  1. Aug 12, 2021 at 11:59 AM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Tnx Bear. The 1st secret is the color. MGM is the best looking color, dont let anyone tell u otherwise lol. In all seriousness though I have an artic coating on mine. It definitely helps with keeping the truck clean.
  2. Aug 12, 2021 at 12:09 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    What did MGM mean?
  3. Aug 12, 2021 at 12:09 PM
    Brembo355
    Brembo355 New Member
    What wheel and tire set up did you go with on the bottom right picture?
  4. Aug 12, 2021 at 12:11 PM
    mgm16trdpro
    Northern NJ
    Magnetic grey metallic, basically grey.
    IsaiahCanada[QUOTED] likes this.
  5. Aug 12, 2021 at 12:24 PM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    Love the combination. The RAS really helped with load handling, sway, and overall ride. Makes the rear end feel planted and actually improved the ride. The Timbrens I got to really protect the RAS from hitting the frame on big dips and such. Also running the TRD rear sway bar, Coachbuilder +1 shackles, and King rear shocks
  6. Aug 12, 2021 at 12:40 PM
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    I'm not expert detailer, but have you tried a Magic Eraser or a clay bar yet?
  7. Aug 12, 2021 at 12:51 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Good call—not yet, I’ll have to pick up a new clay bar…should have a magic eraser around the house.
  8. Aug 12, 2021 at 1:02 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    Magic Erasers always scare me when they touch paint. Remember to be careful as they are abrasive. I would try a clay bar then a fine polishing compound, like M205. Always start with the least aggressive treatment, then work up from there.
  9. Aug 12, 2021 at 1:11 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Boring truck, nothing happens to it... Thousand miles over thousand miles. Gas every 400 miles, oil every 5000.
    (Tundra + fresh Pigs Ears)
    Oh, wait, for having fun I have the old Swede that barely leaves the garage for the past 2.5 years =)
  10. Aug 12, 2021 at 1:56 PM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Cool. Thanks. My only concern is losing off road performance as I go quite often.
  11. Aug 12, 2021 at 2:02 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Set up a sprinkler to spray water on it non-stop for a couple of hours. Get a dryer sheet (i.e. Bounce) and rub the left over bug guts. The combination of the hypermoisturization and the dryer sheet ought to get it out.
    Tundrastruck91 and oddhours like this.
  12. Aug 12, 2021 at 2:18 PM
    Tunka
    Tunka New Member
    So cal
    2018 sr5 crwmax
    2.5 leveling kit 30555r20 ko2 fuel assault wheels
    Cmx ceramic spray bird shit don't stick
    Do58 likes this.
  13. Aug 12, 2021 at 2:29 PM
    ohreary
    ohreary Party!
    2020 Platinum
    yeah, i had to go with 0 offset. I wanted +20, but i couldn't find a vendor that was motivated to order them for me. i think it will end up looking really great, it just meant that I had to do a CMC and worry about whether the tires will actually fit the truck. i'm still a little worried about it
    a_double[QUOTED] likes this.
  14. Aug 12, 2021 at 2:41 PM
    jackienguyener
    Jackie
    2016 Tundra 1794
    There’s a video on YouTube where a guy installed the RAS on an overlanding Tundra and kinda talks about how it affects articulation, just overall keeps the leaf springs from overextending
  15. Aug 12, 2021 at 2:58 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
  16. Aug 12, 2021 at 3:01 PM
    Rgross2112
    Rush
    Excellent! Thanks for the info, making my decision harder and harder o_O Feels like I’ve been reviewing a ton of covers, just need to get to the point and just order them. Much appreciated brother.
  17. Aug 12, 2021 at 3:22 PM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    I agree with what TBoe said. I have the MX4 and really like it. I get a little bit of water at the tailgate and the front of the bed in really heavy rain, but I also don’t have the drain tubes in. It’s not nearly enough water to cause any concern. If you can find a preferred dealer near you, you get a 10 year warranty instead of the regular 5.
    TBoe1776 and Rgross2112[QUOTED] like this.
  18. Aug 12, 2021 at 3:26 PM
    a_double
    a_double New Member
    It will definitely look good! Plenty of people run +0 with aggressive tires, but yea, chopping is necessary. In for pics! I always wanted a black vehicle with bronze wheels. :thumbsup:
    ohreary[QUOTED] likes this.
