Upper Control Arm Bolt Issues
Discussion in '1st Gen Tundras (2000-2006)' started by Kings, Aug 14, 2021.
  1. Aug 14, 2021 at 6:34 PM
    Kings
    Kings [OP] New Member
    Trying to take off my stock upper control arm to replace with new SPC uppers, but the driver's side UCA bolt has no more room to be removed. Getting held up by what looks like metal brake lines. It's a 2006 DC 2WD.
    Has anyone else run into the issue? Passenger side was a breeze but I'm pulling my hair out about this bolt.
  2. Aug 14, 2021 at 6:40 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You'll have to remove the bracket holding the brake lines, and then carefully push them towards the engine bay to make room for the bolt to slide out.
    I've installed 2 sets of SPCs total. One set on my truck, and one set on @jpink's truck. Mine was an Access Cab, and his is a 2005 Double Cab. Both were about the same.
  3. Aug 14, 2021 at 6:40 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    We had that problem on @jImmegart truck. It was a seriously stubborn one to get out. We kept wiggling it until eventually it came out. Getting it back in was just as much fun. Stay at it, its shitty but it will come out. Angle it away from the brake line. We considered unbolting the brake lines but they didn't even move.
    On my truck it had easy clearance which I found interesting.
    Siebler, jImmegart, des2mtn and 3 others like this.
  4. Aug 14, 2021 at 6:52 PM
    Kings
    Alright thanks for the replies. I was hoping for some secret step I was missing but I'll keep at it.
    jImmegart likes this.
  5. Aug 14, 2021 at 6:54 PM
    Fun fact, that plastic bracket that holds those brake lines will be brittle after 15 years and will snap as soon as you try to remove it.
    :anonymous:
  6. Aug 14, 2021 at 7:18 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Guess I got lucky. I just unbolted it and gently held them outta the way. Didn't have much issues with putting the bolt in or taking out
    Siebler and Darkness like this.
  7. Aug 14, 2021 at 8:59 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The part I found interesting is @jImmegart truck and mine are practically the same. Both 2wd 03, even the same color. Mine had a lot of clearance and his was like this.
  8. Aug 14, 2021 at 9:15 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    i had to remove my bracket to do mine.
    still better than the tacoma and having to BEND THE BODY out of the way.
  9. Aug 14, 2021 at 10:50 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    Ya it is strange. yours seems to be the odd one out.
    Darkness[QUOTED] likes this.
  10. Aug 15, 2021 at 12:21 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'll take it :D
    jImmegart[QUOTED] likes this.
  11. Aug 15, 2021 at 8:07 AM
    Mine came right out too. This was part of why we joked that John's DC stood for Double Complex because everything seemed more difficult.
  12. Aug 15, 2021 at 9:59 AM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    I feel like I remember it maybe touching as it came out but definitely didnt have to fight them on my 01 either
  13. Aug 15, 2021 at 11:33 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    When I did mine I just pulled the front of the upper arm out from the engine which made the rear of the arm angle in and then in turn made the bolt head angle out…if that makes sense. Still had to unbolt the lines like everyone else and took a while but got it out eventually.
  14. Aug 15, 2021 at 11:39 AM
    Kings
    Mission accomplished. Had to be more aggressive with those brake lines and like someone said the plastic bracket snapped immediately.
    Side note, these are "Mevotech" upper arms from Rock Auto but the branding, part numbers and instructions are all SPC. Even came with the grease-able ball joint version which was a plus.
  15. Aug 15, 2021 at 1:00 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Good to hear they updated to the grease-able ones. In the past the Mevo versions had the non-zerk ball joints.
    Good job!
