2014 CM SR5 - "panel" fuse blowing, no HVAC control lights, stereo not dimming
Discussion in '2.5 Gen Tundras (2014-2021)' started by swallace, Aug 16, 2020.
  1. Aug 16, 2020 at 12:21 PM
    swallace
    swallace [OP] Insert profound statement —> here <—
    Steven
    Tri-Cities, WA
    2014 Silver Sky Metallic CM 4.6L 4x4
    6112/5160, DD 10”, Amp steps, Alea leather, more…
    Hi all - I want to start by saying how great this forum is! Got my tundra about a month and have been learning a lot through these threads.
    2014 SR5 Crewmax. I noticed first that my stereo wasn't dimming when I turned my headlights on and didn't think anything of it. I thought maybe this was a feature the truck didn't have. Then I realized the lights for the HVAC knobs and all switches, etc. didn't come on with the headlights. Again, thought it was a missing feature. This weekend, I installed the AJT Design blackout kit and saw a bunch of LEDs and diffusers behind the HVAC controls and realized something wasn't working.
    After some tundras.com digging, I thought maybe the problem was the day/night mode setting in the head unit. I was unable to access the setting no matter what I did (parking brake on/off, etc.). I also tried to rotate the odometer reset knob on the instrument cluster. It changes the brightness of the instrument cluster (when the headlights are on), but nothing else in the cab. The parking brake light turns on in the instrument cluster when the parking break engages, so I know that the parking brake engagement signal is working.
    I tested every single fuse in the interior fuse panel and one fuse was blown, a 7.5amp fuse labeled "panel". I replaced the fuse and it immediately blew again. I assume related to my problems.
    Note that all of the electrical in the truck is original except for an aftermarket trailer brake controller that was professionally installed. I found one thread that said someone was having a similar problem with an aftermarket trailer brake controller, but it didn't help me troubleshoot. I pulled apart the dash and looked where the trailer brake was installed, and it seems pretty straight forward, I don't see how it would relate to my problems. And the trialer brake is working correctly.
    All that said, my questions are as follows:
    1) At the risk of asking the obvious, it is a safe assumption that whatever is causing the blown "panel" fuse is causing my HVAC control panel lights to not work when I turn on my headlights?
    2) How would I determine what is causing the fuse to blow?
    3) At what point do I need to get professional help diagnosing this, and where should I go? Dealer, car stereo installer, etc. If I do bring this in to get worked on, any idea how much $$ for something like this?
    Thanks in advance!
    Steven
  2. Aug 16, 2020 at 1:05 PM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Did you buy it from a Toyota dealer?
  3. Aug 16, 2020 at 1:07 PM
    swallace
    Steven
    Tri-Cities, WA
    No, private party.
  4. Aug 16, 2020 at 1:10 PM
    What happens if u disconnect the aftermarket brake controller and put a new fuse in?
  5. Aug 16, 2020 at 4:01 PM
    swallace
    Steven
    Tri-Cities, WA
    I removed the brake controller, fuse blown. Out of curiosity, I disconnected the HVAC controls AND the head unit AND the brake controller all at the same time...fuse blown immediately when I turned the headlights on.
  6. Aug 16, 2020 at 4:16 PM
    Have you checked the wiring for the headlights?
  7. Aug 16, 2020 at 4:20 PM
    swallace
    Steven
    Tri-Cities, WA
    I've got 2019 pro headlights and iHacker harness in the garage. So I will be working on them soon.
    This is a bit new to me. What/how would I check the headlights here?
  8. Aug 16, 2020 at 4:28 PM
    CaptainGrumpus
    Maine
    Maybe remove the headlights from the equation?
  9. Aug 16, 2020 at 4:58 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    On my truck the “panel” fuse is a 5 amp. Are you sure it’s the panel fuse?
  10. Aug 16, 2020 at 5:41 PM
    swallace
    Steven
    Tri-Cities, WA
    It's definitely the "panel" fuse. And the fuse box cover has it labeled as 7.5 amp, which was also the fuse size that I pulled out.
    I will remove the headlights from the equation and post the result. Probably will just do it when I install the PRO headlights.
  11. Aug 16, 2020 at 6:54 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Reason I asked was because I had a similar issue. My AC panel crapped out on me while I was in the Grand Canyon. I have the dual climate with the digital temperatures. The numbers shut off and the AC stopped blowing. If your AC still works it may be because yours is probably the analog climate control? Anyways, turned out that I had a chafed wire that was shorting it. As soon as I got off-road, the bumps would make the chafed wire rub against the metal body panel and pop the fuse. But it wasn’t the panel fuse. Can’t remember exactly which fuse but it was one of the 10amps. The wire was one of the wires in the bundle of wires going from the engine fuse box into the driver’s side firewall grommet. The Toyota tech spent about 3 hours checking and unplugging everything that was on that wire harness. When that didn’t work, he started looking for a bad wire and got lucky when he noticed the fuse kept popping when he wiggled that wire bundle. Might be worth taking a look at that wire bundle.
  12. Aug 16, 2020 at 7:00 PM
    swallace
    Steven
    Tri-Cities, WA
    @joonbug You are correct that my AC still works and I have the analog climate control. As best as I can tell, everything works on the truck as expected except what I mentioned above.
    Thanks for the suggestion on where I can look next. I really appreciate it.
    joonbug likes this.
  13. Aug 9, 2021 at 8:15 PM
    swallace
    Steven
    Tri-Cities, WA
    I’m bringing back this old thread. I still haven’t solved this problem. Would it be possible to wire my gage cluster to my HVAC and stereo for dimming? This would bypass the blown fuse.
    I haven’t found anything else that isn’t working with this fuse. Trailer lights all still work.
  14. Aug 9, 2021 at 8:42 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Yes, the panel fuse is the cause for the loss of illumination for all those items, plus some.
    Quick search shows:
    24 PANEL 7.5 A: Instrument panel lights, glove box light, ashtray, accessory meter, audio system, rear view monitor, navigation system, rear seat entertainment system, gauges and meters, air conditioning system
    Most likely culprit is mentioned above, somewhere in the various harnesses going to all those systems, you have an abraded wire grounding. The other is a straight short circuit in any of those systems (less likely, but possible). If I were you, I'd disconnect everything on that list and replace the fuse. If it blows you've got a grounded wire somewhere. If it doesn't, you've got a short circuit somewhere, start adding components you disconnected back into the harness until it blows, thats your culprit (hopefully the only one).
    Im pretty sure it means the light associated with the components listed, except for maybe the ashtray, which I assume they mean the cigarette lighter.
  15. Aug 9, 2021 at 9:24 PM
    swallace
    Steven
    Tri-Cities, WA
    I know it’s not a short circuit, as I already tried removing the components as you suggest and the fuse still blew. I’m struggling to figure out how to find the grounded wire, and certainly open to suggestions.
    Would it work for me to “bandaid” the problem by splicing the stereo and HVAC panel lights dimming wires to my dash gauges that still dim?
