What does this sensor mean?
Discussion in '1st Gen Tundras (2000-2006)' started by Durbin7, Jul 10, 2021.
  1. Jul 10, 2021 at 2:17 PM
    Durbin7
    Durbin7 [OP] New Member
    Ohio
    Two nights ago when I got in my truck to five home from work, there was a new yellow alarm sensor that lit up and then went away 5 seconds later. It said maintenance required. The fact that it went away seemed funny. Does this need checked out? Or can I run with it on for a while? Truck seems to be running fine.
  2. Jul 10, 2021 at 2:30 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    What year truck? Access cab? Double Cab? V6? V8? 2WD? 4WD?
    I think our 2008 sequioa's "maintenance required" light will flash, and then go away when the truck thinks its approaching oil change time. Once it reaches the interval set in the computer the light will come on and stay on until you do the reset sequence.
  3. Jul 10, 2021 at 2:31 PM
    Durbin7
    Ohio
    2006 double cab sr5 2wd
    Tundra2 likes this.
  4. Jul 10, 2021 at 2:33 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  5. Jul 10, 2021 at 2:56 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    That means you are getting close to an oil change. It will be fully lit at 5k miles sounds like you are around 4.5k since your last reset
    Tundra2 likes this.
  6. Jul 10, 2021 at 3:02 PM
    Durbin7
    Ohio
    I wondered, but that can't be it. I drove 4k miles total last year. Only been 2k miles since my last service. I had the timing belt and water pump done and they changed the oil then. Right around the new year. I wrestle with how often to change oil since I drive so little during the year.
    Tundra2 and jerryallday like this.
  7. Jul 10, 2021 at 3:07 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    But did you reset (aka let the computer know) by using the Odometer push pin after the last oil change?
    FirstGenVol and Tundra2 like this.
  8. Jul 10, 2021 at 3:33 PM
    Durbin7
    Ohio
    No sir, I don't think I knew that was a thing, lol. Thank you
    jerryallday likes this.
  9. Jul 10, 2021 at 4:46 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Here is how to reset it. It will come back on in another 4.5k
    https://youtu.be/KC03koYxwRE
  10. Jul 10, 2021 at 7:01 PM
    Durbin7
    Ohio
    Thanks all
  11. Jul 11, 2021 at 4:23 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Yeah . . . thank you , I didn't know about this feature.
  12. Aug 8, 2021 at 5:04 AM
    eddie98
    eddie98 New Member
    Atlanta, GA
    2018 MGM CM
    N-Fab Podium Steps, Line-X, Bed Lights
    General question about this "maintenance" light. I have a 2018 CM.
    Will this maintenance light come on "only" for oil change, or it will come on for another reason? I believe it comes on every 5k miles but not sure. need to get my manual and find it.
  13. Aug 8, 2021 at 7:02 AM
    I had no idea the newer first gens had this feature. My 02 is low tech and doesn't remind me about oil changes.
    des2mtn likes this.
  14. Aug 8, 2021 at 7:39 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Ok, I’m stumped….. What is a 2018 MGM CM?
  15. Aug 8, 2021 at 7:44 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  16. Aug 8, 2021 at 8:29 AM
    shifty` Animals and insects don't do drugs
    abcinv likes this.
