This bugs me.
Discussion in '2nd Gen Tundras (2007-2013)' started by azimuth, Aug 15, 2021.
  1. Aug 15, 2021 at 9:01 PM
    azimuth
    azimuth [OP] New Member
    2010 double cab SR5
    I have tried adjusting the catch and latch. The other side closes flush. Not sure what to do from here. Suggestions? TIA
  2. Aug 15, 2021 at 9:48 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Is that tonneau cover rail pushing on it? Had a similar issue when I installed my retractable cover, had to move the rails cabward a bit.
    Fiesta346 likes this.
  3. Aug 15, 2021 at 9:50 PM
    azimuth
    2010 double cab SR5
    No it doesn't touch. The other side barely touches.
  4. Aug 15, 2021 at 9:55 PM
    Gravy
    Yucaipa, California
    Hmm, dunno then. Does it rattle when you drive or is it tight, just misaligned?
  5. Aug 15, 2021 at 9:58 PM
    azimuth
    2010 double cab SR5
    It doesn't rattle. It's not even that far out. If I push in it goes flush but doesn't stay. Maybe some chub sat on the gate on that side....lol
    TheBeast likes this.
  6. Aug 15, 2021 at 10:00 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Buddy, if you have few enough worries in life to be bothered by that, thank whatever god you pray to.
  7. Aug 15, 2021 at 10:01 PM
    azimuth
    2010 double cab SR5
  8. Aug 15, 2021 at 10:01 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    My 2014 looks like that if I pussyfoot the tailgate closed.
    If I slam it closed, its all flush..
  9. Aug 15, 2021 at 10:04 PM
    azimuth
    2010 double cab SR5
    I slam it too. Still hangs out. It is a first world problems kind of deal though. Reminds me of Clark Griswold in Christmas Vacation fixing the newel post.....
  10. Aug 15, 2021 at 10:08 PM
    Gravy
    Yucaipa, California
    Maybe your latch has gone limp *cough*.
  11. Aug 15, 2021 at 10:09 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    It would bother me as well..
    You are not alone....:eek2::thumbsup:
    Dag3, TaquitoBandito and GODZILLA like this.
  12. Aug 15, 2021 at 10:11 PM
    azimuth
    2010 double cab SR5
    Oh no you dint! *wags chicken neck*
  13. Aug 15, 2021 at 10:12 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    I'm with you OP, Mine is the same way,bugs the shit outa me!
    ;I'm talking about the tailgate, not the chicken neck:rofl:
  14. Aug 15, 2021 at 10:56 PM
    Gravy
    Yucaipa, California
    Well, assuming no 400 lb Karen jumped on your tailgate, and you've adjusted the catch, I'd maybe pull the latch out, see if any of the internals are worn. Nm, looks like a riveted construction. Maybe find a bolt same diameter as catch and stuff it in the latch, see if it holds in firmly.
    azimuth[OP] likes this.
  15. Aug 15, 2021 at 11:24 PM
    azimuth
    2010 double cab SR5
    Good idea to check the latch function....
  16. Aug 16, 2021 at 4:20 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    If it bothers you, try a body shop. Yes, you might have to pay a bit. But at least stop in, show them and ask if they can fix it. They may even help you with a little "DIY" advice.
    1lowlife, azimuth[OP] and GODZILLA like this.
  17. Aug 16, 2021 at 4:43 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Peace be with you... Can I get a Amen?
    1lowlife likes this.
  18. Aug 16, 2021 at 5:35 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    That would be my plan...... You could remove both striker plates then just push the tailgate against the rubber stops mounted to the bed. If the tailgate is flush with the bed side to side, then the issue is an adjustment with either the striker plates or latch (which have the least amt of adjustment). if it's not flush, then the tailgate has a "twist" or "warp". See above post.
    1lowlife and azimuth[OP] like this.
  19. Aug 16, 2021 at 5:48 AM
    2mchfun
    Can any fasteners be shimmed to shift it over? I mean maybe you could add a few washers.
  20. Aug 16, 2021 at 6:18 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Have you tried slamming it shut from the side that sticks out and not from the middle. That's what mine does sometimes too.
  21. Aug 16, 2021 at 6:18 AM
    18" TRD Off Road Wheels
    Have you popped the tailgate off and looked at the hinge point on that side? Had a similar issue with a work truck years back, and it was the hinge bushing that had started to collapse and was affecting alignment.
    ColoradoTJ, 1lowlife and Gravy like this.
  22. Aug 16, 2021 at 6:20 AM
    Ericsopa
    Ericsopa Old man and the sea
    If the other side closes flush, then the tailgate itself must be warped. Now this might sound a little hairy, but I've done it before on a passenger door (not on my Tundra, though). Take a 2x4 wrapped in a towel and wedge it between the left fender and the tailgate and push on the right side to try and realign the tailgate. Try to remove the warp. LIke I said, it's worked on car doors. Don't know if you want to do that or not, but I'd try it if it were mine. Be sorta gentle to start.
  23. Aug 16, 2021 at 9:47 AM
    hhenry_
    hhenry_ New Member
    Bay Area Ca
    08 tundra crewmax
    I have the same problem also. I tried slamming it but it’s still the same.
  24. Aug 16, 2021 at 9:56 AM
    15whtrd
    15whtrd Mr. Blonde
    If you can’t adjust the strikers any further, and the lock mechanism is in good working order without excessive wear on the clasp, you could try a little more rudimentary of an approach. Maybe try smacking the striker with a dead blow. It might just be bent out a little from something hitting the tailgate from the inside. Maybe even a large box end wrench to just tweak it.
  25. Aug 16, 2021 at 10:19 AM
    TheBeast
    TheBeast The Beach
    check the latch on the right side.
  26. Aug 16, 2021 at 10:26 AM
    Rubberdown
    Rubberdown Spilling my guts here.
    What everyone else said. Adjust the striker on that side. Pull it in further and it out to get you squared away.
  27. Aug 16, 2021 at 10:42 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Mine does that on the right side because my retractable cover is adjusted about a 1/16" farther than it should and so it causes that side to not fully engage unless I close it hard. Then it sits flush.
    I just need to adjust my cover on that side a little... maybe I'll go do that this afternoon.
  28. Aug 16, 2021 at 9:54 PM
    azimuth
    2010 double cab SR5
    Follow up: I checked and did all that was suggested. Did find that my latches were a bit slow so I cleaned and lubed them. No change. Time to break out the 2x4. I opened the tailgate and placed a block between the gate and the catch, sidled my way to the passenger side and gave the top of the gate a shove. Closed and checked. It was closer. Thrice more and creeped up on just right. It's so close to flush now that I didn't want to go too far. Now it doesn't beg for my attention when I close the gate or walk around it. Too dark for a pic. will try to post one tomorrow.
  29. Aug 16, 2021 at 10:31 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Good news..
    At least you can take comfort in knowing, with all these responses, you are not the only one that would be bothered by such a small detail.
    The average Joe Blow 'ham and egger'* would never notice it, but we/you/I would notice it EVERY TIME you walked up to the truck...:eek::eek2::oops:
    Glad to see you are making progress and that it may help others in the future...:thumbsup:
  30. Aug 16, 2021 at 10:41 PM
    This is exactly what I was going to suggest.
    GODZILLA[QUOTED] and 1lowlife like this.
