Aug 23, 2021 at 8:51 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    recommended in pairs.
    Gravy likes this.
  16. Aug 23, 2021 at 8:54 AM
    10 blue trucks
    04 4WD RCLB
    Unfortunately, not a thing where I come from anymore. But oh how I miss my 20's.
  17. Aug 23, 2021 at 9:28 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Way to make it awkward, blue. No worries, i wasnt worried about the ball joints before i came here either. But since i need all the bushings, its a thing on early trucks, might as well do it while im in there. And needle bearing replacement bushings, and some lube or sealant to things.?!
    Cody06tundra likes this.
  18. Aug 23, 2021 at 9:37 AM
    I thought the first and second rule was to never talk about 1GT club. :confused:
    Cody06tundra and bmf4069 like this.
  19. Aug 23, 2021 at 2:23 PM
    10 blue trucks
    04 4WD RCLB
    Wait, my bad, I don't think you have a dipstick right? If not, you have a different procedure. Make sure you do a little homework on that either way.
  20. Aug 23, 2021 at 3:31 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Correct !
    from 2006 FSM....
  21. Aug 23, 2021 at 6:47 PM
    Lanco
    Connor
    South Jersey
    2006 Access Cab SR5
    looks like I have a lot to do! I will probably start with the timing belt, I have heard a lot about those already.
    Thanks for the information on the breaks that will be really helpful.
  22. Aug 23, 2021 at 6:52 PM
    I feel like this has been said a dozen times recently, but you can pop the cover back and check the belt condition. As noted in another thread tonight, cover is easier to slide back on the passenger side. At least check the condition of the belt now for cracks and stuff (post a pic?) so you know if, like, you should NOT be driving it right now, or if there's some confidence you can put a few thousand miles between now and changeup time.
    empty_lord posted up a link to the water pump/timing belt kit from Aisin over here in Tundra2's thread: https://www.tundras.com/threads/2000-rclb-v8-4wd-thread.94083/#post-2376172
  23. Aug 23, 2021 at 6:53 PM
    Lanco
    Connor
    South Jersey
    2006 Access Cab SR5
    South Jersey so I would say rust belt adjacent. I had a jeep rust out on me so a clean frame was a must when I was looking, there’s a few spots of surface rust and I plan on coating the frame at some point.
  24. Aug 23, 2021 at 6:57 PM
    You could do fluid film yearly if you’re up to it. Make sure you can keep other important parts from seizing like the LCA cam adjustments, brake caliper pins, front diff drain and fill plugs, etc.
    coldcanuk likes this.
  25. Aug 24, 2021 at 11:49 AM
    Cody06tundra
    Cody06tundra New Member
    Cody
    2006 Tundra Crew Cab SR5 4.7L
    I just had to replace my belt tensioner 30,000 miles after I did my timing belt and water pump so I would definitely consider that if yours is not at 100%. I had belt squealing for a couple days and when I took the belt off and I rotated the belt tensioner to relieve pressure the belt tensioner stayed, it never sprang back, so think about that while you're doing the timing belt cuz you'll already have that part off. And if your existing serpentine belt is in good condition or okay condition I would throw that behind the back seat and put a new one on so that way if anything happens you won't be stranded. Something with spark plugs, throw a couple good ones in the glove box.
    Also I would suggest replacing the thermostat and the radiator hoses since you're going to be making a mess, just do it all at one time. It's not that much more money and it's extra piece of mind and less labor you'll have to do down the road.
    Something to consider when you do oil changes is to upgrade to the Mobil M1 - 301A oil filter because it is a good bit bigger than the stock oil filter size and it has a ton of filtration capacity
    Lanco[QUOTED][OP] likes this.
  26. Aug 24, 2021 at 2:14 PM
    Lanco
    Connor
    South Jersey
    2006 Access Cab SR5
    Good point, I definitely to do more all at once than a bunch of small jobs
  27. Aug 24, 2021 at 2:31 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I like the 2nd rule. Like, a lot.
    bmf4069 and Cody06tundra like this.
  28. Aug 24, 2021 at 2:36 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    This truck maintenance is getting exciting !
    Lanco[OP] and Cody06tundra like this.
