Wheel choice and offset
Discussion in 'Wheels & Tires' started by Tundra694, Aug 4, 2021.
  1. Aug 4, 2021 at 1:39 PM
    Tundra694
    Tundra694 [OP] New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    What aftermarket wheels would sit flush to the fenders like the stock ones ?
    I've read that stock rims are +60 offset but I haven't seen any aftermarket ones even close to that. I currently have the Method Grid's which I love the look of. However with what I believe is +18 offset on them they stick out past the body about 1.5 - 2" which has resulted in some decent rock chips. It's not a garage queen but I'm also not trying to litter it with stone chips. TRD Pro rims are in the mix but at about $500/wheel I'd like to look at other options. Any suggestions ?
  2. Aug 4, 2021 at 1:48 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    2mchfun likes this.
  3. Aug 4, 2021 at 1:49 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    This could offer you some insight http://www.rimsntires.com/specspro.jsp
    But most of the wheels come in specific offsets. lots of choices in the +18 to +25, but fewer rims in higher positive offset, which is what you are looking for.
  4. Aug 4, 2021 at 1:52 PM
    Tundra694
    AJ
    I was hoping it was all in my head but last night I left a normal limestone parking lot and once I was on the highway heard the stones bouncing off the rockers and found 3 new stone chips. I only have 6,000 miles on my truck so I'd like not giving my truck the golf ball finish.
  5. Aug 4, 2021 at 1:54 PM
    frichco228
    Frank
    Virginia
    totally get it, one of the reasons (beside the appearance) that I love the stock toyota OR wheels.
    Look around for wheels +30 to the stock +60, most of the wheel vendor sites let you filter by offset.
  6. Aug 4, 2021 at 2:06 PM
    Tundra694
    AJ
    Yea I was originally holding out for a deal on TRD PRO BBS wheels but ran into these methods used for a steal and loved the look. I only realized after I got the tires mounted and wheels on that they stuck out as much as they do. I've been back and forth about changing them ever since.
  7. Aug 4, 2021 at 4:11 PM
    pursuit2550
    pursuit2550 New Member
    The majority of wheels for the tundra from what I have seen are 25 and lower. I have the TRD wheels and I am putting on 1.25 wheel adapters which put it slightly outward of the fender. Almost like a 25 offset. Gives it a better stance but avoid rock issues. Luckily I have never had the rock chip issues with any of my aftermarket wheels.
  8. Aug 4, 2021 at 4:51 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    With the price of wheels right now I’m leaning towards 1.5inch spacers and keeping my stock trd or wheels. I wanted to go to 17s but the wheels keep climbing up
  9. Aug 4, 2021 at 5:51 PM
    Elduder
    Elduder New Member
    0's with 315s :D
    Stock wheels with a 1.25 is like a +28 offset, 1.5 is like a +22. Anything in the +25 area is pretty much perfect for stance, clearance and concern over fender chips. I dont have any paint chips as of yet.
    Nightshade1970, equin, junior and 2 others like this.
  10. Aug 4, 2021 at 5:52 PM
    eick
    eick New Member
    I wanted to do that but good lord wheels are expensive right now
  11. Aug 6, 2021 at 1:15 PM
    Tundra694
    AJ
    Yea they stick out 2.25" in the rear and 1.5" in the front so they actually might be 0 offset. I'm going to pull them and see what they're stamped on the back with. I might go with icons that are +25 which should be a bit more reasonable if mine are 0 offset.
  12. Aug 7, 2021 at 3:14 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    The 20x9 TSS Tundra wheels are a +50 offset and sit flush with the side with 33” & 35” x 11.5” Ridge Grapplers (I’ve run both sets of tires)
    Tundra694[OP] likes this.
  13. Aug 7, 2021 at 3:17 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Just took off the TSS wheels to go to a more aggressive offset (Black Rhino Duggers 20” +10 offset)
    equin and Tundra694[OP] like this.
