RainMan's 2021 Lunar Rock TRD Pro Build
Discussion in '2.5 Gen Builds (2014-2021)' started by RainMan_PNW, Oct 30, 2020.
  1. Aug 5, 2021 at 6:57 AM
    #391
    LunarLuke78
    LunarLuke78 New Member
    Luke
    DFW
    2021 -LR- Tundra TRD Pro
    Classic!
  2. Aug 8, 2021 at 9:59 PM
    #392
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Somewhere in North Idaho, on some land that is in the family…
    And at my parent’s 60 acres in NW Montana
  3. Aug 10, 2021 at 9:39 AM
    #393
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Truck is looking good. Looks like your Wescott lift settled a little in the front and you have a little rake back??
  4. Aug 10, 2021 at 6:07 PM
    #394
    RainMan_PNW
    Casey
    Clark County, WA
    I think it’s more just the angle of the shot. I do need to park it on level concrete and measure again.
    FISHN43[QUOTED] likes this.
  5. Aug 10, 2021 at 10:31 PM
    #395
    JIB2021SR5
    JIB2021SR5 New Member
    2021 White SR5
    Great write up Casey - What is the part # for the Backup light switch you used
  6. Aug 11, 2021 at 7:36 AM
    #396
    RainMan_PNW
    Casey
    Clark County, WA
    TRDFerguson likes this.
  7. Aug 11, 2021 at 8:00 AM
    #397
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  8. Aug 16, 2021 at 9:22 AM
    #398
    RainMan_PNW
    Casey
    Clark County, WA
    Got around to painting my tow hooks yesterday.
    Used a 17mm socket and breaker bar to break the bolts loose, then pulled them off. Hit them with some brake cleaner, then a wire wheel (both on my grinder and on my hand drill) to rough up the factory paint, then a good soak with brake cleaner again after hanging them on a make-shift rack.
    Two coats of Duplicolor self-etching primer, then three good coats of Rustoleum Caliper Paint (red) and then left them hang in the 88 degree heat for about 4 hours.
    Then use the same 17mm socket to put them back on, and gave them a good extra snug with the breaker bar to make sure they were good and tight.
    Not very visible in this last shot, but it's just a good looking truck. :cool:
  9. Aug 19, 2021 at 9:03 AM
    #399
    BWPRO
    BWPRO New Member
    Bryce
    2021 Tundra TRD PRO
    Truck looks is great brother! I'm thinking of running the same set up with wescott and coach builder. Would you recommend getting 3" CB shackles? I want the truck to sit leveled or as close to leveled as possible with the wescott fronts. Also how are you liking it? Any difference in the ride quality?
  10. Aug 19, 2021 at 9:15 AM
    #400
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I would like to do the same lift. But after being in Portland Maine last week had to park in garage for parking. I barely fit height wise. 5 levels in the garage the higher you went up the lower the garage got. I don’t want to even try to explain. Lol.
    bulldog93 likes this.
  11. Aug 19, 2021 at 9:33 AM
    #401
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I've got the Westcott lift on mine and definitely get claustrophobic in parking garages now, lol.
  12. Aug 19, 2021 at 10:05 AM
    #402
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I started to enter a parking garage in Nashville that said 6’5” clearance. I hit the brakes and backed out. I’m on TRD Fox suspension with CB +2 shackles and 285/75s, and it was too close for my comfort. I don’t think the shark fin would hit it, but man it looked so close.
  13. Aug 19, 2021 at 10:25 AM
    #403
    RusPro21
    Don
    Pa.
    The yellow things that hang down 2 of them. I had to make sure my antenna fin was in the middle of that would have got knocked off. After that I was backing down could not go any further.
  14. Aug 19, 2021 at 12:08 PM
    #404
    RainMan_PNW
    Casey
    Clark County, WA
    So, the CB+2 will level you out pretty much dead on (if you don't have any sustaining load in the back such as topper or rack/RTT). I actually want a slight amount of rake so I'm considering either switching to the CB+3 or putting the Roadmaster Active Suspension on the truck and then re-evaluating what shackle to use.
  15. Aug 19, 2021 at 12:09 PM
    #405
    RainMan_PNW
    Casey
    Clark County, WA
    I still need to park on a level slab, grab a helper and a level, and take measurements from the top of the fin to the ground.
  16. Aug 19, 2021 at 12:11 PM
    #406
    French Avocado
    Utah / Wyo
    But do you duck when you drive under the bar? Even though the roof is above my head I still duck instinctively.
    bulldog93, Dsptundra, RobertD and 2 others like this.
