Checking the oil
Discussion in '2.5 Gen Tundras (2014-2021)' started by OHwendTrd, Aug 20, 2021.
  1. Aug 20, 2021 at 9:59 AM
    OHwendTrd
    OHwendTrd [OP] Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Noob question here. How to properly check my oil w/ the dipstick and make sure I didn't add too much in. I have a '13 Tacoma and an '18 Tundra, did the oil change on both vehicles recently. I did the Tundra yesterday, added 8.5 quarts in to spec and let the truck run for awhile and drove it to make sure it cycled well through the filter.
    Do you put it all the way in and pull it out to check the proper levels, or leave it out at one of the notches on the yellow handle?
    Putting it all the way in.
    Leaving it out about to the rubber seal.
  2. Aug 20, 2021 at 10:05 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Always go ring deep. Always.
    Dr Doobie, YardBird, Blang805 and 5 others like this.
  3. Aug 20, 2021 at 10:07 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    How about the 2nd, 3rd, 4th or 5th time? lol. I think I may need to drain some out then.
  4. Aug 20, 2021 at 10:16 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    I wouldn't worry about being slightly overfilled like that. Could also check to make sure you're on level ground. The most important thing with checking oil is to make sure you're doing it the same way every time. The dipstick is an imperfect tool, so ensuring you're on the same bit of level ground, checking after a similar cool down period, etc helps you find discrepancies.
    For example, I find it much simpler to check the oil in my driveway before I start the engine for the first time that day. In my mind, you can then validate how much oil is the in the pan as it's had many hours to drain back into the pan.
  5. Aug 20, 2021 at 10:19 AM
    PKFan
    2018 Inferno! DC SR5 4x4
    To keep from overfilling, I generally put in about a 1/2 qt less than the manual calls for, as it's hard to get all the oil out just from draining. Then I top off after the fact if needed, generally checking the level like BecauseRacer above does -- cool after sitting overnight.
    15whtrd and RdKing like this.
  6. Aug 20, 2021 at 10:28 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    OHwendTrd[OP] and RdKing like this.
  7. Aug 20, 2021 at 10:35 AM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    Words we live by Saltyhero13
  8. Aug 20, 2021 at 10:36 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    That goes for every ring, everytime.
    Saltyhero13[QUOTED] likes this.
  9. Aug 20, 2021 at 10:39 AM
    RdKing
    Rich
    Eastern Seaboard
    @OHw3ndlingTRD You'll be fine, it wont bother anything.
    Next 10k oil change start it with 8qts.
  10. Aug 20, 2021 at 8:05 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Agreed. I will be doing this next change. Appreciate all the tips and suggestions everyone
  11. Aug 20, 2021 at 8:11 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Haha too late already drained a bit. Did it right from the drain plug and didn't cause really any mess so that's a plus. Dropped it down just about dead even with the high mark. Getting into doing my own maintenance on all our vehicles, good excused to run to the garage. Your '18 drinks that much oil, good to know.
    Tundratoofun and RdKing like this.
