Larger tires, tricks our odometer and…
Discussion in 'Wheels & Tires' started by Redcon41318, Aug 17, 2021.
  1. Aug 17, 2021 at 9:10 AM
    Redcon41318
    Redcon41318 [OP] New Member
    So I have been thinking, does running larger than equivalent oem tire size trick or give false mpg readings? Does this mean it also provides in accurate odometer readings, since larger tires equal more distance covered?
    YardBird likes this.
  2. Aug 17, 2021 at 9:12 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    yes
    Oey12, snivilous and YardBird like this.
  3. Aug 17, 2021 at 9:14 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    This is the case for every vehicle ever, none can measure and adapt to changes in wheel size without reprogramming. Some guys go through the trouble most guys don't, I will be when I upgrade my tires.
  4. Aug 17, 2021 at 10:38 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Yes it does but I don't worry about it. I know the difference and compensate for it. In the old days of mechanical odometers it was a real pain to fix it.
  5. Aug 17, 2021 at 11:05 AM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Other brands allow you to adjust this in the computer but not Toyota. Gotta get an add on box to trick the tundra
  6. Aug 18, 2021 at 6:33 AM
    Redcon41318
    So in a sense bigger tires, i will put slightly less miles on my truck!?
    Thanks guys for the clarification.
    Tundratoofun likes this.
  7. Aug 18, 2021 at 7:55 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Correct. One revolution on stock tires gets you x' down the road. One revolution on larger tires gets you further because of the larger circumference but your computer still only reads what stock tires would have traveled.
  8. Aug 18, 2021 at 8:59 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    you can get a hypertech speedometer calibrator. a couple hundred bucks on Amazon. I got one after putting 20s/37s on and it got my speedometer to within 1 or 2mph of accurate speed.
  9. Aug 18, 2021 at 9:12 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Can larger diameter (than stock) tires affect your braking system in any way ?
  10. Aug 18, 2021 at 9:30 AM
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    Yes because they're heavier. More weight takes more effort to stop. That said, I have no braking issues after a 7" lift & 37s (might be different for the earlier gen Tundras, but my gen3 is fine. I'm not towing anything though.). That also said, I'm upgrading rotors and pads to heavy duty ones anyway because ...more weight more effort to stop. Plus I'd be much more able to brake effectively if/when hauling/towing.
  11. Aug 18, 2021 at 9:31 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Yes, based on the fact that you’ve got more weight in the tires, greater rotational mass, and increased inertia from that. So the brakes will need to work harder to stop the vehicle.
    YardBird[QUOTED] likes this.
  12. Aug 18, 2021 at 8:57 PM
    Redcon41318
    I like the performance so much on my truck it sounds funny! I swear i felt a decline in performance going e rated on 265 tire size!
  13. Aug 18, 2021 at 10:43 PM
    Blue Thunder
    Washington
    I’ve tested my truck’s speedo (cruise control) against a GPS. My truck is actually 2mpg slower. When I go with slightly larger tires, it should be dead on.
    Hopefully will fix the 0.5mph difference against my hand calculation as well.
    So check your truck before buying any equipment to “fix it”.
  14. Aug 19, 2021 at 2:05 PM
    Redcon41318
    Good copy!
  15. Aug 19, 2021 at 2:32 PM
    DVCNick
    DVCNick New Member
    2011 5.7 4x4 Double Cab
    Speed is easy with any instantaneous GPS app, but getting an accurate MPG will be a little trickier as the distance recorded by the truck is wrong too.
    I think you'll have to GPS a route to get a known, fairly long distance, drive it as straight as possible, and then gas up and see how much you used. And likely you'll have to do this several times and get an average if you really want a pretty accurate reading.
  16. Aug 19, 2021 at 2:38 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
