Fj jump to a Rubicon jeep
Discussion in 'Off-Topic Discussion' started by Rica25, Aug 20, 2021.
  1. Aug 22, 2021 at 8:26 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Yep, FJs and older 4Runners are getting up there now. I couldn't afford a used 4Runner so I bought a used Lexus GX460. ;)
  2. Aug 22, 2021 at 8:29 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    I would guess your wife likes the "attention" from the weirdos that think Jeeps are "cool". ;) Should have lifted the GX and put 33s on it.
  3. Aug 22, 2021 at 8:37 AM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
  4. Aug 22, 2021 at 9:15 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    FJ's are absolute units, tough, reliable, look amazing when modded and high quality once you get past the AC evaporator issue. Not to mention a collectors item :D
    Edit: Evaporator! not condenser. my bad :(
    Rica25[OP] and TheBeast like this.
  5. Aug 22, 2021 at 9:20 AM
    TheBeast
    TheBeast The Beach
    Toyota FJ can only go up in value..not so much for the Jeep :)
    but yeah I hear you on the rear doors.
    check TrailRecon youtube channel for all thing Jeep related.
    Rica25[OP] likes this.
  6. Aug 22, 2021 at 9:21 AM
    AZBoatHauler
    So.Arizona
    ^ exactly. Have her pick this or the jeep…
  7. Aug 22, 2021 at 9:23 AM
    Elduder
    Elduder New Member
    AC condenser?
    I had one for years and never heard of this. Only issues I knew of were early 07s having bad rear ends that grenaded, this was fixed quick by Toyota. The other was the pre 2010s had bad fender welds on the body and would crack causing deformation at the hood cowl.
    Rica25[OP] and AZBoatHauler like this.
  8. Aug 22, 2021 at 9:40 AM
    C.I.
    Cesar Pedrin
    Cabo, Mx
    When I worked at the yota dealer (in service) I recall at least 4 FJ's with this issue... cant remember the years affected but I was told this was quite common, matter of fact the original part was discontinued/replaced by a an improved one.
    Very sorry, it was the AC Evaporator (inside)... I always confuse the two
    Rica25[OP] and Elduder[QUOTED] like this.
  9. Aug 22, 2021 at 11:11 AM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    It’s all superficial, she likes the jeep because it’s “cute”.
  10. Aug 22, 2021 at 11:53 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    Baller. Mine is on 33s
    C.I. and Rica25[QUOTED][OP] like this.
  11. Aug 22, 2021 at 12:39 PM
    Rica25
    Ricardo
    Tulare
    Same on mine 33s.
    ShreveportTSS[QUOTED] likes this.
