4Hi vs. AWD
Discussion in '3rd Gen Tundras (2022+)' started by Doofus, Aug 9, 2021.
  1. Aug 9, 2021 at 12:29 PM
    Doofus
    Doofus [OP] New Member
    Would you trade 4Hi for AWD?
    I’m admittedly ignorant of the mechanics involved with this trade off but I have an F150 with AWD and consequently never use 4Hi. 4Lo comes in handy.
    I understand the gear ratio aspect of AWD vs 4Hi but, for my use case, the two are substitutes with AWD being much more functional.
  2. Aug 9, 2021 at 12:49 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I'd like to have 4Auto, 4Hi and 4Lo just in case I need them but maybe I'm greedy. 4Auto is admittedly probably all I need 99% of the time.
    LukeS, Oey12, LS3 and 3 others like this.
  3. Aug 9, 2021 at 12:56 PM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    The racing Tundra fellas like installing the Sequoia AWD transfer case below 4wd Tundra's. It definitely lets them put the power to the ground.
    Dantdodge likes this.
  4. Aug 9, 2021 at 1:11 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    For me absolutely and 100% no. The vast majority of people I think will be better off with AWD. When it comes to knowing what the vehicle is doing, road condition, predicting how a vehicle is going to react and having the ability to control a vehicle on snow/ice I don't want AWD. One of the best vehicles I ever owned, also for snow and ice, was a '96 4Runner - rear wheel drive unless one engaged the 4WD option.
  5. Aug 9, 2021 at 1:28 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Yes. A true full time AWD system with a Torsen center differential with high and low range is superior in every condition I can think of over a selectable 2 wheel drive to 4 wheel drive transfer case.
    I have driven both in a variety of conditions in a host of different vehicles, and the system we have in our Tundra sucks a bag of dicks compared to a decent permanent AWD case.
    KClav, LukeS, daveyjames207 and 7 others like this.
  6. Aug 9, 2021 at 1:35 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    That was my assessment of the AWD 2006 4Runner.
  7. Aug 9, 2021 at 1:56 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Indeed not. Part tyme is where it's at, pardon moi for ending a sentence with preposition.
  8. Aug 9, 2021 at 2:00 PM
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Full-time 4WD was was one of the reasons I bought the Sequoia. That Toyota Torsen has a long history being stout and reliable. That bum Sweers should get it into the Tundra. Goofy it was only in the Sequoia and the 4Runner.
    Metro14536 likes this.
  9. Aug 9, 2021 at 2:01 PM
    Coal Dragger
    Kung Fu Dick
    Well you’re probably the only driver on planet earth who hasn’t liked an AWD Torsen center differential.
    I mean it’s not like permanent AWD systems dominate motor sports where they’re allowed like rally cars, Paris-Dakar race trucks, Pikes Peak hill climb racers, or other venues where as much traction as possible is a huge advantage. Oh wait, AWD systems do in fact dominate in those environments. Strange that highly skilled pro drivers came to a vastly different conclusion than you did.
    Also a bit strange all these folks who have driven full time AWD in inclement weather, and traditional 4X4’s and also acknowledge the permanent AWD is better.
    4genRunner and RavingOx like this.
  10. Aug 9, 2021 at 2:11 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I wouldn't turn down having AWD, but besides flipping the switch there's not much difference in usage personally. For the people that get worried about turning at all in 4Hi I can see the merit, for me if the weather is bad I'll leave 4Hi on all day long regardless if I hit dry spots, so at that point AWD isn't much different. Ultimately if I had to have one or the other, 4Hi obviously has more traction than AWD so I'll go with that.
  11. Aug 9, 2021 at 2:14 PM
    Coal Dragger
    Kung Fu Dick
    All you need on AWD is a diff lock, and most good systems have that feature.
    Acedude likes this.
  12. Aug 9, 2021 at 2:14 PM
    snivilous
    SW UT
    No doubt, but the question didn't state if the AWD had a diff lock :D
  13. Aug 9, 2021 at 2:22 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Man, you always this snarky or did someone pee in your corn flakes this morning?
    TK1979, LukeS, tsinajinii and 9 others like this.
  14. Aug 9, 2021 at 3:32 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I would like an AWD system with a 4hi and 4lo option for sure. But the AWD option is only going to outperform the 4hi option on dirt road if you are blasting them at 50 MPH like a rally driver.
    Oey12 likes this.
  15. Aug 9, 2021 at 3:51 PM
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    The best 4wd system I have been in is awd with a locking center diff and a low range. Bonus points if it has front and rear lockers. Like Toyota Land Cruiser fj80. Basically the more options the better.
    in my land cruiser I have
    awd high (unlocked center diff)
    4wd high (locked center diff)
    Awd low (unlocked center diff)
    4wd low (locked center diff)
    and if I was cool I’d also front and rear axle lockers to play with.
