  1. Aug 10, 2021 at 5:30 PM
    Dew eeeeeeeeeet
    Voss and TRDGen like this.
  2. Aug 10, 2021 at 5:49 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Haha its been getting little love here and there, Only came off the road because I got the Tundra so I could put love into it. 4 years later.....
    Committed to having it back out on the road this winter. All it needs is the rear cage and such painted and then plumb new fuel.cell, everything is sitting in the garage. Even Monstalined the Fuel Safe Cell when i did the Tundra for good measure.
  3. Aug 10, 2021 at 5:56 PM
    daveeasa
    You already burned $300 of money I don't have on an alternator yesterday.
    I assume that's worth doing with the water pump and serp belt + tensioner since it won't be significant extra work if I do the big 3 ahead of time and maybe the de-pin and re-pin on site.
    Not sure what the lifetime of an alternator is but I'm guessing it got some good use over 160k miles and 20 years? Especially with the reported parasitic draw and 4 nuked batteries in the past few years.
    Darkness likes this.
  4. Aug 10, 2021 at 7:11 PM
    Started tacking together pieces for the compressor mount. It’s pretty tight pulling out but should fit fine
    CD54F0E7-046C-4959-B9F6-4AD5934B0E6C.jpg 81DFDC13-B57F-4973-9EAA-EBCB0B6343A2.jpg
    oscardog86, Voss, des2mtn and 4 others like this.
  5. Aug 10, 2021 at 7:22 PM
    My driver's side belt has been driving me nuts lately. Has a lot of click-click-click in it with minor body movements, like you can hear the bearings in the mechanism - at least until you pivot the arm to a 4 o'clock position instead of the 5 o'clock position it stays in.
    Have you or anyone else noticed the same? I feel like if I could just figure out wtf was making the noise, I could re-lube to stop it from happening. but I also dread tampering with safety equipment!
  6. Aug 10, 2021 at 7:42 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Cant say i have had that issue
  7. Aug 10, 2021 at 8:58 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    How did you go about pressure washing the seatbelt? Did you remove it or just hang it out of the door as much as you could and close it in the door? Hoping to clean mine up and spray it with silicone lubricant as per PHM.
    oscardog86, FrenchToasty and Thrussn like this.
  8. Aug 10, 2021 at 9:05 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    Experienced a gremlin the other day.
    I washed the truck, rinsed off the cold engine the night before last, filled the tank, and even cleaned my aem filter. When I went to fire it up the following morning, it would start and then immediately die. I tried this a couple times with my reader hooked up but it wouldn't throw any codes. I could keep it running with the pedal but it was breaking up and very pissed.
    I unhooked the battery and let it bake in the sun for the day. When I got back to it, it started rough and did the same thing once again. I held the engine at about 2k rpm and the breaking up and stumbling cleared up after about 20 seconds. It's been running great after that.
    I put half a can of seafoam into the brake booster vacuum line and a can and a half into my full gas tank.
    I have no idea what the issue was so I wanted to share it here for an additional thought/opinion. I'm assuming it was because of water that I sprayed into the engine bay, but the lack of codes that were thrown make me unsure. Is it possible the issue was on the fuel delivery side and unrelated to the water?
  9. Aug 10, 2021 at 9:31 PM
  10. Aug 10, 2021 at 9:36 PM
    I knew one of you would like that!
    But seriously I couldn’t get it out!
    I’ll have to radius the tab by harness and after that it should clear easier.
    bmf4069[QUOTED] and Darkness like this.
  11. Aug 10, 2021 at 10:01 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    He did say he would take $500, but that was still too high as I would have to paint it black and get the lower metal piece that pre-facelifts have
  12. Aug 10, 2021 at 10:03 PM
    jImmegart
    Jonah
    California
    He sent me a picture of his old truck once but I seem to have lost it. It was a white, pre-facelift tundra. It had a coastal offroad front bumper if I remember correctly.
  13. Aug 10, 2021 at 10:05 PM
    jImmegart
    Jonah
    California
    I need someone to remake the T3 tundra grill :D.
    I wonder how easy that would be to do tho? I know the ivan stewart grille part pops out, so maybe scanning the shell and 3d printing wouldnt be too hard.
    FirstGenVol and TRDGen like this.
  14. Aug 10, 2021 at 10:05 PM
    empty_lord
    05 rollover special
    unbolted the bottom and the top. left the rest in. pulled it all the way out, closed the door and just went ham with the pressure washer and the belt on the (CLEAN) floor
  15. Aug 10, 2021 at 10:06 PM
    empty_lord
    05 rollover special
    you can convince some chinese company to make the surround for cheap and then its just the insert thats metal.
    jImmegart[QUOTED] likes this.
  16. Aug 10, 2021 at 10:06 PM
    jImmegart
    Jonah
    California
    ah, is that what that bump is? I'm assuming they don't really sell just the pipe anymore right? just the whole cold air?
  17. Aug 10, 2021 at 10:06 PM
    empty_lord
    05 rollover special
    no more just pipe from what im told. the cheapest way to get it currently is through etrailer but i cant imagine they have many.. mine should be here on the 12th
  18. Aug 10, 2021 at 10:07 PM
    jImmegart
    Jonah
    California
    He did say he would for $500 ;D
  19. Aug 10, 2021 at 10:09 PM
    jImmegart
    Jonah
    California
    ah this one ?
  20. Aug 10, 2021 at 10:09 PM
    empty_lord
    05 rollover special
    05-06 is the one not in production. the 00-04 are still available
    i paid 250 for the whole intake. sooo i dont feel too cheated since i wouldnt of used the filter in the mit kit
  21. Aug 10, 2021 at 10:12 PM
    jImmegart
    Jonah
    California
    Oh ok. Its weird that just the pipe is not legal in california, but the whole cold air is? I guess its just a matter of if they get them carb certified or not.
  22. Aug 10, 2021 at 10:13 PM
    empty_lord
    05 rollover special
    the fact a tube that literally doesnt touch the air box isnt legal to use...
    i dont know how yall survive
  23. Aug 10, 2021 at 10:17 PM
    jImmegart
    Jonah
    California
    Ya, I mean the smog shack I go to doesn't even open my hood. With how stock that pipe looks, I am sure I could get away with it.
    Ever look at these? https://hpsperformanceproducts.com/...tundra-4-7l-v8-827-523?variant=32478052614241
    Or are you trying to keep the stock airbox?
    Also, are the maf positions different from 00-04 to 05-06?
    oscardog86 likes this.
  24. Aug 10, 2021 at 10:45 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you want one let me know. I have one sitting in my garage but it won't fit @empty_lord with his fancy vvti motor.
    My smog guy can be picky.
  25. Aug 10, 2021 at 11:06 PM
    empty_lord
    05 rollover special
    larger throttle on 05-06. i dont like CAI kits. the stock box has much cooler IAT
  26. Aug 10, 2021 at 11:16 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    You should do the TRD velocity stack too.
  27. Aug 10, 2021 at 11:20 PM
    empty_lord
    05 rollover special
    Very well may, but later when I’m doing the wiring clean up.
  28. Aug 11, 2021 at 2:05 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Huh?
  29. Aug 11, 2021 at 5:01 AM
    My truck did something similar last year after I put a few ounces of Seafoam in the crankcase. I was assured that couldn't be the cause. The difference is that my truck wouldn't turn over. It would sputter and struggle but not start. Took me about 3-4 minutes before it finally rolled over. It's never done anything like that before or after.
    oscardog86 and Thrussn[QUOTED] like this.
  30. Aug 11, 2021 at 5:19 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    On an OH truck - that was fun!
