Typical transmission temps?
Discussion in '2.5 Gen Tundras (2014-2021)' started by trails-end, Aug 2, 2021.
  1. Aug 9, 2021 at 12:57 PM
    #121
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Hmm.. would be interesting to get some data. I just got back from Montana/Idaho. On the way out there was towing a 7x14 enclosed trailer (Over 8' tall) in 100F, 12 hour days.
    Had the Tundra on S5 at 55-65 mph. Didn't use the cruise at all as I was very, very closely monitoring the RPMs and would let off the gas as soon as in S5 the torque converter unlocked (or I shifted to S4). First sign of an incline it went into S4. Got pretty tiring, but would be interesting to be able to monitor the temps.
    On the way back, others drove the Tundra and I pulled the trailer with a 2500HD (still in 100F temps, S6 with cruise on at 72 mph.). Transmission temp never broke 200F. Sat between 185F and 190F mostly. I did kick it down into S5 on the hills/mpuntains right away as that was only 300 rpm higher than S6. I suppose the trans temps may have gone higher if I continuously left if in S6 going up.
  2. Aug 9, 2021 at 1:02 PM
    #122
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I suppose the way I drive may effect the temps. I'm usually pulling a 7x16 enclosed that might weight 4500-5k and I stay around 80mph. Unless I feel it's winding too high too long, then I'll slow down a bit. Like 75.
    Henry1jg and Sundog like this.
  3. Aug 9, 2021 at 1:04 PM
    #123
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    You've got to be absolutely taking it in the shorts on mileage at 80 mph. I was trying to maintain a 9-10 mpg at 55-65 (North Dakota, Montana, Idaho).
    Cpl_Punishment likes this.
  4. Aug 9, 2021 at 1:13 PM
    #124
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    I've never heard that, but after looking it up, ya single digits mpg. But overall for the trip it's usually around 10-11.
  5. Aug 9, 2021 at 1:21 PM
    #125
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    How long are these trips usually? Long trips like that I think would push the trans temp very high
    Oey12 likes this.
  6. Aug 9, 2021 at 1:23 PM
    #126
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Only like 40-45 miles at the higher speeds.
    Clemsonman14 likes this.
  7. Aug 9, 2021 at 2:04 PM
    #127
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Ex-squeeze me? No no no no no...
    Foist you must establish a preconceived outcome. THEN you venture forth in search data points that support your outcome whilst rejecting data that diametrically opposes your desired result.
    THAT... is science.
  8. Aug 11, 2021 at 4:27 PM
    #128
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    From what I understand reading threads on this forum, the following are expected, normal transmission operating temps;
    Pre-2019
    -Cool as a cucumber. Always, no matter the situation.
    2019+
    -Unloaded at 70 mph = HOT!
    -Truck full of family and camping gear = if a RAM transmission ever got this hot it would melt
    -Pulling a trailer/heavy loads = Satan himself says "Damn, that's TOO HOT!!", but Toyota says it's just fine
  9. Aug 11, 2021 at 4:39 PM
    #129
    Vizsla
    Vizsla 2 = 2.5
    Plot twist… 2018 got the new improved refrigerant for the air conditioning system, but not the bigger condenser to accommodate. Users have reported poor air conditioner performance and higher transmission temps with the oem cooler. Lol.
  10. Aug 11, 2021 at 4:44 PM
    #130
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    My 2015 does not seem to run cool as a Cucumber.
  11. Aug 11, 2021 at 4:53 PM
    #131
    Jernik
    Jernik New Member
    Jeremy
    :annoyed:You guys and your facts! :rofl:
    hagrid, Cpl_Punishment and Oey12 like this.
  12. Aug 11, 2021 at 5:58 PM
    #132
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Yes, this! I have seen 230 in below freezing weather. Toyota knows what they are doing, do the guys that are running their transmission cooler than designed for know how to build a bullett proof 6spd?
  13. Aug 11, 2021 at 6:36 PM
    #133
    Vizsla
    Vizsla 2 = 2.5
    Maybe, but probably?:notsure:
  14. Aug 11, 2021 at 6:58 PM
    #134
    Vizsla
    Vizsla 2 = 2.5
    No offense, but your science is dumb. If you don’t have a transmission cooler obviously you need it, if you have one need another. More better!
  15. Aug 11, 2021 at 7:14 PM
    #135
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I am going to get five, to match my vaccine count.
    hagrid likes this.
