Factory hitch rusting
Discussion in '1st Gen Tundras (2000-2006)' started by shoe07, Aug 12, 2021.
  1. Aug 12, 2021 at 1:27 PM
    shoe07
    shoe07 [OP] New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    I went to replace my bumper this evening which has some holes in it, and found the factory hitch/structural bumper looks a little rough. Should I just clean it up and paint or go another route?
    w666 likes this.
  2. Aug 12, 2021 at 1:34 PM
    I think new to replace that is around $1000 or so. You could get a bumper reinforcement for $200-250 and pay another $200 for an aftermarket hitch.
    If you want to save cash and don’t tow anything near its limit, I’d just grind off the rust and paint it with POR-15. The replacement chrome bumper will cover most of it.
    BubbaW likes this.
  3. Aug 12, 2021 at 1:35 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    if it were mine i'd probably replace it or cut it off so the temptation to tow with it would be an impossibility.
  4. Aug 12, 2021 at 1:37 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    you don't want to tow with that. I would look around, may find replacement at salvage or for sale online used.
    CallsignKodiak likes this.
  5. Aug 12, 2021 at 2:04 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  6. Aug 12, 2021 at 2:06 PM
    shoe07
    Ohio
    That’s unfortunately what I was thinking. Grrrrr
    Jack McCarthy likes this.
  7. Aug 12, 2021 at 2:17 PM
    Cancer spreads. Get it outta there. Treat your frame. Replace.
  8. Aug 12, 2021 at 2:17 PM
    If you can find more than one used in good shape, let me know. I need to replace my bumper reinforcement and would like the integrated tow hitch if possible as well. Truthfully, I’d be surprised if you found one.
  9. Aug 12, 2021 at 7:06 PM
    shoe07
    Ohio
    Have you found the necessary parts for this change? The dealership wants 1600 for the oem replacement.
    etrailer has hitches for under $200. I would need to change to the non trailer package bumper.
    where do ya’ll search for parts? I’m terrible at it. I can’t find diagrams like you guys post on the dealership websites
  10. Aug 12, 2021 at 7:14 PM
    shoe07
    Ohio
    Would this be what I need? If I got this and a bolt on hitch off etrailer I’d be back in business?
  11. Aug 12, 2021 at 8:24 PM
    It seems that way if it lines up with the OEM chrome bumper and mounts directly to the frame.
    Here's an exploded diagram from another member. I don't know if he posted it for his 2004 or the OP's 2001 in another thread...
    NewImprovedRon likes this.
  12. Aug 12, 2021 at 11:35 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    https://toyotaparts.bochtoyotasouth.com/oem-parts/toyota-trailer-hitch-pt22834110
    i run this hitch with the non tow package bumper. price is fair and it bolts up nice and tight unlike the aftermarket ones. this was the OE hitch for 00-02 i believe. or a dealer add on. i cant find any clear info
    may want to double check fitment with double cab. but i dont think there were any differences in the hitch setup between doubles and access/reg
    but your current hitch is shot. replace it before the rust spreads to the frame or worse, w/e you're towing ends up becoming its own vehicle on the highway
    Burgmane and Jonny Rotten like this.
  13. Aug 13, 2021 at 4:38 AM
    shoe07
    Ohio
  14. Aug 13, 2021 at 4:59 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    If you choose to go OEM, your SR5 part #'s are identical to my Limited 2004. Was gathering the parts list when I took mine off for maintenance.
    Personally, with what you tow, I would invest in new or at least check out some Pick-A-Part places in your area for at least items 6 and 7.
    below is from McGeorge Toyota for an SR5....
    Trailer Hitch Components for 2004 Toyota Tundra | Toyota Parts (mcgeorgetoyota.com)
  15. Aug 13, 2021 at 5:11 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    You have a PM. :thumbsup:
  16. Aug 13, 2021 at 5:25 AM
    empty_lord
    05 rollover special
    Yes I have the standard bumper support
  17. Aug 13, 2021 at 9:45 AM
    I'm surprised you can attach a class 3 hitch instead of a ball to the standard bumper support. The bumper support the OP originally has looks like it can take the full tow rating for the 2004 Tundra (if it wasn't rusted).
