How to fit 35s WITHOUT a can mount chop
Discussion in 'Wheels & Tires' started by Famof5Tundy, Aug 8, 2021.
  1. Aug 8, 2021 at 5:40 PM
    Famof5Tundy
    Famof5Tundy [OP] New Member
    2020 MGM CM Platinum
    Just getting started
    This is something a lot of people ask...and I found an answer that worked for me..
    So after a lot of research...almost exclusively here and YouTube.... So let me share the 3 things I found out to be true....and...pictures
    1. It seems that +25 mm offset wheels kept coming up as the magic number
    2. 3 inches in the front
    3. You will have to modify the front plastic still, which is easy as removing altogether if you wish (working a new mod that I didn't run across yet, share when it's done)
    a_double, red_5ive, Sunnier and 3 others like this.
  2. Aug 8, 2021 at 5:43 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Stock UCA? Alignment numbers? Tires really 35s? Lots of variables come in to play, yours looks good kudos to stuffing those in there without a can mount chop. Most of us probably do the cab mount chop instead to fit bigger tires. :D
  3. Aug 8, 2021 at 5:50 PM
    Famof5Tundy
    Stock UCAs, getting alignment tomorrow...but honestly, right now it looks pretty close.
    The specs list it as 34.7 and 13 wide
    Agree totally that there are a lot of variables and that any one truck may sit a little different. And since it drove me nuts researching...I figured I'd share what I found and what I banked on to guide my decision..
    For what it's worth..and important before anyone were to just take this as gospel....I wouldn't have put them on if I wasn't WILLING to do a CMC, so if I have to in the future, gladly.
    Sunnier likes this.
  4. Aug 8, 2021 at 9:36 PM
    Redrider29
    Redrider29 HARDTRD
    Mitch
    2019 SR5 Crewmax TRD Offroad 4x4 Cement
    Paint matched mirror caps, grill surround, hood bulge, and Bumper Shellz Wireless phone charger in center consule TRD rear sway bar Black painted TRD off road wheels with TRD center caps Black emblems TRD air filter Tyger roll up tonneau cover Extra USB plugs in cab TRD Pro grill Paint matched Bumper Shellz 1.25" Spider Trax spacers Lamin-x fog light covers yellow-removed Diode Dynamics SS3 amber fogs Bilstein 5160 rear shocks DIY bed rail system AJT TSS relocation bracket AJT interior chrome delete bits and pieces Caliraised LED 32" light bar bracket GG Lighting 32" light bar
    The coachbuilder bumper shims was what I used. I really only leveled mine and put BFG 35x12.5r18 on mine. With Coachbuilder bumper shims you can get caster pushed much further forward to clear the cab mount.
    Ely010606 likes this.
  5. Aug 9, 2021 at 12:03 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That’s awesome btw. I am very much not willing to cut the cab mount.
  6. Aug 9, 2021 at 9:07 AM
    red_5ive
    red_5ive Jedi Knight and friend of Cpt. Solo
    Southern California
    2008 4.7L CrewMax
    • 3.5" Maxtrac Spindle Lift • 2.5" Spacer • Monster XD778 18 x 9 wheels, +18 Offset • Nitto Ridge Grappler 325/65 R18 (34.6 x 12.8 - temporarily back on the 32s until I can decide on gears) • Nitro 5:29 Gears (awaiting installation - on hold for now) • Black/smoke headlights • Clazzio custom leather seats • Boss Wireless Android Auto head-unit • Backup camera
    It looks like you have 2 spacers. How much total spacing? 1/2"?
  7. Aug 9, 2021 at 3:48 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    Yes. 1/2"
    red_5ive[QUOTED] likes this.
  8. Aug 9, 2021 at 5:50 PM
    Famof5Tundy
    Back to in specs but with caster forward, still no rub. Very close, but no rubbing...
    Hope this helps...
    Also, for those looking for a different idea with the front plastic. Unplug the fog light, run it in the side hole, plus it in. Then cut a metal plate, drill holes and use self tapping screws for the mount. Here's pics.PXL_20210809_211045915.jpg PXL_20210809_212623357.jpg
    biebs96 likes this.
  9. Aug 9, 2021 at 6:12 PM
    JcGc
    JcGc New Member
    2020 Crewmax 4x4
    4/2 Ready lift Kenda Klever 35 x 12.50 x 20 XF Off road wheels
    It's easier just pushing the front plastic liner forward. Cutting things out, leaving the liner out .......all looks like crap.
  10. Aug 9, 2021 at 6:19 PM
    CamaroSsToTundra
    CamaroSsToTundra New Member
    Ohio
    2018 Tundra
    Nice I am also able to fit 37/12.50/20 with 7 inch lift without body mount chop with 20x12 -51 offsets wheel. Usually 37 goes with 8 inch lift and there is no research online that you can fit with 7 inch w/o BMC.
    red_5ive likes this.
