  1. Aug 14, 2021 at 4:16 PM
    1794TX
    Steven
    N.TX
    '20 1794
    Yeah, well, I couldn't really get by without them, at least without grunting and drama; so @602runner isn't wrong...:rofl:
    French Avocado likes this.
  2. Aug 14, 2021 at 4:19 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Nothing personal hahaha
  3. Aug 14, 2021 at 4:24 PM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Installed LED "Porch Lights" on my roof rack. My intention was to connect four lights that could be controlled by the OEM cargo light switch on my dash. I also wanted to be able to independently control the lights for each side, since I use my CVT canopy on either side of the truck depending upon my camping site. Most importantly I wanted to avoid drilling any holes in the roof to run the wires if at all possible. Thanks go out to @junior and his "My DIY Roof Rack" thread which gave me some ideas as to how to accomplish this.
    These lights sell for $99 a pair for this rack from the manufacturer of the rack.
    https://www.victory4x4.com/product/VRKLED.html
    I found the exact same lights (check the specifications on both sites) for $14.95 each so I purchased four of them.
    https://www.superbrightleds.com/mor...ch-and-utility-light-700-lumen-12v/5568/9848/
    The light kit from from the rack manufacturer comes with CNC cut backing plates. I bought a Harbor Freight 48" aluminum ruler for $4.99. To make my backing plates I cut them to length and drilled holes for the bolts, it was the perfect width for the cut outs in the rack.
    I spray painted the backing plates with black enamel. These are the parts I used to make my wiring harness for the lights.
    2 - waterproof boxes from Amazon.
    https://www.amazon.com/gp/product/B08N6P4HPH?ie=UTF8
    2 - pigtails to fit my cargo light bulb receptacles.
    https://www.amazon.com/gp/product/B0837SZ1NJ?ie=UTF8
    2 - small waterproof switches
    https://www.amazon.com/gp/product/B07LCH1N3B?ie=UTF8
    I didn't end up using the 2 pictured male and female Deutsch connectors for this install, I soldered my connections instead. I also used marine grade adhesive lined shrink wrap on all the connections.
    I removed my cargo light LED bulbs and installed the pig tails. I drilled two small holes through the plastic top of my cargo/third brake light receptacle. I used rubber grommets and black silicone sealant on both sides of the holes (not shown).
    I ran the wires along the inner side of the rack and mounted the waterproof box behind the Victory logo using that cutout for the bolts for the box.
    I mounted a waterproof switch on top of each box to keep it dry and I can reach up and click the switch to turn on/off the lights on either side (it rained on me).
    The lights work great, give out a lot of light and the two rear facing ones replace the cargo lights where I tapped the connection from. It's more useful for them to be further outboard on the rack when I use my RTT anyway.
    Overall a cost effective, secure and watertight method of installing lights on my cab rack without drilling the roof.
  4. Aug 14, 2021 at 4:47 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Resourceful indeed! Well-done!
  5. Aug 14, 2021 at 4:50 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Same. Wish I could ditch mine.
  6. Aug 14, 2021 at 4:54 PM
    TampaRD Pro
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    I also attached Rhino Rack Pioneer MaxTrax Small Side Mount Brackets to my Front Runner x Diamondback Rack System, so that I can carry my Maxtrax MKII's out of the bed area and still carry my kayaks on my roof rack at the same time.
    https://www.amazon.com/gp/product/B01966CLUA?ie=UTF8
    https://diamondbackcovers.com/colle...oducts/front-runner-x-diamondback-rack-system
    I used another set of the Rhino Rack Pioneer MaxTrax Small Side Mount Brackets to attach a pair of Victory Roof Rack Accessory Mounts on the other side of the bed to allow mounting of RotopaX or shovel/axe, etc.
    I used eye bolts as part of the mounting assembly to add mounting options for the bars.
  7. Aug 14, 2021 at 4:59 PM
    JL98
    JL98 New Member
    2016 MGM Tundra DC TRD Off-Road
    TRD Pro Grille, 32'' LED Light Bar, 275/70/18 Duractracs, 18x8 RSSW Krawler wheels (+30 mm offset), Bilstein 5100 top setting (front), 1'' block rear, Plastidipped badges
    Made my '16 MGM look like it did back when it was driven off the lot today!
    A good wash, clay bar, wax and some elbow grease is all it took!
    [​IMG][​IMG][​IMG]
  8. Aug 14, 2021 at 4:59 PM
    TampaRD Pro
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Thank you!
    HulkSmurf14[QUOTED] likes this.
  9. Aug 14, 2021 at 5:01 PM
    Nice. I bet they look good at night.
    TampaRD Pro[QUOTED] likes this.
  10. Aug 14, 2021 at 5:06 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Did you measure fender height before and after? Just curious if it settled at all.
