BSM and ABS light on after 8 inch ReadyLift lift kit.
Discussion in '2.5 Gen Tundras (2014-2021)' started by JayKay, Aug 22, 2021.
  1. Aug 22, 2021 at 10:24 AM
    JayKay
    JayKay [OP] New Member
    Hey Everyone!
    I recently put an 8 inch ReadyLift lift kit with Bilstein shocks on my Tundra and after about 2 months, the ABS and BSM lights came on. After shutting off the engine and starting it the next day, the lights turned off and stayed off. This happened twice already. I called ReadyLift and they said take it to the dealer to get the ABS and BSM re-calibrated. Does anyone know why these lights are coming on and if the dealer will be able to re-calibrate it? I have a 2014 Tundra Platinum 4x4 Crewmax. Thanks in advance!
  2. Aug 22, 2021 at 10:27 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Look for a damaged abs plug/wire or speed sensor plug/wire. Most likely it was stretched during install and it was only a matter of time before suspension movement on a stretched wire took its toll.
  3. Aug 22, 2021 at 2:21 PM
    JayKay
    The ABS plug seems to be ok with no visible damage. Any idea where the speed sensor plug is?
  4. Aug 22, 2021 at 3:38 PM
    timsp8
    NY
    There’s one on each wheel. They look like this, but you only see a little of the wire end.
