Cold start chirp chrip
Discussion in '1st Gen Tundras (2000-2006)' started by jerryallday, Aug 17, 2021.
  1. Aug 17, 2021 at 2:08 AM
    jerryallday
    jerryallday [OP] New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I have been chasing this chirp at cold starts. I replaced the belt with a gates green v-belt and did a new tensioner pulley and bearing (gates brand). Noise went away for a week and came back.
    I then replaced the idler pulley. The noise stayed the same but for less time. The chirp last about a 1 second and goes away.
    Sounds like it’s coming from the alternator or power steering (passenger side)
    I can get it to chirp for longer if I press the window switches up while the widows are closed during the cold start. I can also get it to chirp if I turn the wheel back and forth instantly after cold start.
    I can get the noise to stop instantly If I turn the ac on after cold start.
    I think it may be the actual tensioner since I only replaced the pulley, bad belt, alternator or battery going bad (battery is coming up on 3 years). Battery has good voltage after cold start.
    169k miles 2006 double cab
  2. Aug 17, 2021 at 3:12 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  3. Aug 17, 2021 at 8:15 AM
    If you decide to replace the tensioner, it might be a good time to replace your OG alternator since it has to be removed to get the new tensioner in place. I plan on doing both at the same time.
  4. Aug 17, 2021 at 8:28 AM
