  1. Aug 15, 2021 at 5:02 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    PCV replaced today at 108k. It was grimy but still functional.
    9517D118-65E5-4B43-BCCF-47B72A7CFA4C.jpg BFD301BA-EEAD-4EDB-BC55-440D5C4C18D2.jpg 6437AABB-34CA-40DA-A19C-67CB93A357B9.jpg
  2. Aug 15, 2021 at 5:47 PM
    French Avocado
    Utah / Wyo
    Anyone had a latch break on the glove box? If so, then how did you fix it?
  3. Aug 15, 2021 at 8:57 PM
    azimuth
    azimuth New Member
    2010 double cab SR5
    I mounted two 75lbs Hill and Wood magnets last March/April. I used some Gorilla 60# double side tape hoping they would stay. They did very well until last Friday when I parked such that the Western late afternoon sun shone directly on them with my windows up and this all metal gun mounted. Came back to the truck after 30 mins. and they had pulled off the surface. Dang. So today I mounted them with mechanical fasteners.
    Also, several days back I fixed the sliding Weathertech mat on the passenger side. Driver side stays put. But the passenger side was always out of place. Search the web and found these Eagle Klaw mat retainers on ebay.
    They look OEM and no more sliding mat
  4. Aug 16, 2021 at 5:43 AM
    BEDINTRUDER
    BEDINTRUDER New Member
    Dom
    OHIO
    2011 Tundra RockWarrior (SOLD) 2018 Tundra Limited
    Hauled the toy out to southern Ohio this weekend and got some seat time in RZR2.jpg RZR1.jpg
  5. Aug 16, 2021 at 6:40 AM
    Where did you go Wayne National?
  6. Aug 16, 2021 at 7:01 AM
    BEDINTRUDER
    Dom
    OHIO
    YEP! Tecumseh Trails
  7. Aug 16, 2021 at 8:46 AM
    rvrats2
    rvrats2 Too Often Yankees Overprice This Auto
    Carbondalé, CO
    2011 SR5. Bench Seat!
  8. Aug 16, 2021 at 10:20 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Spent most of the day yesterday under the truck, sanding rust off the frame and treating it with Opsho. It's 2/3 done now, only the center section to go.
  9. Aug 16, 2021 at 11:56 AM
    McYoda
    McYoda H4x0r
    Brady
    Oregon
    2010 “Grade”
    I’ve never done that before (the sanding of the frame or using Opsho). Any good tutorial you’d recommend? My understanding is rust the primary longevity concern for these trucks.
  10. Aug 16, 2021 at 12:02 PM
    BlackSheep
    Scott
    Kansas City, MO
    No tutorial, the instructions on the Opsho container just say to remove as much of the rust as possible with brush, wheel, flap disc, etc. then apply a thin coat of it with a brush. Let dry for 24 hours and brush away any residue, then prime and paint. It says multiple coats of Opsho may be necessary in areas of heavy rust. Or, in lieu of paint, you could apply fluid film, POR 15, or some kind of thick oil or grease.
    McYoda[QUOTED] likes this.
  11. Aug 16, 2021 at 1:04 PM
    oogabooga289
    oogabooga289 New Member
    From what I remember from way back when researching, Ospho was a rust converter? Which kind are you using?
    I've been meaning to do something like this for years but end up putting it off due to the seemingly large time commitment to wire wheel and brush on all the nooks and crannies.
  12. Aug 16, 2021 at 2:25 PM
    BlackSheep
    Scott
    Kansas City, MO
    Yes it’s a rust converter. The idea being, you can’t get all the rust in the nooks and crannies up under the truck, so you kill it by chemically changing it and then seal the frame.
    omgboost likes this.
  13. Aug 16, 2021 at 4:03 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Sharptail?
  14. Aug 16, 2021 at 5:10 PM
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    BDS 7 w/ Fox 2.5 OME Dakar leaf pack CB +2 shackles 18x9 Method 308 +18mm 37x12.5 Toyo AT3 TRD intake/exhaust Infinity Kappa w/ Pioneer HU
    Crossed 100k today. Bittersweet.
    2011, only mechanical issue was a MAF sensor. Couldn't be happier 20210816_093024.jpg
  15. Aug 16, 2021 at 6:44 PM
    Punisher17
    Punisher17 New Member
    Me too last Wednesday actually. Forgot to post
  16. Aug 17, 2021 at 5:23 AM
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    I see you with the S mode over there. What year are you? I've had two cross country trips between GA>AZ, and I put only about 8-10k a year on the road. Luckily I use the Altima for most of the around town trips.
    What, if any, mechanical issues have you had so far? I've been very lucky, but curious to see what others have experienced so far. Aside from the secondary air system and water pump, and maybe some other random small stuff, these motors seem flawless.
    Punisher17[QUOTED] likes this.