  16. Aug 11, 2021 at 8:04 PM
    #136
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Source? Not saying you're wrong. I'd just like to read about it. And the complaints.
    I've got the new refrigerant, the bigger condenser, and a small ext trans cooler that sits in front of the upper passenger side corner of the AC condenser. Are you suggesting those of us with 2019+ Tundras who have added a cooler might see problems with the AC? I haven't seen any issues, and I'm not sure that the trans cooler blocks the radiator in a detrimental way, especially considering those big plastic air dams on the sides that draw more air into the AC condenser.
    My understanding is that, since the OEM thermostat doesn't even open till ~190ºF, this transmission has always run hot compared to other manufacturers. For example, I've had a few GM trucks ranging from 2002 to 2012, and those transmissions always ran between 120ºF and 165ºF.
    Putting an ext cooler on a 2019+ is not running it colder than designed because it's the same transmission that was designed with and came with the ext cooler for years. I'm not running mine any colder than the way the transmission was originally intended by Toyota. The ext cooler is thermostatically controlled to open at ~190ºF. It's not even a factor until then. Transmission pan stays between 190ºF and 200ºF when I'm not towing, like it ostensibly did for several years.
    Henry1jg and k0diak8o8 like this.
  17. Aug 11, 2021 at 8:24 PM
    #137
    Vizsla
    Vizsla 2 = 2.5
    Only answering my quote. I have a 2018. I get to compare temps and stuff in extreme heat(desert) conditions with other various year Tundras. All my friends have LT Tundras and we do stuff… 07-10ish run cooler trans temps, but the calibration reflects that. 2018 Tundra got screwed on AC performance.
  18. Aug 11, 2021 at 8:33 PM
    #138
    Terndrerrr
    Music City
    6UR-FE
    Bummer. Mine won't get ice cold until I start driving. But then it's fine.
  19. Aug 11, 2021 at 8:37 PM
    #139
    Vizsla
    Vizsla 2 = 2.5
    And let me save you the trouble from quoting the anonymous Toyota engineer ever again. That was a personal opinion from an engineer that works for Toyota, that has nothing to do with how or why the transmission cooler exists or not. I know a few, mixed bag. Lol.
  20. Aug 11, 2021 at 9:33 PM
    #140
    Terndrerrr
    Music City
    6UR-FE
    Yeah, in a previous career, I worked alongside many engineers. I get it. But I disagree that this is a personal opinion. COTJ said this engineer “deals with this directly”, so it’s not just some random Toyota employee with an engineering degree giving an opinion on an issue that is totally unrelated to what Toyota pays them to do. I consider it a highly informed professional opinion. Much more highly informed than any of us anyway. What I want to know about are the heat defects mentioned.
    Dealing with it directly is why their words carry so much weight for me and why I don’t think it makes sense for so many people on here to dismiss it out of hand.
  21. Aug 11, 2021 at 9:57 PM
    #141
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Its been over two years since the change, show me the data that proves they are somehow failing, and the dealerships that are full of burnt out Trans. I'll wait.
  22. Aug 12, 2021 at 3:20 AM
    #142
    Bammer
    Monroe, CT
    Show us the data that they are just as healthy as a pre 2019... This can go on for ever, put a cooler on if you feel the need, don't if you don't !
    The pissing match back and forth is really getting old..
  23. Aug 12, 2021 at 3:59 AM
    #143
    blanchard7684
    blanchard7684 New Member
    I disagree with other engineers and managers who think they are engineers on an hourly basis. Confirmation bias is a bitch even with the best data and information at hand.
    Case in point that shows even my own struggle with it.
    Had a compression train at work that shutdown and was acting very bizarre. Pids flying all over the place. One was speed. Its a turbine driven compressor.
    We also knew there was a valve hang up that would have allowed the unit to reverse spin. To make matters worse the system was indicating zero oil pressure while spinning backwards up to 24000 rpm with second critical speed at 20000 rpm. In other words a big effing deal.
    I'm looking at all the trends. my reaction was "zomg tear everything apart now. its a blood bath."
    (The contractor mechanics loved me...all the OT...wow)
    An operator and an automation specialist found a faulty speed probe. They found the real issue while I was in a panic.
    At any moment in this debacle, I was the engineer with one set of data and a theory on what had occurred. The Automation specialist and operator were actually at the unit when it failed and was getting a totally different set of data that indicated no backspin.
    My own confirmation bias made me disregard other sources of information.
