  1. Aug 8, 2021 at 11:56 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Been MIA for a bit. Worked on the truck slowly throughout the work week.
    Changed to 13WL brakes throughout the week. Buttoned up yesterday. Not today.
    Changed inner rack ends, and outer tie rods with moog rack boots today. Steering rack bushings too. Made an extractor tool at work in little bit of downtime that didn't work. Ended up burning out and popping out with a hammer instead of using the tool. I got the dimensions wrong.
    Had new help... actually was helpful this time even though the pictures don't look like it.
    Will try to catch up with threads, and PMs when I can. Sorry all.
    Voss, hammeron, Darkness and 7 others like this.
  2. Aug 9, 2021 at 7:29 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Yeah it's a nightmare. But if you email them, they're really helpful. Just be patient
  3. Aug 9, 2021 at 7:54 AM
    Which ones did you order? I was thinking about the shoft shackle version, but I don’t even own any haha
  4. Aug 9, 2021 at 8:40 AM
    Cummins3500
    Logan
    TRDGen[QUOTED] likes this.
  5. Aug 9, 2021 at 8:43 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    what’d you come up with, and what woulda made the dimensions righter? Gonna have to do the front end on the sequoia before getting an alignment.
    Tundra2[QUOTED] likes this.
  6. Aug 9, 2021 at 9:01 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    I ordered a 1 inch body lift
  7. Aug 9, 2021 at 9:03 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    Cummins3500[QUOTED] likes this.
  8. Aug 9, 2021 at 9:18 AM
    Caliraisedled
    Caliraisedled New Member Vendor
    Jake
  9. Aug 9, 2021 at 10:00 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    TRDGen and FrenchToasty like this.
  10. Aug 9, 2021 at 10:02 AM
    I think Cummins said they are made for the taco but fit his 06 DC, Cali even said free return if they didn’t fit
    TRDGen likes this.
  11. Aug 9, 2021 at 10:06 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    7AF9DF25-AE0F-484D-8971-018A3ACCA5B6.jpg I dont mean the gereric stuff. Those bedside braces are cool, so are the heads/tails and bedracks and sliders.
    Led interior light kit for an ‘02 ac, can you do it?
  12. Aug 9, 2021 at 10:29 AM
    Caliraisedled
    Jake
    The only thing we have that would fit an 00-06 would be some of our light. I'm sure those tie downs would fit because they are not vehicle specific.
  13. Aug 9, 2021 at 10:32 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    thank you.
  14. Aug 9, 2021 at 11:11 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Just a metal tube similar to a ball joint press cup. I cut the tube too long, but my F-clamp was too long also so I'm going with gut instinct on cup being too long.
    Honestly, the longer horizontal bushing popped right out with a few whacks from a hammer, and a 1/2" drive extension. The little vertical bushing required more persuasion. I used a map gas torch to heat up the metal tube that runs through it, and a 1/2" drive T55 torx to beat it out of the steering rack.
    A 1 beer job.
    NUDRAT and Sirfive[QUOTED] like this.
  15. Aug 9, 2021 at 11:15 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Sounds alot like a 4 beer job.
    NUDRAT and Tundra2 like this.
  16. Aug 9, 2021 at 11:23 AM
    Cummins3500
    Logan
    The holes on my bed were a little off on the 4th one and the bracket with the nut behind the tail light was bent outwards. I beat it back in place and drilled the backside of the anchor out a little bit to get it to fit. Tried all 4 anchors on the other 3 corners with no issues. Can safely say the issue was local to my bed. The Cali raised tie downs fit with no issues
    Cali raised’s oem style switches, and usb charger outlet will fit in a double cab/sequoia also
  17. Aug 9, 2021 at 11:37 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    How exactly was the crooked nut beaten?
    bmf4069 and Cummins3500 like this.
  18. Aug 9, 2021 at 11:42 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It's really not. The hardest part is putting the rack back on. I thought changing the inner, and outer tie rods was easier than putting the rack back on, and the sway bar because I had to take it off to have enough room to get the rack back to beat bushings out.
  19. Aug 9, 2021 at 11:45 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Did you pull the steering shaft and is it necessary? I can make tools, i like to see how other people make tools, too.
    Tundra2 and RUSTYNUTS like this.