  17. Aug 17, 2021 at 5:23 AM
    Ktate
    Ktate New Member
    2007 RCSB SR5 TRD 4x4
    Installed the Demello Off Road hidden winch plate, Smittybilt X20 10k winch, and Baja Squadron lights. The added weight dropped the left side 1/2 inch a d the right side 1/4 inch. Bilstein 6112s and 5100s are next. 09BB48A6-D4F5-4A69-B39A-45354F715495.jpg
  18. Aug 17, 2021 at 6:57 AM
    rvrats2
    Carbondalé, CO
    I don’t know. Looked more like a blue, standing in the road like an idiot. Somewhere outside of Rock Springs WY.
  19. Aug 17, 2021 at 7:29 AM
    Retroboy1989
    Northern Utah
    Ha!
    I didn't zoom in on the picture. I thought you were just showing off your take. My thought was, "that's odd he wired it to the bumper for a picture"
    You literally took the Tundra hunting.
  20. Aug 17, 2021 at 9:51 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The Tundra can be a formidable weapon...;):laser:
    rvrats2 and joseph_womack like this.
  21. Aug 17, 2021 at 2:23 PM
    raymond_hb
    raymond_hb New Member
    Oakland, CA
    07 Tundra Limited 2WD
    Finally got my BamMuffler system today but came across tailpipe welded onto the original muffler. What I’m wondering is if it’ll be safe to cut where that welding scar is or buy a new pipe instead? Looks rusty down there but it might also be dirt
  22. Aug 17, 2021 at 3:39 PM
    Joshuamk98
    Joshuamk98 New Member
    Josh
    2013 Black TSS Tundra
    Fox 2.0 coilovers, 1.5 IFP Shocks Nitto Ridge Grapplers 18” Method NV305 Morimoto XB LED Headlights
    Got my new suspension and wheels installed this past weekend. Fox 2.0 in the front and 1.5 in the rear. Tires and wheels are Nitto Ridge Grapplers 285/70r18 and Method NV305 18x9
  23. Aug 17, 2021 at 4:19 PM
    Retroboy1989
    Northern Utah
    Towed a rented travel trailer up over a mountain pass yesterday.
    My brakes are smooth around town but shudder when they get hot from highway driving or towing. Ordered a set of powerstops. My wife has complained about the same thing on the sienna, so out comes the wallet.
    I've never heard of shudders from rear brakes, so I'm not concerned about those. Should I be?
  24. Aug 17, 2021 at 5:03 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    That sucks…
  25. Aug 17, 2021 at 5:59 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Love bronze wheels on black, nice setup!
    Joshuamk98[QUOTED] likes this.
  26. Aug 17, 2021 at 6:07 PM
    Shanet421
    San Diego,CA
    Totally sucks! I would reach back out to Keith and see what he can do for ya
  27. Aug 18, 2021 at 2:46 AM
    Punisher17
    2007 SR5 Crewmax 4.7L it does have the s mode and it has 6 seats which has paid off a lot with kids. It’s on a 2.5 inch leveling kit and 33x12.50r18 gets like 12mpg in the mountains which sucks but we have 2 other better mpg vehicle so my Tundra since I’ve had it put on 20k miles in 4 years.
    Maintenance I’ve done are all 4 o2 sensors(had cel), secondary air injection valve(had cel and limp mode), new OEM muffler (original developed holes that I noticed), water pump and timing belt, spark plugs and coil packs, new transfer case and both diff oils, front brakes and stainless brake lines. That’s pretty much it. Now if we are talking mods I counted the other day at about 35 mods :cool:
  28. Aug 18, 2021 at 12:01 PM
    raymond_hb
    Oakland, CA
    So after getting multiple opinions and quotes on the Bam Muffler system dilemma I found a shop that was able to weld an extender on the driver side catback. It seems like the previous owner had installed a FlowMaster and had modified the cat back and I had the FlowMaster tailpipe welded on to the Bam Muffler systems. I’ve gotta say it’s exactly as advertised stock sound until you hit that pedal. At low RMPS you get that nice low growl and I’m loving it. It sounds exactly like a Tundra should sound. Now with my compass bear sticker and new exhaust system I can say the bear has its growl now
  29. Aug 18, 2021 at 7:49 PM
    careyrob
    Carey
    Massachusetts
    The sienna has a tsb out for a front brake shudder. It's caused by a plastic baffle in the wheel well that prevents adequate airflow to cool the front disc. You just have to cut a section of plastic our of the way to solve the problem.
    I did it in the driveway on my wife's sienna with a pocket knife. Took 15 minutes if that.
    joseph_womack likes this.
  30. Aug 18, 2021 at 8:45 PM
    Peeeheeuuu
    Peeeheeuuu New Member
    Peter
    Elk Grove, CA
    08 Tundra CM 4x4. 21 Sequoia SR5 4wd
    Nothing but parts stacking