  17. Aug 19, 2021 at 12:14 PM
    #407
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    Even though my truck is still stock height and not yet lifted, I have still ducked on low parking garage ceilings.
  18. Aug 19, 2021 at 12:16 PM
    #408
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
    I'd like to know this measurement. I plan on do a similar setup when mine comes in. I have a feeling it won't fit in the garage.
  19. Aug 19, 2021 at 12:21 PM
    #409
    Kung
    KG, VA
    It may be instinct, but it's a little known fact that if you duck quickly when entering a parking garage, it compresses the suspension *JUUUUUSSST* enough that you can slide the truck in without sustaining damage. It's even more effective if you have a few bubbas with you who can duck @ the same time.
    RainMan_PNW[OP] likes this.
  20. Aug 19, 2021 at 12:22 PM
    #410
    BWPRO
    BWPRO New Member
    Bryce
    2021 Tundra TRD PRO
    okay sounds good. So +2 should be good . Only weight I have in the bed is my mx4 bakflip cover
  21. Aug 19, 2021 at 12:40 PM
    #411
    RainMan_PNW
    Casey
    Clark County, WA
    yes. every. damn. time.
    In my old truck, I actually hit one of those in a parking garage once. It was half-way up the ramp from L1 to L2. had to back down the ramp and circle for a spot on L1...
  22. Aug 19, 2021 at 8:46 PM
    #412
    RainMan_PNW
    Casey
    Clark County, WA
    The red anodized hardware in my switch mount plate and the AJT trim had faded to more of a pink, so I swapped it all out for black, including the screws in the shifter too.
    Elroy_unlimited, Yzed608 and Fotnot like this.
  23. Aug 20, 2021 at 10:01 PM
    #413
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    Spent a majority of my day reading through this thread. Awesome note keeping. Everything is so nice and organized.
    Thank you for all these links and what not. Makes everything easier to navigate and find.
    Leo's first and RainMan_PNW[OP] like this.
  24. Aug 20, 2021 at 10:13 PM
    #414
    RainMan_PNW
    Casey
    Clark County, WA
    Thanks. I did it that way so that I could go back and find stuff. On my last truck, I had information and pictures and write-ups scattered from hell to breakfast and so when I got this one I figured I better start tracking things right away.
    Leo's first and Blang805 like this.
  25. Aug 27, 2021 at 9:14 AM
    #415
    RobertD
    Robert
    DFW, Texas
    Hey Casey, for your Boost tow mirrors I know you did the high output flood light. How do you like them? Are they too bright in the cab? Is it worth the extra money over the low output?
  26. Aug 27, 2021 at 9:28 AM
    #416
    RainMan_PNW
    Casey
    Clark County, WA
    I don't know how the low output looks, but I don't find the high output to be too bright. In the front seats, you really don't see the light itself, and in the rear seats you've got ~20% tint from the from the factory.
    That said, I also don't use those lights much (because they are on a separate switch). But I haven't been out in the truck after dark a whole lot either this summer.
  27. Aug 27, 2021 at 9:41 AM
    #417
    RobertD
    Robert
    DFW, Texas
    Okay, appreciate it. I was going to wire them to my reverse lights and was just curious. With the price of everything going up I'm really thinking about placing my order soon
  28. Aug 30, 2021 at 8:15 AM
    #418
    FISHN43
    FISHN43 New Member
    Ohio
    Hey Casey how close is your tire to your UCA after the Wescott lift and alignment? Just curious because we’re both running the same tires and I just lifted my Pro up front with CB shims (only .75”). These tires are so close as it is which does not leave much to adjust the toe out. I know very little about alignment but I saw your specs are “in the green” but with the tire already being that close to the UCA a proper alignment has me worried. Your alignment shop say anything about how close your tires are to the UCA and getting the toe back in spec?
  29. Aug 30, 2021 at 5:39 PM
    #419
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    I bought the high output, and don't regret them one bit. You don't even know they are there unless you look in the mirror. And like Casey, haven't used them much (I hate driving at night), but look forward to them during the fall, winter, spring. Mine are currently wired into the reverse lights.
    RobertD[QUOTED] likes this.
  30. Aug 30, 2021 at 5:51 PM
    #420
    RobertD
    Robert
    DFW, Texas
    Thanks! I work the evening shift and head home at roughly midnight so mine will get used often in the dark hahaha