  16. Aug 9, 2021 at 3:54 PM
    crewmaxlmt
    scott
    Is there any use for the AWD low?
    TK1979 likes this.
  17. Aug 9, 2021 at 4:12 PM
    19crewmaxTRD
    Seth
    Tight uphill turns on loose ground. Keeps your turning radius. (I’ve been known do due some e brake turns in unlocked low)
    Sand dunes when you don’t need 4wd but the extra low gearing helps you get around in a heavy under powered vehicle.
    I’ve even used it to pull vehicles on pavement where the extra gearing makes it easy on my rig but not have to worry about drive train binding.
    TK1979 and snivilous like this.
  18. Aug 9, 2021 at 5:39 PM
    crewmaxlmt
    scott
    Makes sense.
  19. Aug 9, 2021 at 5:48 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Typically AWD does not split power 50/50 front/Rear, it’s more like 60/40 or 70/30. Most trucks with 4wd auto just leave the center differential open 60/40 split where 4hi/lo lock the center differential splitting the power 50/50.
    My GX460 is full time 4WD not awd like a Subaru. Huge difference.
    TK1979 and Cpl_Punishment like this.
  20. Aug 9, 2021 at 6:14 PM
    crewmaxlmt
    scott
    Yeah, a lot of the newer AWD’s are just FWD with a certain percentage dedicated to the rear. Not really the same as a true AWD with a differential between the front and the rear.
  21. Aug 9, 2021 at 7:16 PM
    Coal Dragger
    Kung Fu Dick
    I work for a large class 1 RR, so pee in cornflakes is pretty standard from my employer or worse.
    TK1979 and hagrid like this.
  22. Aug 9, 2021 at 7:26 PM
    crewmaxlmt
    scott
    I guess that’s the price to pay for getting to play with big toys.
  23. Aug 9, 2021 at 7:58 PM
    Coal Dragger
    Kung Fu Dick
    It’s all fun and games until you break stuff or someone gets hurt.
    Broken plenty of stuff, thankfully no injuries or fatalities on my watch but the odds are not in my favor.
    Some of the mechanical failures can be pretty spectacular though. I have photos of some of the mechanical carnage but won’t clutter up this thread.
  24. Aug 9, 2021 at 8:07 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    I love my awd 4runner. All traction all the time and no binding up when turning. I was unpleasantly surprised when I made a u turn in 4wd in the Tundra and felt like my truck was begging me not to.
    oldboy likes this.
  25. Aug 10, 2021 at 12:47 AM
    Coal Dragger
    Kung Fu Dick
    Exactly.
    It’s very easy to confuse AWD systems as all being equal: they’re not. There’s a good reason the Torsen reigns supreme in higher end AWD applications where a vehicle is heavy, powerful, and needs to be capable off road. The Torsen differential is very robust, works very well, and requires no extra maintenance or adjustment. Truck\SUV applications usually have a default 40/60% torque split front/rear, with the ability to send 100% to either axle if needed, and there is a lock feature for 50/50 torque split which will perform like a 4X4 if needed.
    The list of Torsen applications for center differentials, and axle differentials is a long one. One thing you’ll notice is that they’re not cheap cars or trucks that use them.
    Accept no substitutes.
    LukeS, Ahab and Acedude like this.
  26. Aug 10, 2021 at 4:24 AM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    And Land Cruiser and Lexus GX I think?
    If it was good enough for the Cruiser then it is sure that I would like it again!
    Acedude[QUOTED] likes this.
  27. Aug 10, 2021 at 10:06 AM
    Acedude
    Acedude New Member
    Colorado Plateau
    Yep, I think the 4WD BOF SUV's had Torsen Center Diff either standard or optional beginning in 2000 or so??? Tried and true system for many years and miles with various engines, transmissions and axles.
  28. Aug 10, 2021 at 10:10 AM
    nodak67
    nodak67 New Member
    JR
    am i wrong, but you people calling the 4runner an AWD is incorrect. its full time 4wd system (well at least for the limited version).
    my 2014 limited only has 4HI unlocked, 4HI Locked, 4Low. if you tell me its awd, guess i am missing something cause from what i remember, awd usually dont bind up turning. whereas my limited will semi bind if i take an off ramp onto a highway with a bend and flooring it, usually the front inside tire of the turn.
    TK1979 likes this.
  29. Aug 10, 2021 at 10:20 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    You bring up an excellent point about speed. This is where AWD shines… Most drivers in my area do 50 plus on snow and ice covered roads. It makes me cringe honestly but I would much rather these morons have AWD because it can control their stupidity to an extent.
  30. Aug 10, 2021 at 10:30 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I can turn my wheel full turn in either direction in 4wd and have no binding at all in my 2000 limited. They sold it as selectable "always on 4wd" I believe it was meant to be always in 4wd unless you press button to turn off. At least that's what it said in my manual.
