2011 tundra bumper on 2007?
Discussion in '2nd Gen Tundras (2007-2013)' started by Jambalaya, Aug 17, 2021.
  1. Aug 17, 2021 at 9:47 PM
    Jambalaya
    Jambalaya [OP] New Member
    Juan
    2007 Toyota tundra 4x4 sr5
    Hi just wanted to ask if a stock bumper from a 2011 tundra will fit on a 07 .I'm assuming so but rather be safe than sorry thanks !
  2. Aug 18, 2021 at 1:34 AM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    Short answer: Yes.
    If the new bumper is 2 piece, plastic upper and steel lower (base or SR5) it should bolt right up. If it’s one piece plastic (limited, platinum, Rock Warrior), I believe there is more than just the bumper shell needed to make it work.