  20. Aug 9, 2021 at 11:58 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    No, steering shaft stays in place. Use jack stands to support the weight of the rack so you aren't stressing the lines going into the rack.
  21. Aug 9, 2021 at 12:51 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I got to work on my fog lights. I tried buying the Caliraised brackets. The brackets seem like that will be a good option for some. I already have the lights I want to use, which they will not work with. The mounting does not line up with the Baja Designs Squadrons. There would be a small gap on the sides of the brackets and the front bumper. It's pretty minimal and I think you could trim the top and bottom of the bezels to fit them to the bumper better. They seem solid and I like that they screw to the adjustment hole in the back of the bumper.
    @Cummins3500 good suggestion on the brackets. They would work nicely if you have certain pod lights that fit in the brackets.
    I decided to modify the bezels that I had and ended up cutting the backs off so I could put the bolt through the adjustment hole. The front of the bezels secures to the bumper and the light itself is pretty snug against the bezel and holds in place pretty well so far.
    Voss, hammeron, RUSTYNUTS and 4 others like this.
  22. Aug 9, 2021 at 2:18 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Been AWOL a while with busy life/work stuff
    but finally got my rear bumper finished. Had been waiting on welding in Hitch. Now I gotta finally throw the sliders on both rigs that I made over last winter.
    Then I killed one of my Duratracs hitting wrecked RV debris last week. Discount Tire replacement certificate FTW. Unfortunately bent the wheel and jacked the alignment, BIG piece of wood/metal but the tire held together very well, far better than the GMC next to me.
    Done buncha little stuff to Sequoia too will have to grab some pics.
    oscardog86, Voss, bmf4069 and 4 others like this.
  23. Aug 9, 2021 at 2:30 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Found a place with the older airaid intake in stock, price is what it should be, ordered and supposedly being shipped tomorrow, fingers crossed I finally get it because then I can install literally half the intake… that’s all I wanted. LOL
    Voss, jImmegart, Thrussn and 5 others like this.
  24. Aug 9, 2021 at 3:10 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    Interested to see how it turns out for you and how you mod it.
  25. Aug 9, 2021 at 3:17 PM
    empty_lord
    05 rollover special
    No mod at all, the airaid intake setup uses the MIT. The tube from the intake fits with the stock box.
  26. Aug 9, 2021 at 6:02 PM
    I kind of feel bad using these nice surgical/medical reducers for my exhaust! But hey when eBay lays a deal in your lap, you zip your pants up and buy it!
    Most exhaust reducers I looked at were 20-30$ and 20$ shipped. I randomly found these for under 10$ a piece and 5-7 shipped!
    Laid some buggars down to hold them on and took a test drive: liked the results so far. Still need to get on the freeway and see if the RPMs bump up then settle down when slight throttle is given. In town it seems to be a nice input to output feeling so far! 8674EDE9-9DDC-4343-985C-020D8ABC68CF.jpg3515A44E-AB66-4103-834A-14345589546E.jpgDA0299CB-7218-4F31-9EB2-A543BFD69385.jpg
    oscardog86, Voss, Lil Steve and 5 others like this.
  27. Aug 9, 2021 at 6:37 PM
    mbreed2
    mbreed2 Is not right
    Allentown PA
    2001 Tundra 4x4
    I saw a tundra for sale local with a Ivan Stewart grille. I tried to make a deal with them to get just the grille. They said the truck is sold and gone ... Someone is a happy owner of a black tundra with a sweet IS grille... If you show up here, give me dibs if you don't want it.
    oscardog86 and Darkness like this.
  28. Aug 9, 2021 at 6:38 PM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Also, made progress today.
  29. Aug 9, 2021 at 7:54 PM
    empty_lord
    05 rollover special
    Has anyone ever installed a double cab p/s pump on a reg/access cab? The inlet hose is larger. I have a brand new oem pump laying around I’m thinking about installing since I’m doing all the lines anyways (leaking everywhere at this point) the double cab pump technically should flow more yea?
  30. Aug 9, 2021 at 7:57 PM
    empty_lord
    05 rollover special
    But in other news, installed the 130a alt @Tundradrenalin sent for the cost of shipping (thanks again!) installed new brushes to be safe. So far everything looks good, voltage is more stable.
    [​IMG] [​IMG]
    Apparently the 100amp unit doesn’t have the 3rd ear, never noticed that before.