    I'd be leary of towing a full size RV trailer using the standard bumper support that doesn't normally take the integrated hitch.
  18. Aug 13, 2021 at 10:09 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Are the bolt holes for the hitch capable of supporting weight? Great excuse for a steel flatbed/bumper/hitch/5th wheel.
  19. Aug 13, 2021 at 11:36 AM
    shoe07
    Ohio
    Ended up getting the non tow package bumper and the curt hitch rated for 1000lbs tongue weight, which is comparable to the oem hitch. The standard bumper support hitch with the accessory is rated for ~600 lbs tongue weight with wdh. The tow package trucks hitch is 1005 lbs iirc
  20. Aug 13, 2021 at 11:40 AM
    shoe07
    Ohio
    In for $367.49 versus nearly $1500 for the oem Toyota hitch plus other bolts etc that I needed/broke when removing the old parts.
    I imagine the Toyota one is better built, but I find it hard to justify spending 4 times as much. I’ll report back when all the parts arrive next week.
    Fingers crossed I do t regret this decision.
  21. Aug 13, 2021 at 11:55 AM
    My experience is that a lot of aftermarket bolt on hitches tend to rust sooner than OEM. I’m guessing since you let the original one slide in care, you’ll be more diligent in treating it this time round.
    shoe07[OP] likes this.
  22. Aug 13, 2021 at 12:52 PM
    shoe07
    Ohio
    I’ve only had the truck since December, and the side I could see didn’t look to terrible, just what was hidden by the bumper cover which has been on my list to replace since I got the truck.
    I had it treated with corrosion free two weeks after I got it, and the frame is 3 years old. I don’t think finding it in December would have changed anything.
    tvpierce and Jack McCarthy like this.
  23. Aug 17, 2021 at 7:00 PM
    shoe07
    Ohio
    My parts showed up tonight two days early. Things look pretty good and I think I’ll be ok with the finished product.
    The box from etrailer was very damaged which was concerning, but only a couple of nicks on the hitch surprisingly.
    The bumper off ebay is not a genuine Toyota part which I thought it was as the part numbers were shown. Reading the description a little more thoroughly revealed it was my bad.
    however it all the bumper looks very well made, the welds have great penetration. The bolt holes appear to line up with where things are on my current hitch.
    The paint was a little poor so I went ahead and hit it with 2 coats of primer, and 2 coats of paint, and touched up the damaged spots on the hitch while I was at it.
    tomorrow I’m going to pick up some fluid film for the reassembly .
    The wife had surgery today, and I’m playing nurse/cook/daycare etc for the next couple weeks. With being able to drive her van I can leave the truck project day to day without needing to button stuff up.
    Hopefully I can get everything apart and together by Monday.
    Pics too come
    Cody06tundra likes this.
  24. Aug 17, 2021 at 7:12 PM
    She and I both. Huh. Main reason I've been posting like mad today, bored out of my mind sitting on my ass in "recovery".
    Anyway, Curt makes solid products. And you're supporting USA manufacturing, so kudos to you for that. I'm sure you'll be more than happy with it, can't wait to see install pics!
  25. Aug 20, 2021 at 5:00 AM
    shoe07
    Ohio
    Got it all buttoned up last night. Looks good. I believe I’ll be happy with it as both the hitch and bumper seem well built. My only concern is the safety chain connections are a little further away so I may need to extend the chains on my trailer.
  26. Aug 23, 2021 at 11:45 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    This is timely for me. I have been trying to get my hitch out of the carrier all year, but it is permanently rusted in. I thought maybe I could just find a new carrier, and change it with just 4 bolts. I cringed looking at these pictures however. It's likely I'm in the exact same situation. I'll have pull the bumper off for a closer look. I've been searching for a used OEM trailer hitch assy, but no luck so far. At least now I know there's a reasonable alternative.