  11. Aug 14, 2021 at 5:26 PM
    TampaRD Pro
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    And... to finish my weekend modding I installed a Midland MicroMobile MXT275 GMRS radio into Rotundra. The install was easy as I mounted the head unit inside the center console where it fit nicely. I ran the hot wire directly to the battery to avoid electrical interference. I actually ran it to my new Blue Seas Fuse Block that I installed with my Switch Pros 9100 system recently. I used a 10 amp fuse in the block, it made for a very clean install. The radio comes with a cable and small magnetic base antenna but I purchased a Midland 6 meter NMO cable and a Midland 3db Gain Ghost Antenna (and a Midland 32" 6 db Gain Antenna with Spring Base to give me more options depending upon terrain and conditions). I ran a CAT 6 cable through my console and out under the dash to connect the microphone to. (I haven't installed the mic holder clip yet) this way the unit is completely hidden except for the mic which has all the necessary controls.
    https://www.amazon.com/gp/product/B07FN2FBML?ie=UTF8
    https://www.amazon.com/gp/product/B0842B1WFS?ie=UTF8
    https://www.amazon.com/gp/product/B08429ZT37?ie=UTF8
    https://www.amazon.com/gp/product/B084BPXNC5?ie=UTF8
    I routed the antenna cable through the rubber firewall grommet into the engine bay and attached it to my Rago Fabrication Lo-Pro Ditch Light Bracket via a Rago Ham Antenna Ditch Bracket Extension.
    GAknight, Pangaea, JDR76 and 10 others like this.
  12. Aug 14, 2021 at 5:32 PM
    TampaRD Pro
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Yeah, they light it up pretty good. Gives me some options when setting things up in the woods.
  13. Aug 14, 2021 at 5:35 PM
    Charvonia Design
    Keith
    Huntersville, NC
    I got N-fab steps on Amazon for a really good price and thought they looked a lot better.
  14. Aug 14, 2021 at 5:39 PM
    Sarcastic Zword
    Sarcastic Zword What’s old is new again.
    Al
    U.S.A.
    2015 Tundra 5.7
    Had planned a wash, coating decon and refresh but it rained instead…:rain:
  15. Aug 14, 2021 at 5:59 PM
    Punisher29073
    Punisher29073 New Member
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    Have not. i will check in the AM. I have previous measurements.
  16. Aug 14, 2021 at 6:00 PM
    1794TX
    Steven
    N.TX
    '20 1794
  17. Aug 14, 2021 at 6:59 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Installed some @mattgecko led’s in hood bulge and behind grill today - wired up to a dual button factory style switch and a couple of relays via a add a circuit fuse tap
  18. Aug 14, 2021 at 7:31 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Good call. Those chrome/black tube things are hideous. The fact the dealer charges you extra and markets them as an "Upgrade" always made me roll my eyes. Straight to the garbage.
    Just awful IMO.
    woods, Barrett50 and Tundrastruck91 like this.
  19. Aug 14, 2021 at 7:45 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Had the dealer take those off and switch out the plat 20's with the TRD 18's before driving it off the lot :) awww much better !!
  20. Aug 14, 2021 at 8:42 PM
    jimbrophotodotcom
    jimbrophotodotcom New Member
    Hawaii
    2021 Lunar Rock Tundra TRD Pro
    IG: @LunaTheTundra, Coachbuilder kit and 35s soon
    How do you like the RAS system?
  21. Aug 14, 2021 at 9:34 PM
    swallace
    swallace Insert profound statement —> here <—
    Steven
    Tri-Cities, WA
    2014 Silver Sky Metallic CM 4.6L 4x4
    6112/5160, DD 10”, Amp steps, Alea leather, more…
    Random question, but how do you put GIFs in a posts?
  22. Aug 14, 2021 at 9:43 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Its easy, right click on the Gif, hit copy link address, then paste in the forum box. :)
  23. Aug 14, 2021 at 9:47 PM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    Need some night pics
  24. Aug 14, 2021 at 9:47 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
  25. Aug 14, 2021 at 9:49 PM
    TILLY
    Massachusetts
  26. Aug 14, 2021 at 9:53 PM
    swallace
    Steven
    Tri-Cities, WA
    woods, RainMan_PNW, GODZILLA and 2 others like this.
  27. Aug 14, 2021 at 9:55 PM
    TILLY
    Massachusetts
    :cheers:
    IsaiahCanada likes this.
  28. Aug 15, 2021 at 12:35 AM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    Bought a replica insert, spent an hour taking off the TRD Pro Insert to swap with my grill surround. I have to say, for how cheap it was, it's a pretty decent copy IMO! Now I just need to find someone who wants a brand new black grill surround and black grill...
  29. Aug 15, 2021 at 2:43 AM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
  30. Aug 15, 2021 at 3:34 AM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    Love it. Really helps with load handling, sway, squat, and actually helped with smoothing out little bumps in the road too unloaded
