1st Mod
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cashlock82, Aug 14, 2021.
  1. Aug 14, 2021 at 8:06 PM
    Cashlock82
    Cashlock82 [OP] New Member
    Corey
    1798 tundra
    Morimoto xb headlights with demon eyes
    F1A6A8B5-C735-442F-9E5F-6AEC453D2B5A.jpg F7D1B13A-9801-49A5-9190-2E68AD221A79.jpg D3108F40-BEE2-4631-B590-1AD624AAECED.jpg Put Profile Prism RGB strips inside a set of Morimoto XB headlights controlled with a Morimoto XBT controller to get the Demon Eye look since there is no off the shelf demon eyes to buy I created the look with strips lights.
  2. Aug 14, 2021 at 8:22 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Legal where you live?
  3. Aug 14, 2021 at 8:51 PM
    Cashlock82
    Corey
    1798 tundra
    Technically No because the strip lights are not DOT approved, but as long as I’m not showing red or blue I don’t think I’ll have a problem. The Morimoto controller has a color wheel you can adjust them to any color you want.
  4. Aug 14, 2021 at 8:56 PM
    TILLY
    Massachusetts
    Can you go back to just the stock lights with the controller?
  5. Aug 15, 2021 at 3:45 AM
    Cashlock82
    Corey
    1798 tundra
    You could if you wanted to but there’s no need to because you can turn the RGB strips lights on/off with the XBT controller. To answer your question yes you can use the controller with the stock lights.
  6. Aug 15, 2021 at 3:52 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    It’s your truck and your money. I’ve never understood the appeal. Every time I see that I think the same thing I do when I see a truck with the front end lifted six inches higher than the rear: Why?