  24. Aug 12, 2021 at 6:03 AM
    #144
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    I have a 2021 with a self installed external transmission cooler magnetic grey metallic black interior. I live in one of the most hot miserable humid climates Houston. I can attest I have ZERO AC cooling issues. I am very pleased with the AC performance even when 98f and 80% humidity. The trans cooler didn't affect AC performance in my opinion. It blows a solid 43F all the time. Wife 2017 4Runner blows 48F. My 2017 diesel 44F, my 2001 lexus gs 300 36F (variable displacement compressor) P
    On a side note premium vehicles do have some better parts. My Lexus upper control arms have spherical bearings, not rubber bushings, will last a lifetime or two. AC compressor variable displacement, clutch never cycles on and off. Its nice vs hearing my other cycle on and off at lights etc.
    Bammer and Terndrerrr like this.
  25. Aug 12, 2021 at 6:16 AM
    #145
    Terndrerrr
    Music City
    6UR-FE
    I’ve always said it’s not likely to be an issue within warranty period, especially considering how many people just commute in their trucks. I put one on because of how I use my truck. If I remember correctly, you got pretty heated with a guy who came in here and showed his service ticket with a burned up transmission on his 2020. He was towing 3k lbs 5 days per week.
    Agreed. We have so few issues to discuss that we go round and round on the few that people have strong opinions about. Add a cooler, or don’t. :notsure:
    Bammer[QUOTED] likes this.
  26. Aug 12, 2021 at 7:21 AM
    #146
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    Curious if you tow with your Tundra and if you do, what kind of transmission fluid temperatures you see. Also your temps while not towing. Do you have a comparison of temps before and after? TIA!
    (FYI I also have a GS. HUGE fan of those cars. I've had several)
  27. Nov 11, 2021 at 12:32 PM
    #147
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    Did you purchase the kit or put the trans cooler system together yourself?
    My 2021 trans temps hit touched 210 F with a very light load, full tank, no trailer, and one passenger when climbing fairly steep grades through a short local pass during cool ambient temps 39 F several days ago. It seem to drop back into the mid 190's fairly quickly. Next time out I'll be taking screen shots and recording conditions better for comparison.
    Truck hasn't had it's 1st oil change btw.
  28. Nov 11, 2021 at 1:11 PM
    #148
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    Some late 2018 trucks have R1234YF refrigerant with the smaller condenser that had the ATF cooler built into the condenser. These see reduced AC performance as R1234YF is less efficient and you have hot ATF flowing through part of the condenser as well. This results in more heat transfer in the condenser making it harder to cool the refrigerant.
    What you have on your truck is a larger condenser that is just for the AC. The ATF cooler you added is separate, therefore you do not get as much heat transfer within the condenser itself. The idea of blocking air flow doesn't matter too much. If you look at the radiator and the condenser from the factory, a large portion of the surface area is behind the bumper and supports. When driving, the area in front of the radiator is high pressure due to air being crammed into the grill, behind the grill is low pressure. This differential pressure causes air to move through the condenser and radiator, extracting heat in the process. By adding an ATF cooler in front of them, all you are doing is very slightly raising the temperature of the air before it flows through the condenser and radiator. As you and others have noted, there doesn't seem to be any change in AC performance due to this in the majority of operating conditions.
    Since this thread is about trans temps.
    2020 Platinum 4x4
    Unloaded, other than driver and fuel (GVW ~6440)
    Stock:
    cruising on the highway at 80-85 in D, ambient temps from 60-90F on multiple drives
    Pan temps 215F-222F
    Setrab 920 cooler installed (I made my own kit):
    Pan temps 195F-199F
    I only recently started viewing TC temps. Anytime they exceed 210F, the thermostat seems to open and the pan temps being dripping fast. I have not done enough towing to have meaningful data.
  29. Nov 11, 2021 at 1:16 PM
    #149
    JDR76
    JDR76 New Member
    WA
    Had the truck and trailer out the other day. Ambient about 50 degrees. Drove for an hour on the freeway, averaging 65 mph. Travel trailer was at about 4k lbs and just me in the truck, so not overly loaded. I drove in T/H and D and peaked at 217 degrees.
    2WD likes this.
  30. Nov 11, 2021 at 1:30 PM
    #150
    Terndrerrr
    Music City
    6UR-FE
    I bought the partial kit from @chasenicholas93, which included the cooler, mounting bracket, horn relocate bracket, hoses, and connects. I bought the OEM Toyota parts separately (the thermostat, hard lines, and the hoses that ran between them.
