Bilstein 6112 top hat nut.
Discussion in 'Suspension' started by Mosespaul, Aug 5, 2021.
  1. Aug 5, 2021 at 1:23 PM
    Mosespaul
    Mosespaul [OP] New Member
    Paul
    17 crewmax 040
    Led fog lights Weather tech mats 2nd car seat Spray in bed liner Led interior lights Led headlight bulbs Custom keyed door paint
    Hello all!
    Need advice! I purchased a set of 6112’s for the 2017 tundra crewmax. I ordered my shocks pre assembled and it seems one of the top nuts for top hat is loose ( see video)
    the vendor I purchased these from said just to tighten the nut and it’ll be fine. My question is can that nut tighten down and overcome the pressure from the spring? Seems sketchy!?
    Thanks!
    https://youtube.com/shorts/VvrTf6UzMBE?feature=share
  2. Aug 5, 2021 at 1:34 PM
    Drainbung
    Drainbung Some days you are the show...
    Bob
    Oasis of NV
    2019 Cement DCLB 4X4
    TRD Fleshlight
    Once it's under the weight of the truck you shouldn't have any problem tightening it down.
    BroTun13 and landphil like this.
  3. Aug 5, 2021 at 2:44 PM
    Mosespaul
    Paul
    17 crewmax 040
    Ok that makes sense! Thanks for the reply!
    Drainbung likes this.
  4. Aug 6, 2021 at 9:24 PM
    pursuit2550
    pursuit2550 New Member
    First off I am not genius but that should not be like that. Second, I would prefer to have the spring compressed with a spring compressor to tighten it. Why risk stripping out the nut and thread. That spring is under a lot of pressure. Loading it with the truck could work but if it doesn't you have to pull it out again.
  5. Aug 6, 2021 at 10:34 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Loading it in the truck will work just fine. :thumbsup: 2 wrenches, righty-tighty, and Robert is your mother’s brother. ;)
    Mosespaul[OP] and BroTun13 like this.
  6. Aug 9, 2021 at 5:45 AM
    msmmce1
    msmmce1 New Member
    leave it loose until installed, that will make it easier to adjust during install, then tighten once installed and weight on it.
    Mosespaul[OP] likes this.
