4hi or 4lo
Discussion in '1st Gen Tundras (2000-2006)' started by Strangebird22, Aug 13, 2021.
  1. Aug 13, 2021 at 7:46 AM
    Strangebird22
    Strangebird22 [OP] New Member
    Terry
    Ohio
    2000 Tundra AC 4.7 4X4 SR5
    We are camping this weekend and I have to pull our 4500 lbs camper up a fairly steep gravel road. Should I use 4hi or 4lo?
    Metro14536 likes this.
  2. Aug 13, 2021 at 7:47 AM
    If you are going slow I would use 4Lo. I've found when crawling in 4HI our transmissions get really got.
  3. Aug 13, 2021 at 8:05 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Do you have a way to monitor your trans temp?
  4. Aug 13, 2021 at 8:12 AM
    Strangebird22
    Terry
    Ohio
    Yes I am using the torque app.
  5. Aug 13, 2021 at 8:14 AM
    Strangebird22
    Terry
    Ohio
    And I will definitely be going slow. No good way to pick up any speed before heading up the hill.
  6. Aug 13, 2021 at 8:21 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    I wouldn’t hesitate to use 4lo.
  7. Aug 13, 2021 at 8:26 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    If going slow is not an issue I would use 4 lo. If you do not use 4 low often I would cycle it a few times before your trip so you don’t end up finding out you have an issue with it engaging.
    Metro14536 and des2mtn like this.
  8. Aug 13, 2021 at 8:48 AM
    Strangebird22
    Terry
    Ohio
    Ok great will be going with the 4lo. Thanks for the advice everyone. Will let you know how it goes when I get home Sunday.
    NewImprovedRon and jimf909 like this.
  9. Aug 14, 2021 at 8:17 AM
    Strangebird22
    Terry
    Ohio
    You were right huntertn. Tried to engage the 4lo and no go. I push the 4lo button and it flashes and beeps a couple times and then goes back to 4hi. So it looks like I will have to drag it it hill in 4hi.
  10. Aug 14, 2021 at 8:24 AM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Sometimes my 02 will do that if I havent engaged 4 wheel drive in while. I just move forward and backwards a little bit until it locks into 4 lo. Also make sure your completely stopped when engaging 4 lo
    jimf909 likes this.
  11. Aug 14, 2021 at 9:25 AM
    lamboboy732
    lamboboy732 New Member
    Need to be stopped and in neutral to engage 4low
    w666, NewImprovedRon and Metro14536 like this.
  12. Aug 14, 2021 at 9:26 AM
    Strangebird22
    Terry
    Ohio
    Ok I did not know you had to be stopped to engage it. Will try that. Thanks
  13. Aug 14, 2021 at 9:28 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Unless it's 20 miles long and a 75 degree angle....you'll be fine in 4HI Tow Haul (if your gen has it).
    I've only used 4LO once, in deep snow in my driveway after it sat a weekend.
  14. Aug 14, 2021 at 10:27 AM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    Use 4Lo for low speed slogs up steep hills...
  15. Aug 14, 2021 at 11:00 AM
    I think I’ve used 4wd low only twice in 20 years. If I had a manual, I’d use it a lot more.
  16. Aug 14, 2021 at 11:32 AM
    Strangebird22
    Terry
    Ohio
    Awesome thanks for the help everyone. We are heading home tomorrow. Will chime back in and let you know how it went.
  17. Aug 14, 2021 at 11:43 AM
    jimf909
    Washington or Idaho
    Use lo going downhill to use engine braking.
  18. Aug 14, 2021 at 11:44 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    X2 ^^^ This is how I normally do it, I make sure that the 4H light is solid if not usually put it on reverse then it clicks, put it back to park push and turn the knob to 4L lights flashing then put it to neutral then the 4L light becomes solid.
    NewImprovedRon likes this.
  19. Aug 14, 2021 at 12:29 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    And just in case no one noticed, you can't go from 2hi directly to 4lo by design. 4hi must be fully engaged before the computer will allow the transition to 4lo. :thumbsup:
  20. Aug 14, 2021 at 2:37 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Sounds like you got it figured out. Let us know how it went?
  21. Aug 15, 2021 at 3:53 PM
    Strangebird22
    Terry
    Ohio
    Just want to check back in and say thanks to everyone for your advise. Thanks to you I was able to get into 4lo and she pulled the camper up that hill like a champ :benchpress:
    Thanks again to all!!!
  22. Aug 15, 2021 at 3:58 PM
    Ely010606
    SPARKS, NV
    Awesome that is good news.