  19. Aug 12, 2021 at 3:44 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    I think you’ll be happy with any of the top 3 covers…I run the ArmorFlex by Undercover and like the top coating on it for being more scratch resistant; my buddy runs the F1, and it’s really nice too. I like that I can open and close my tailgate without needing to lift the last panel 1st, his F1 required him to lift the last panel, close the tailgate, then drop the panel…not a big deal, but small feature I like on mine more (his F1 is a couple years old now, so they may have changed this in newer ones?) I’d say whatever you can get the best pricing on, they all seem to fit really well. Haven’t seen many major complaints with any of the 3 (MX4, F1, or ArmorFlex)
  20. Aug 12, 2021 at 4:14 PM
    Rgross2112
    Rush
    Good to know! Thanks
  21. Aug 12, 2021 at 5:03 PM
    tundrasportinMA
    tundrasportinMA New Member
    Western Mass
    2019 Tundra Sport DC
    6112/5160 , SCS Ray 10's, Cooper Discover AT3 -295/70/18, Dirty Deeds 8inch, N-Fab Podium
    If you get a chance could you please post up some pics. Have been looking at these but haven't seen them on an MGM yet.
    Degausser[QUOTED] likes this.
  22. Aug 12, 2021 at 5:30 PM
    IMO I would choose a different tire. The BFG's are crap, they are stone magnets, and often don't balance well.
    woods likes this.
  23. Aug 12, 2021 at 5:37 PM
    BRM is the best color lol.
  24. Aug 12, 2021 at 5:44 PM
    CallsignKodiak
    CallsignKodiak New Member
    Bear
    Iiawah
    2021 CrewMax 4x4
    That shines up NICE.
    Tundra234[QUOTED] likes this.
  25. Aug 12, 2021 at 5:53 PM
    Degausser
    Degausser New Member
    Kevin
    GA
    2024 LR SR5
    Sure I'll take a couple for you tomorrow
  26. Aug 12, 2021 at 7:15 PM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    I’ve had Falkens on my 4Runner for a long time and now on my Tundra. I was thinking of getting KO2s for the Tundra, then read about all the balancing issues. Additionally, KO2s were the only tire Discount Tire recommended not getting in the size needed for our trucks. They said BF just can’t get them right in that size.
    equin and Tundra234[QUOTED] like this.
  27. Aug 12, 2021 at 7:29 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Westcott Designs had told me the same with BFG KO2s on Tundras as well when they installed my lift…said they do fine on 4Runners/Tacoma/FJs, but don’t run well on Tundras…balancing and wear issues…couldn’t say why specifically. Told me to stick with the Nittos I had or had been having good feedback with Toyo as well on our trucks
    romad86[QUOTED] likes this.
  28. Aug 12, 2021 at 7:43 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I had KO2 stock on my tundra and I bought it at ran for 54k miles with no issues rotated every 5k miles. I bought 325/60R20 (35.5/12.8R20) and ran them for 21k miles before trading them in with same exact results. Even had a screw get in one, got it fixed and still worked perfect. Brother ran 2 sets on his sequoia, dad on his tundra. Sister on her 4runner....no one had problems. I don't fully understand why SO MANY people have issues with them and/or hate them.
    NewImprovedRon, CoachJ and 1UP like this.
  29. Aug 12, 2021 at 7:59 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    it is after all the best color….looks really different depending on light
    291175F7-C85A-48D9-8CD8-8F66D0505B38.jpg E4508C6C-0503-4EEC-ADCA-7F6EE5887D32.jpg C4A5769C-B030-43D7-9CC1-D7F45D579713.jpg 5027FC4B-A8E0-49EE-B32E-8708D707E2A4.jpg
    GAknight, WFD473, TRDblvd and 15 others like this.
  30. Aug 12, 2021 at 9:39 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Not sure…they’re actually the tires I asked about putting on when I was going to increase to 35s…I liked the way they felt/handled/looked on my friend’s Raptor, even recommended them for my sister’s FJ. Thought they’d be a little softer with load rating on street. I was advised to go a different direction on the Tundra when I had the suspension done.
    I had no real reason to switch from my current 33” Ridge Grapplers; figured if the recommendation was to run same brand or sister company (Toyo) in 35s, then I’d stick with Nitto Ridge Grapplers given I liked how the 33s performed and held up. They didn’t say BFG KO2 weren’t good tires, just not a great match on the Tundra, specifically.
    Fotnot[QUOTED] likes this.
