Do I need upper control arms?
Discussion in 'Suspension' started by Tmon58, Aug 8, 2021.
  1. Aug 8, 2021 at 9:43 PM
    Tmon58
    Tmon58 [OP] New Member
    Tyler
    Riverside
    2014 Black Tundra Crewmax TSS Off Road
    What's up guys, new here.
    Just bought bilstien 6112's for my crewmax and have them set to the highest setting which is 2.5" lift.
    Do I need to upgrade the upper control arms as well or will the stock ones work?
    I mainly drive alot of highway miles and plan to offroad occasionally on weekends. I'll be installing 5100's in the rear with icon AAL 1.5" lift
  2. Aug 8, 2021 at 9:46 PM
    AZTundra
    Paul
    Phoenix, AZ
    You should be fine with the stock ones. Aftermarket control arms are typically needed at 3" or higher.
    Saltyhero13 and Tmon58[OP] like this.
  3. Aug 8, 2021 at 10:06 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    What Paul said. You’re good…unless you want to spend more money. :rofl:
    Tmon58[OP] and AZTundra like this.
  4. Aug 9, 2021 at 4:12 AM
    Tmon58
    Tyler
    Riverside
    Thanks for your input guys. I like saving money
    2mchfun likes this.
  5. Aug 9, 2021 at 4:16 AM
    Baem1035
    Baem1035 New Member
    So Cal
    White 2016 Tundra Crewmax 4X4
    -C4 Fab Overland Series Front Bumper -Demello Offroad Sliders -RCI Offroad Skid plates -Leitner Designs ACS Bed Rack -King shocks 2.5 Front Resi Coilovers w/ CDC adjusters. -King shocks 2.5 rear resi shocks with CDC adjusters -Camburg Racing Uniball UCAs -Deaver Suspension U748 Leafs -BFG 35inch K02 tires -Method 311 wheels -Baja Designs 40inch lightbar and fogs
    For that setup and what you will be doing with it, I would save the money. The stock ones will work just fine.
    Tmon58[OP] likes this.
  6. Aug 9, 2021 at 3:51 PM
    oh_really
    oh_really New Member
    NoVa
    2019 Tundra CrewMax Limited Cement
    I have the same setup with factory UCA. Alignment is perfect and there is still room for adjustment. Unless you plan to do some vigorous off-roading, you won't need to upgrade.
  7. Aug 9, 2021 at 4:06 PM
    Tmon58
    Tyler
    Riverside
    Awesome, Thank you. This is good news for my wallet
