Limited crewmax stock suspension
Discussion in 'Suspension' started by Legbuh, Aug 13, 2021.
  1. Aug 13, 2021 at 2:42 PM
    Legbuh
    Legbuh [OP] New Member
    2019 Crewmax Limited
    I just took delivery of my 19 crewmax limited. It looks to have a leveling kit.
    Front springs are red and the rear shocks say fox on them. Is this stock? This isn't a TRD or off-road version.
  2. Aug 13, 2021 at 2:43 PM
    Pics will help to know for sure, but you might have a set of the TRD PRO shocks. The regular TRD off-roads are blue/yellow bilstein shocks with black springs.
    BravoDeltaRomeo likes this.
  3. Aug 13, 2021 at 4:20 PM
    Legbuh
    Front
    Rear
    GODZILLA likes this.
  4. Aug 13, 2021 at 4:23 PM
    Legbuh
    It almost looks leveled too. It's got tinted windows, and shin killer nerfs too.PXL_20210813_232145116.jpg
  5. Aug 13, 2021 at 4:24 PM
    Ah, ok, those are not anything that came from Toyota. You've got an aftermarket suspension there. If you google BDS Suspension Fox, you'll see bunches of results.
  6. Aug 13, 2021 at 4:25 PM
    Looks pretty good. Those steps look like the Predator Steps that Toyota sells as an accessory.
  7. Aug 13, 2021 at 4:26 PM
    Legbuh
    I hope that's a good thing lol. Didnt say anything on carvana about it. I also noticed a small shimmy in at 55. Discount tire fixed that no problem and let me know the front tires weren't stock.
  8. Aug 13, 2021 at 4:28 PM
    Carvana usually provided free carfax. I'd pop that up and see if it has maintenance records that indicate suspension work. You might be able to talk to the shop that did it. Could have been done by the owner too.
    From your pics it looks like a Fox 2.0 kit, and it should definitely be a better ride than the stock ones would have been.
    MinehunteR and T-Rex266 like this.
  9. Aug 14, 2021 at 12:48 PM
    Legbuh
    Nope, nothing in the carfax. I scoured it looking for anything. It only showed Window Tint being installed.
    I also found out that the PO put LED fogs in... not just bulbs, but what look like factory type LEDs. I was going to install some yellow JDM ones. :)
  10. Aug 14, 2021 at 2:13 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    That's a nice surprise to find when buying a used truck. Wish mine came with upgraded suspension that the dealer didn't know about.
  11. Aug 14, 2021 at 3:21 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I keep seeing 50 buck and wondering "who the hell is this guy?" I generally know all the regulars and I keep forgetting its you.
  12. Aug 14, 2021 at 3:46 PM
    Yeah, that's why I edited my line under my username. Thought it might help.
    Any complaints about my change in identity should be directed to @War Machine, @ToyoMafia, and @Squatting Pigeon via PMs. As these are to be considered official complaints, please be sure to submit each complaints in triplicate to each individual. Each copy must be submitted separately to ensure that they are correctly processed.
  13. Aug 14, 2021 at 3:48 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    :bananadead: Bring it.
    GODZILLA[QUOTED] likes this.
  14. Aug 14, 2021 at 3:51 PM
    :drevil:
    ToyoMafia[QUOTED] likes this.
  15. Aug 14, 2021 at 3:51 PM
    ToyoMafia
    Magic carpet.
    I’ll just add it to the pile of complaints. :crapstorm:
  16. Aug 14, 2021 at 6:49 PM
    War Machine
    War Machine SSEM # 5 3MW
  17. Aug 15, 2021 at 5:25 AM
    Legbuh
    I just wonder if that's why it has different front tires... ie, they didn't get an alignment after all the suspension mods and wore the tires quickly.
    when I take it in for the fuel pump recall I will have them check alignment as well.
  18. Aug 15, 2021 at 5:29 AM
    Very well could be the cast. Might have had bad tire wear when Carvana got it, so they replaced the front tires as part of their inspection. Is there a way you can contact Carvana to ask if they performed an alignment on the truck? If they can't confirm that they did an alignment, then I would be for getting it done sooner rather than later. An alignment is cheaper than tires.
  19. Aug 15, 2021 at 5:43 AM
    Legbuh
    Also, they had the tire pressures backwards... 35 in front and 30 in the rear. That's opposite from what I read on the door jam. :)
  20. Aug 15, 2021 at 5:45 AM
    Ah, maybe they had two people doing the job. One that figured they'd move the old tires to the front and put the new tires on the rear because they take more wear, and then another who just threw them on the front to get the truck out the door.
  21. Aug 15, 2021 at 7:48 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    When you get alignment, make sure you get the print out. Some places will say they did it but then you see the print out and your still in red on some of them and they then tell you they weren't able to get it fully aligned. I've had places tell me the printer isn't working but it's in all green then I take it else where and it's all out of whack. That's when I realized I needed UCAs on my 4runner.
  22. Aug 15, 2021 at 1:27 PM
    Legbuh
    Took a closer look at the front suspension. It is trd pro . Starting to look like a better deal all the time.
  23. Aug 15, 2021 at 1:28 PM
    Yeah, that's a solid upgrade!
  24. Aug 15, 2021 at 2:05 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Now pop the hood. Maybe they accidentally installed a supercharger too.
  25. Aug 18, 2021 at 7:49 PM
    Legbuh
    Well,I found led under body lights too that turn on with the interior lights when you open the door
    And black letter inserts on the tailgate. I thought that was stock
    No sc though. Bummer.
    TucsonTundra1794 likes this.
