Turning signal on my chevy
Discussion in 'Off-Topic Discussion' started by IgotSR5onit, Aug 16, 2021.
  1. Aug 16, 2021 at 8:18 AM
    IgotSR5onit
    IgotSR5onit [OP] New Member
    Figured Id post here and see if anyone could offer up any advice as the silverado forum is kind of dead. I have an 06 1500 I use to work out of. A couple of weeks back I noticed my driver turning signal was not engaging on my trailer. I was extremely busy and have been short employees so I let it ride. By the time I got to it I noticed that it stopped working on my truck also and the turning signal light was staying lit like a bulb was out. Right turning signal works fine, left turning signal engages flashers. checked bulbs, all good. check fuses, both trailer and truck turning signal fuses were blown. Changed, no affect. Replaced the hazard relay/switch, no change. So a few moments ago I decided to take all the lights out and get a better look and I noticed theyre not firing like they should I took a picture, but on the drivers side with drivers turning signal engaged bulbs 3 and 4 fire while on passenger side bulbs 1 and 4 fire. Im at a loss.
  2. Aug 16, 2021 at 9:10 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Have you tried swapping back in regular bulbs? Might have something to with the LEDs.
    IgotSR5onit[OP] likes this.
  3. Aug 16, 2021 at 9:29 AM
    IgotSR5onit
    i just got done cleaning the ground and checking all the wiring underneath to no avail. The leds have been on for a couple of years, but I guess I just need to try that because Im running out of ideas.
  4. Aug 16, 2021 at 9:37 AM
    IgotSR5onit
    went out and noticed when I turned on the hazards everything worked fine. Possibly a problem with the switch on column?
  5. Aug 16, 2021 at 10:18 AM
    Check the contacts on the steering wheel stalk, those usually go bad.
  6. Aug 16, 2021 at 10:21 AM
    IgotSR5onit
    I was messing around with it and I didnt think about it, but Ive always ran the lights on Auto. So I turned the headlights on manually to make sure nothing was out and I noticed I couldnt even engage the turning signals at all. I turned the hazards on and nothing from them either. About that time someone stopped in to talk to me and while I was complaining about the situation with the truck the hazards suddenly come on. I turned them off and then everything worked as it should. Im baffled to say the least. I dont feel like this problem is solved, but as of this moment its working. Id still like to try to remedy it completely. Maybe in the Light switch on the dash? that was the only thing I did differently.
  7. Aug 19, 2021 at 4:37 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    With GMs if you have tilt they tend to wear or break wires in the column. Replace the turn. Signal switch.
