No CEL on the instrument panel?
Discussion in '1st Gen Tundras (2000-2006)' started by Crickle, Aug 11, 2021.
  1. Aug 11, 2021 at 1:18 AM
    Crickle
    Crickle [OP] New Member
    2001 White/Red Tundra Base model, bench seat...
    I cannot find a check engine light on my 2001 base/standard cab.
    This is the one without a tach, etc.
    What am I missing?
  2. Aug 11, 2021 at 1:41 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I can't even seem to find a picture of a cluster with no tach on a tundra only a Tacoma. If you have a pic please share.
    Chances are its burned out from being on for a long time. May need the bulb replaced. Do you have codes showing up when using an OBD scanner?
    Crickle[QUOTED][OP] likes this.
  3. Aug 11, 2021 at 5:55 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    bmf4069, Crickle[OP] and FrenchToasty like this.
  4. Aug 11, 2021 at 12:22 PM
    Crickle
    I've had the cluster apart to clean it, and I guess I don't know what the symbol looks like.
    I'll take it apart again.
    No codes from my reader...
  5. Aug 11, 2021 at 12:28 PM
    w666
    Maryland
    That info is on the following page...oddly labeled "Malfunction Indicator lamp" instead of the more common "Check Engine light" (CEL)
  6. Aug 11, 2021 at 12:29 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    It says “CHECK” and has engine symbol. When I was switching to LED way back when and had the cluster out, I took the bulb out and put flashlight over hole, you can see symbol/words on other side shining thru
  7. Aug 12, 2021 at 11:42 PM
    Crickle
    Thanks for the info, everybody.
    If I am understanding this correctly, when you turn the ignition to "on", and the dash lights go through their bulb check...the CEL does NOT light up?
    That doesn't sound right, as that is an important bulb...
  8. Aug 12, 2021 at 11:50 PM
    NickB_01TRD
    KY
    It definitely should light up. It should stay lit up until you start your engine. Seems like most likely your bulb is blown. Or loose connection at socket or somewhere else. I have hit the top of the dashboard and had a check engine light bulb start working again on a tundra.
  9. Aug 13, 2021 at 12:09 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    It’s not uncommon for propel to remove the bulb on the check engine light if they’re selling a car with a problem, or if the lights been on long enough, the bulb can be blown.
  10. Aug 13, 2021 at 2:36 AM
    w666
    Maryland
    No, sorry...I guess sarcasm doesn't translate well in text. I meant it like "duh...it's the one that's burned out".
  11. Aug 13, 2021 at 4:52 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The CEL/MIL should illuminate when the key is rotated to the RUN position before starting the engine as a means for checking the lamp functionality.
