TRD heat shield needed
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tophergt99, May 1, 2017.
  1. May 1, 2017 at 5:07 PM
    Tophergt99
    Tophergt99 [OP] Back in black
    Weston, Wisconsin
    2015 SR5 Black TRD Crewmax
    In progress....
    Might be buying a used trd exhaust system but don't think it will come with the heat shield. I know I need a driver side hanger kit, I found that but can't find the bigger trd heat shield that comes with the kit. Anyone know the part #?
  2. May 1, 2017 at 5:16 PM
  3. May 1, 2017 at 5:20 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
  4. May 1, 2017 at 6:03 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I think Romans off for the week or the next two weeks getting married / honeymoon
    Tundyfundy and NewImprovedRon like this.
  5. May 1, 2017 at 6:05 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Nvm not yet
    831Tun likes this.
  6. May 2, 2017 at 6:56 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    I've got some bad news. That heat shield isn't available separately. I've called Toyota before on this, and they do not have a part number for this nor will they just sell the heat shield to me.
    MotoTundra likes this.
  7. May 2, 2017 at 7:20 AM
    Tophergt99
    Weston, Wisconsin
    In progress....
    So what are my options? Will the stock one hold up? I don't sit and idle anywhere except when I remote start in the summer or winter.
  8. May 2, 2017 at 7:43 AM
    Roman
    Roman
    Franklin, TN
    You'll have to run with the stock one. There have been other Tundra owners who have had to do just this, and I haven't heard of anyone having problems.
    Tophergt99[OP] likes this.
  9. May 5, 2017 at 11:03 PM
    QTunDrA
    QTunDrA New Member
    Q
    2014 Tundra Platinum
  10. May 10, 2017 at 7:25 AM
    Tophergt99
    Weston, Wisconsin
    In progress....
    I checked that link, it a discontinued part. I am getting the system, do you guys think I'll be ok with just the stock heat shield? We dont have slow/stopped traffic here.
  11. May 11, 2017 at 7:13 AM
    Tophergt99
    Weston, Wisconsin
    In progress....
    Do you guys use any kind of sealant when installing the trd system or does it seal up on it's own good? Is it ok to reuse the seals or should I get new one's? Exhaust is only 4-5 months old.
  12. Aug 9, 2017 at 10:17 AM
    edwin729
    edwin729 Tundra Life
    Edwin
    Arizona
    2023 Silver Tundra Crew 4x4 Plat
    @Tophergt99 hey did you figure out your exhaust question? Are you running with the stock heat sheild? I'm going to install similar exhaust, I'm going from stock to dual trd exhaust system.
  13. Aug 9, 2017 at 11:55 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    Why not just make one? Seems like a piece of ducting metal would work just fine. All you would need is a pair of tin snips, a sharpie and a drill for the mounting holes. Just use your existing shield as a template. I would use some nuts or washers on the backside of the mounting holes to space it off the bed and keep it from a possible rattle.
    http://www.homedepot.com/p/Master-F...vanized-Steel-Flat-Sheet-GFS24X361P/202191776
  14. Aug 9, 2017 at 12:01 PM
    Ha! Beat me to it... was thinking same thing
    JH5370[QUOTED] likes this.
  15. Aug 9, 2017 at 7:24 PM
    Tophergt99
    Weston, Wisconsin
    In progress....
    Just been using the stock one, haven't had an issue.
  16. Oct 22, 2020 at 10:23 PM
    aminter0
    aminter0 New Member
    Andrew
    2017 White Tundra CM SR5 TRD
    Hey all- has anyone running the stock heat shield on the TRD Pro Exhaust had any issues? Thanks!
  17. Nov 27, 2021 at 4:37 PM
    wyso
    wyso New Member
    chris
    2010 Tunda
    TRD supercharger, big brake kit, 22 TRD wheels
    I need either the TRD or stock shield if anyone has one they don't need for sale>
  18. Dec 16, 2021 at 8:26 PM
    wyso
    wyso New Member
    chris
    2010 Tunda
  19. Jun 17, 2025 at 6:28 AM
    lsumatt1514
    lsumatt1514 New Member
    2020 Tundra Crewmax Platinum
    Following up on this...has anyone had any issues using the stock exhaust head shield with the TRD exhaust kit? Thanks!
  20. Jun 17, 2025 at 9:01 AM
    Echo5Golf
    Echo5Golf New Member
    Phil
    Tundra Hunter
    So he is busy??? Pfffff…..
  21. Jun 17, 2025 at 9:15 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
