Bilstein TRD Pro Suspension, install question
Discussion in 'Suspension' started by Mediumrarepls, Aug 15, 2021.
  1. Aug 15, 2021 at 8:12 PM
    Mediumrarepls
    Mediumrarepls [OP] New Member
    2019 Tundra SR5 TRD Offroad Crewmax Quicksand 4x4 5.7
    I just purchased a used bilstein trd pro set. Before i start my install I was wondering if anyone knew if any other mods need to be done. I heard that I may need relocation brackets for my abs line. I always thought the rear shocks were the same length and the front were 1.5 inches taller.
    I was hoping it would just be a straight swap.
    Thanks
  2. Aug 15, 2021 at 8:17 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Easy swap! On the front, disconnect the sway bar, it will allow the arm to drop a lil more and fit the taller shock in
  3. Aug 15, 2021 at 8:20 PM
    Mediumrarepls
    Do I need to get relocation brackets for abs and break lines? Is the rear the same height as the stock trd offroad set up?
  4. Aug 15, 2021 at 8:23 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Same. The rear height wont change from the shocks
  5. Aug 15, 2021 at 8:24 PM
    Mediumrarepls
  6. Aug 15, 2021 at 8:25 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    The rear ride height is the same as stock trims, but the travel is longer. You could damage your lines at full droop without the brackets.
  7. Aug 15, 2021 at 8:27 PM
    Mediumrarepls
    Brake line and abs?
  8. Aug 15, 2021 at 8:31 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yep, I didn’t test the full limit, but when I swapped leaf packs I definitely had some tension on both before I realized I needed to disconnect the brackets. I fabbed up some DIY extensions before I reconnected them.
  9. Aug 15, 2021 at 8:34 PM
    Mediumrarepls
  10. Aug 15, 2021 at 8:35 PM
    Mediumrarepls
    I'm guessing this will work? Sorry for the notice questions. I've never done this before.
  11. Aug 15, 2021 at 8:37 PM
    Black
    2014 Tundra Limited CrewMax
    That is what you need. Easy and cheap.
    TRDFerguson likes this.
  12. Aug 15, 2021 at 8:38 PM
    Mediumrarepls
    Sweet! Thx
  13. Aug 19, 2021 at 7:39 AM
    Mediumrarepls
    Last question before install. Is there anything I need to extend or relocate in the front? 20210819_073530.jpg
  14. Aug 19, 2021 at 8:33 AM
    Kanobi13
    Kanobi13 New Member
    How are you trying to swap just unbolt and replace or disconnect lower control arm?
  15. Aug 19, 2021 at 8:34 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  16. Aug 19, 2021 at 8:39 AM
    Mediumrarepls
    I'm hoping to just unbolt and replace.
    I believe the pro shocks add 2 inches. I'm curious if it's necessary to have longer brake lines. What's other people's experience with this.
  17. Aug 19, 2021 at 8:52 AM
    Rodtheviking
    Vancouver, WA
    Sequoia
    Brake lines should be fine, was just an option while stuff is out.
  18. Aug 19, 2021 at 9:50 AM
    Kanobi13
    Kanobi13 New Member
    Just be careful not to pull cv joint out. I did not extend lines
  19. Aug 19, 2021 at 11:36 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Disconnect the brake line and senser wire brackets so they can move more. Disconnect the sway bar first, that will help you move the shocks
    Mediumrarepls[OP] likes this.
  20. Aug 19, 2021 at 2:58 PM
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
    Brake lines are fine no need to extend them. Just unbolt them during install. Shoot me a text or call if you have anymore questions.
  21. Aug 19, 2021 at 3:00 PM
    Black
    No need to extend the brake lines with that setup.
    TRDPros have the same factory lines as everyone else. Yes, you need to be careful when everything is disconnect during install so you don’t stretch them but once everything is reassembled there is plenty of brake line.
    Mediumrarepls[OP] and Hbjeff like this.
