  1. Aug 11, 2021 at 5:50 AM
    That's what I felt last year. PHM seemed to think it was a fuel pump issue after coming down from the mountains and had me hit my tank a few times. Here is the video I took when my truck was struggling to start that day. It sounded much worse in person.
    https://www.youtube.com/watch?v=GdbgK1Zu0Fw&feature=emb_title
    Thrussn[QUOTED] likes this.
  2. Aug 11, 2021 at 11:20 AM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    is that K&n one you have not the carb legal one?
  3. Aug 11, 2021 at 11:29 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
  4. Aug 11, 2021 at 11:45 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I think both are not carb legal but I never had paperwork for the Airaid.
    If I can find a good dry filter to fit the K&N I will run that again during the Winter months. The K&N sounds super aggressive and did give me a bump in fuel economy. Only part I don't care for is the K&N filter, they're full of big holes.
  5. Aug 11, 2021 at 11:50 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Hahaha............. free Heather............classic
    you VRP yer methods too? wheels look great
    bmf4069 and Glock 40[QUOTED] like this.
  6. Aug 11, 2021 at 12:14 PM
    jImmegart
    Jonah
    California
    would it not fit the stock airbox? also, wouldnt any dry filter with the same diameter fit the piping?
    Also this K&N one is carb legal
    77-9020KP K&N
  7. Aug 11, 2021 at 12:20 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I did. We'll see how long it lasts.
    RUSTYNUTS[QUOTED] likes this.
  8. Aug 11, 2021 at 12:21 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The piping is an oddball size on the K&N.
    The airaid tube and the K&N fipk kit (extinct now I believe) both use the stock airbox and an aftermarket filter. They were identical in design except K&N used a cool pyramid shaped filter for more surface area. I don't think that K&N was carb legal either.
    There were three different K&N kits: the fipk, the black tube with cone filter, and the metal tube with cone filter. I have the black tube one of course.
    RUSTYNUTS likes this.
  9. Aug 11, 2021 at 12:29 PM
    jImmegart
    Jonah
    California
    These airaid kits are carb legal, not sure I want to get rid of the stock airbox though. But getting rid of the stock pipe with that big box seems nice. I also dont really want to replace the whole box and pipe if I had to switch it out to smog, but if it was just a pipe it would be less of a hassle.
  10. Aug 11, 2021 at 12:34 PM
    Those wheels look great. Are you saying that the Chemical Guys VRP is what made them look so good? I may have to try that.
    RUSTYNUTS and Glock 40[QUOTED] like this.
  11. Aug 11, 2021 at 12:35 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Yeah, that's all I used today. I buffed with microfiber after putting it on.
    RUSTYNUTS and FirstGenVol like this.
  12. Aug 11, 2021 at 12:36 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Anyone want pics of plugging baffles or resonators on an ‘02 q45. When i get the plastic and radiator out of the way, ill see if i can cobble some proper ram air. And dad would be tickled if i had a plastic coffee can that could take dry ice and cool an aluminum chunk of pipe, with the iat sensor in it. Enriches the mixture to compensate for an intake pressure signal, and loud pipes. Cause i bet a ck45de will sing with loud pipes. Maybe not as flamboyant as a g35, but enough to take his bosses amg to task.
  13. Aug 11, 2021 at 12:47 PM
    A Skoal can lid was a perfect fit to eliminate the intake resonator on a mid 90's Chevrolet Vortec V8.
    TRDGen, NUDRAT, bmf4069 and 1 other person like this.
  14. Aug 11, 2021 at 12:49 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Child proof tylonol or ibuprofen lid with the warnings sanded off for my 5vz 4runner, and i think the center cup of a spray paint lid, but its been a while.
    oscardog86, TRDGen and KNABORES like this.
  15. Aug 11, 2021 at 9:58 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    The 05 & 06 vvti motors use a different airbox than the earlier 00-04 models.
    On those you can retrofit a rubber velocity stack that TRD calls an 'air accelerator', which they include in their CAI kits. (Which is nothing more than an oiled air filter, a rubber velocity stack, filter minder, sometimes a smoother intake tube and/or fancy airbox lid, depending on model.)
    The scalloped area is faced towards the fender liner.
    Need to remove some of the rubber from the base of the TRD velocity stack.
    Requires trimming the part that sticks into the fender (more than pictured below, just left 1/8" or so lip past the flare/bulge after removing the foam).
  16. Aug 11, 2021 at 10:00 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Would any of the AFE filters fit? If not maybe AEM?
  17. Aug 11, 2021 at 10:01 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Air box looks the same to me
  18. Aug 11, 2021 at 10:07 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Anyone selling the lower half of the air box for a 05-06 or have an extra?
