Splash guard install
Discussion in '1st Gen Tundras (2000-2006)' started by mbreed2, Aug 17, 2021.
  1. Aug 17, 2021 at 11:23 AM
    mbreed2
    mbreed2 [OP] Is not right
    Allentown PA
    2001 Tundra 4x4
    Now that I got your attention... sounds dumb I know. This has been off for over a year and I'm not sure how the corner plastic pieces are supposed to go on under the fog lamps. Can anyone snap a pic for me? It's pretty straight forward, but does the black plastic go under or over the metal tabs. And the white clip on nuts, do they clip over the metal tabs or over the black plastic?
  2. Aug 17, 2021 at 11:33 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Care to take a pic of what part you are asking about ? Your year FSM shows that area but clueless which part you're speaking of.
  3. Aug 17, 2021 at 11:34 AM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    When I'm done pooping sure.
    bmf4069 and shifty` like this.
  4. Aug 17, 2021 at 11:37 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
  5. Aug 17, 2021 at 11:41 AM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
  6. Aug 17, 2021 at 11:58 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
  7. Aug 17, 2021 at 12:11 PM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Close but no cigar. I'm looking at the other end. That thread shows mounting the plastic end pieces to the middle steel piece. Im looking for mounting under the fog lamps.
  8. Aug 18, 2021 at 6:49 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Plastic clips go on the tabs mounted on the bumper support, not the actual plastic guard. Grab some Over sized Diameter washers to put under the bolt heads and spread the load of the bolt when you install them into those clips. Without the washer, they have a tendency to squash the plastic and enlarge the hole in the splash guard.
    mbreed2[QUOTED][OP] likes this.
