  1. Aug 13, 2021 at 3:07 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I've never tried the grapplers, I see decent reviews but not interested, I'm the same with the STT like you.
    Have you taken the KO2 in slick or cold yet? I'm guessing cold is hard this time of the year no matter where you are. I've noticed on my tacoma and the wifes t4r unless you are super easy on a take off you will be spinning. It's embarrassing to me if I burn rubber leaving the dentist or something after a light rain.
  2. Aug 13, 2021 at 3:48 PM
    Brettstation37
    Brettstation37 New Member
    Brett
    Catskills NY
    2020 Tundra CrewMax TRD Sport
    free candy and puppies don’t work anymore…
    But if it says FREE WiFi ya better look out..
    Fotnot[QUOTED], Hightide and GODZILLA like this.
  3. Aug 13, 2021 at 4:01 PM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    Installed the Helmhotz resonator on my Dirty Deeds 10” today and it sounds bitching. Plasma cutter made it go quick. Also painted my running boards and brought one of my tires in to get the leaking tpms sensor repaired.
    142473A5-6031-46D3-9D14-1C1277FB09D3.jpg 69C84A96-AE38-47CE-BFE6-DB46E483341B.jpg 01CEE48A-F64C-481D-8521-76AED02E609C.jpg
  4. Aug 13, 2021 at 4:04 PM
    RobertD
    Robert
    DFW, Texas
    Have you seen the Netflix movie The Mitchells verse the Machines? That scene makes me laugh so much
    the ER kid likes this.
  5. Aug 13, 2021 at 4:15 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Hell yeah, they look awesome!
  6. Aug 13, 2021 at 4:33 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Same. No problems on any of mine either.
    TundraTXTSS and CoachJ[QUOTED] like this.
  7. Aug 13, 2021 at 5:27 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Installed some yotaleds
  8. Aug 13, 2021 at 5:34 PM
    infidel
    infidel New Member
    Jesse
    SE Wisconsin
    2016 Silver SR5 Crewmax
    Procomp 3/1 Method 307 18x9 +25 Falken Wildpeak AT3W 295/70r18
    You wire them to the marker lights?
    Ive been eyeing these, just need to do it already.
  9. Aug 13, 2021 at 5:35 PM
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
    I removed the factory tube steps. This is my highway cruiser. Looking lean, nimble and fast!
  10. Aug 13, 2021 at 5:39 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    And a transmission cooler in case he tows something.
  11. Aug 13, 2021 at 5:45 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    you can pick between an add a fuse, or a physical switch. I went with the add a fuse and placed it in the INJ 10 amp location
  12. Aug 13, 2021 at 7:19 PM
    BWPRO
    BWPRO New Member
    Bryce
    2021 Tundra TRD PRO
    Gave her a much needed bath and ceramic coat.
    Lassie and Fotnot like this.
  13. Aug 13, 2021 at 7:21 PM
    BWPRO
    BWPRO New Member
    Bryce
    2021 Tundra TRD PRO
    Looks good! I'm thinking about doing this. You wouldn't happen to know how long the wiring harness is with the switch would you?
  14. Aug 13, 2021 at 7:25 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    no idea honestly, adding the switch increases the price by $20 so I got it without it.
  15. Aug 13, 2021 at 7:27 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    This happened today. Probably because of all the humidity in the air. Luckily tvd always sends spares. Might need @Rerun steady hands to put it on though.
    Fotnot and AZTundra like this.
  16. Aug 13, 2021 at 7:36 PM
    AZTundra
    Paul
    Phoenix, AZ
    I used the wet method to install mine and then a toothpick to align it before touching it with a q-tip to dry up the water and lock it into final position. A bit tedious, but seemed to work well.
    NewImprovedRon and RainMan_PNW like this.
  17. Aug 13, 2021 at 7:38 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Reflective tailgate letters went on earlier
    804E548D-04E2-43D2-96EE-D5DB0050DB33.jpg ADD8B0E3-C67A-484B-855F-CF66407F71D9.jpg
    3xYOTA, WonkyDonkey, woods and 12 others like this.
  18. Aug 13, 2021 at 7:41 PM
    RobertD
    Robert
    DFW, Texas
    Interesting.... bet that will look cool at night to everyone behind you!
  19. Aug 13, 2021 at 7:42 PM
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
  20. Aug 13, 2021 at 7:43 PM
    Squatting Pigeon
    Holden
    North Texas
    It catches light pretty well, I bet it looks cool in traffic at night!
  21. Aug 13, 2021 at 7:45 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Same here
  22. Aug 13, 2021 at 7:48 PM
    swallace
    swallace Insert profound statement —> here <—
    Steven
    Tri-Cities, WA
    2014 Silver Sky Metallic CM 4.6L 4x4
    6112/5160, DD 10”, Amp steps, Alea leather, more…
    Installed Platinum quilted dash panel. Thanks @Toyotoholic! It matches my seats now and helps bring the interior together.
    Old
    New
    GAknight, 3xYOTA, GELCW and 31 others like this.
  23. Aug 13, 2021 at 7:54 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Yeah that's what we did, did em with the frac mod and it's been fine up until today. I'll try tomorrow to put another on.
    RainMan_PNW and AZTundra[QUOTED] like this.
  24. Aug 13, 2021 at 7:54 PM
    BlueRibbon4x4
    Geno
    Installed the Diode Dynamics SS2 ditch lights today. Combo spot/flood, nice and bright.
    3AC7D7F8-CD20-4975-B4F1-816C602EFABD.jpg BDD521BF-6714-4A5F-8316-321B05E9124A.jpg 8333041E-7E01-4A47-ADF1-555A4F9F11AB.jpg 2D2DE17A-5A4F-476F-95B6-A6E70AAFDA47.jpg
    GAknight, woods, mgm16trdpro and 13 others like this.
  25. Aug 13, 2021 at 7:55 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Yes! I have the same set! My wife said they are crazy bright when your behind it at night.
  26. Aug 13, 2021 at 7:58 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I had Cooper AT3 XLTs and really liked them. The tread wore very well and still was good enough even after 50K miles. They also didn’t spin on wet pavement and did well in dry off-road trails (I don’t go mudding - hate the cleanup afterwards). My only other experience with Coopers were with their Discoverer ATs that I had on an 03 Tacoma many years ago. They did fine until a large bolt pierced the top thread and blew it out. It wasn’t even sharp, just a large bolt that somehow penetrated. Not sure how it happened, and it was probably a freak occurrence. But that was about 10 years ago. Anyway, I would’ve considered the AT3 XLTs again if they would’ve had them in my size this last time.
    ctkny, woods and AZTundra[QUOTED] like this.
  27. Aug 13, 2021 at 7:59 PM
    Squatting Pigeon
    Holden
    North Texas
    Good :devil:
  28. Aug 13, 2021 at 8:09 PM
    RobertD
    Robert
    DFW, Texas
    :rofl::rofl::rofl:
    I was so confused how you installed these like normal ditch lights since when you shared the bracket image, my ignorance thought the bracket was the whole front piece (which is the front of box with brackets resting against it) lol
    I didn't understand how adding 2 lights a foot apart was going to work as ditch lights :facepalm:
    At least you knew what you were doing.
  29. Aug 13, 2021 at 8:17 PM
    Brettstation37
    Brett
    Catskills NY
    mine fell off quite some time ago, need to replace…maybe one day
  30. Aug 13, 2021 at 8:22 PM
    BlueRibbon4x4
    Geno
    Understandable! But wait, you were gonna let me install ditch lights a foot apart? :rofl:
    GODZILLA and RobertD[QUOTED] like this.
