Buying a tundra with 200k miles
Discussion in '1st Gen Tundras (2000-2006)' started by Wallerjt, Aug 7, 2021.
  1. Aug 7, 2021 at 1:08 PM
    Wallerjt
    Wallerjt [OP] New Member
    Jacob
    2006 AC limited
    Limited edition
    I’m buying in California. Looking at a tundra 05 DC with a leer hard top on bed, limited with 198k miles, clean title, timing belt recently replaced and good service report for 10,995$
    also a 05 tundra AC SR5 with 200,500 miles for 9,450 with a hard top. Curios on if paying too much and what to look out for.
    thanks in advance.
    05tundra916 likes this.
  2. Aug 7, 2021 at 1:28 PM
    05tundra916
    05tundra916 New Member
    2005 Toyota Tundra Double Cab
  3. Aug 7, 2021 at 1:31 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    sounds like a good truck, check the usual rust however. Climb up under there, don't just glance. If the frame is solid and everything else looks good you could have a keeper
  4. Aug 7, 2021 at 2:50 PM
    How handy are you? 200K miles isn't that scary for these trucks but you should anticipate a suspension overhaul if it's still rocking a lot of the original parts. A lot of original parts will likely need to be replaced. These trucks are demanding a premium right now so the prices you mention don't seem too high.
  5. Aug 7, 2021 at 2:58 PM
    Wallerjt
    Jacob
    2006 AC limited
    Limited edition
    I’m also looking into a 06 AC tundra 131k miles for around 14k just took it on a test drive and it was smooth only noticed a little bit of rust in a boot holding the exhaust pipe
  6. Aug 7, 2021 at 3:07 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    The McGov. used truck (and car) standard advice: look for evidence of flood damage. America had a crap pot of floods 6 years ago. MANY vehicles got insurance checks and were then bought back (cheap) and put into the secondary market. Inspect under the hood. Under the seats (including the rear ones). Look close.
    If there's no evidence of flood damage and everything else checks out I hand him the 90 Benjamins. My daily driver is a 1997 Toyota T100 with 265,000 miles that runs perfect.
  7. Aug 8, 2021 at 10:43 PM
    cameron92
    cameron92 New Member
    PNW (State of Jefferson)
    2005 Phantom Pearl Grey Tundra Limited DC 4WD, 4.7L VVTI, LSD, Tow Package
    2.5in suspension lift (Bilstein 5100's, Icon add-a-leaf, Eibach pro springs, Camburg upper control arms, and kyb replacement tophats.) ARMA Bedliner. Trailer Braking System. Fifth wheel underbed mount plates (frame mounted) W/ through bolts in bed. Yakima Q-Towers W/ 58in Yakima round crossbars and 52in Yakima wind fairing.
    I bought my 05 limited for 5500 from the original owner with close to 200k here in north california. Came with full service record, an extra set of factory limited 17"alloys with snow tires on em, a trailer brake system on it and a herculined bed. I will admit I got super lucky on my find. Those are both great deals though. 200k are these truck just starting to break in, just do your routine maintenance and maintenance by mileage and you'll be fine.
  8. Aug 9, 2021 at 7:37 AM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    @Wallerjt those prices are very reasonable if the truck is in good condition. A rusty frame is a deal breaker though. I crawled under the Tundra with a ball peen hammer to "ping" the frame to see if it was solid. I'm not frame diagnostician and mine generally looked good (exposed rust on 60% of the frame and most of it looked like it was surface rust) nevertheless, hitting it with a hammer was reassuring.
    Keep in mind, the Toyota standard for warranty replacement is a nickel sized hole* rusted through the frame! That's a huge variance from surface rust.
    * Correct me if I've misstated this. Morning beers affect my recall.:cheers:
    Sirfive likes this.