  19. Aug 11, 2021 at 10:08 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Negative ghost rider.
    00-04:
    05 & 06:
    Voss, des2mtn and TRDGen[QUOTED] like this.
  20. Aug 11, 2021 at 10:11 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Swapped out tires. In my driveway. No tire machine. Anybody else do dumb shit like this? If it’s been awhile, I totally forget what a bitch it is. Every frikkin time. I’ve been runnin 35/12.5/17’s for awhile now, and even with all the cutting and pounding I’ve done, I still make contact. Been lookin at smaller tires and came across a used set of 34/10.5/17’s. Yes used but in great shape for cheap, so I can see if the size is ideal before spending the money on a new set. Haven’t really checked for clearance yet, but it’s amazing how much smaller a 34 looks than a 35. Probably has a bit to do with them being 2” more narrow as well tho.
  21. Aug 11, 2021 at 11:31 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    Keep us posted. I'm still waiting on my 4crawler 1 inch body lift. I'm wanting 35s and 17s for 2022 but may have to settle for 34s and 17s. Time will tell. I feel like I could fit a skinny 34 now since Ive already got ~33.5x11.5 inch tires
  22. Aug 12, 2021 at 6:26 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    My buddy went from 35x12.5 to 34x10.5 and he was mad about how small they looked. I think thats a perfect size for these trucks if you have the right wheels. Post some pics when you can.
    oscardog86 likes this.
  23. Aug 12, 2021 at 8:33 AM
    daveeasa
    My truck (and the wife) returned from the airport last night, yay.
    I’m hoping to order up brakes today. Anyone willing to assist me with that via DM? Also going to order up a RedArc but I know that well from the Tacoma.
    Spent some time pondering bumpers last night and stuck on that so putting it aside for a while.
    Also, I have a question on shell mounting which I can post in a shell specific thread but thought worth asking here. I had an ARE shell bolted through the rails. Looks like the Leer which is on it now is secured with clamps. The rail holes don’t align exactly with the Leer bulges. Anyone know if it’s safe to drill and bolt the Leer on?
    0B6B895D-6C0E-420B-A81B-30FD0F539E23.jpg 2243DB93-892E-43FB-960D-9F141269F887.jpg
  24. Aug 12, 2021 at 9:33 AM
    Been using Seafoam since forever. In the crankcase 100-150mi before each oil change. In the gas tank. In the intake. I've even used it in transmissions, per their instructions. Anywhere there's typically carbon deposits and some kind of petroleum product goes, you can use it, it's essentially just a highly-refined petroleum product.
    That said, how you apply it and how much (or rate added) is important. SeaFoam DOES NOT RECOMMEND applying their product using vacuum lines for this reason and reiterated with some extra points here. While I doubt you'll hydrolock as suggested, one guy on a hot rod forum tried telling me he hydrolocked his engine applying direct to the cylinders.
    I know ppl who've used vacuum lines religiously, but they make a spray can with straw kit that lets you hook it in typically at the intake/MAF/TB of most engines and dump what SeaFoam feels is a perfectly metered proportion to your intake.
    SeaFoam has videos and guides at YouTube and their website instructing the proper method for various cleanings, although it's generic, it's supposedly universal. The above definitely isn't me saying, "Oh yeah, totally wasn't a product issue, SeaFoam doesn't kill engines!"
    If that jackass on the LS1Tech forums was accurate and not just talking out his ass because he wants to hate on the product, I think he's an idiot. Never dump more than a teaspoon or two of fluids in a cylinder (Marvel's Mystery oil, to free up cylinders for example), and avoid submerging or pouring in liquids via vacuum lines.
    I also think water bath may've played a role but not sure where all you sprayed, in the engine bay, whatever.
    oscardog86 and FrenchToasty like this.
  25. Aug 12, 2021 at 9:35 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I've tried to dismount a car tire exactly once. I gave up after an hour of trying to break the bead and left it to the tire shop.
  26. Aug 12, 2021 at 10:40 AM
    I had to blow the carbon out of the motor last night. In Mexico, of course.
    Dantdodge, TRDGen, Voss and 7 others like this.
  27. Aug 12, 2021 at 10:42 AM
    You should have pinned it to 110!
    One or two handed pic at 100 with knee holding wheel? :eek2:
  28. Aug 12, 2021 at 10:57 AM
    No sir, I was 100% safety and had both hands on the wheel. Both.
    Darkness likes this.
  29. Aug 12, 2021 at 11:01 AM
    So how or who took the pic?
  30. Aug 12, 2021 at 11:01 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    "The Edge... there is no honest way to explain it because the only people who really know where it is are the ones who have gone over."
    -Hunter S Thompson
    I found the edge at 107 in San Felipe on stock tires. I did not have a dedicated photographer to document it unfortunately.
