  1. Aug 5, 2021 at 6:58 PM
    Hey have you posted info about your aux fan setup? What size fan, relay and any other mods to make it work?
    TRDGen likes this.
  2. Aug 5, 2021 at 7:00 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I had them put the trans cooler in. Transmission. Temps have even been lower with it vs the old one
    If you wanted to not have one, mishimoto makes a radiator without the cooler. Save some coin
    Thrussn[QUOTED] and TRDGen like this.
  3. Aug 5, 2021 at 7:04 PM
    I thought the first one you bought didn't fit your truck? Who made that one?
  4. Aug 5, 2021 at 7:11 PM
    empty_lord
    05 rollover special
    CSF makes the one for double cabs but doesn’t specify. Mishimoto fit access and reg cabs
    TRDGen and NUDRAT like this.
  5. Aug 5, 2021 at 8:30 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Thanks. My chase visa does that and I use it always for that reason but the phone was about 9 months old AND it was free after trading in my old iPhone X so I didn’t technically ‘purchase’ it which sucks. Had to shell out another $950. The other thing that sucks is that I need to find a replacement front window and install it myself since it’s not going to be more than my deductible anyways.
  6. Aug 6, 2021 at 7:07 AM
    This is one of those cases where I'd just look into Safelite. Last time I had a side window replaced it was under $200.
    In the pic it looks like the back passenger window is spidered also? Was it just one or both?
  7. Aug 6, 2021 at 7:24 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Just the front pass window. That’s a tree shadow in the back. I can get a used window for $50 at the yard and get it tinted to match so I’ll probably do that.
    BubbaW likes this.
  8. Aug 6, 2021 at 7:31 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    It’s more time consuming than difficult but replacing window will give you chance to clean/lubricate if not done already.
    CodyP and shifty` like this.
  9. Aug 6, 2021 at 7:35 AM
    What exactly needs to be lubed? I looked the last time I had my door panel off but wasn't sure where it was needed. And what type of lube?
  10. Aug 6, 2021 at 7:38 AM
    And fix the scissor jack to reduce window rattle when partially-open, if you suffer from that (I know I do, both for the front windows and rear slider!)
  11. Aug 6, 2021 at 8:34 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    I used Napa Sil-Glyde that I had left over when I took my moon roof window/frame out to clean regulator since it was struggling to open/close....the FSM calls for MP grease for many of our lubrication points. Each one of those window lube points noted in FSM are made of neoprene plastic ?? and one will see an improvemnet once lubed. I chose to remove the window/regulator completely since it had probably not been done since new and I wanted it German clean(goodin clean). My last one to do is the back window since I don't use it much and never been lubed since I've owned it.
    Lubricant - Multi Purpose Sil-Glyde Lubricates 4oz. Plastic Tube BK 7651351 | Buy Online - NAPA Auto Parts (napaonline.com)
  12. Aug 6, 2021 at 3:32 PM
    Cummins3500
    Logan
    tacoguybill, shifty`, Voss and 2 others like this.
  13. Aug 6, 2021 at 3:39 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Wait, if we take the two names and put them together it spells "Feather"... he loved to feather dust his motor... he was giving us hints the whole time!
    We have to communicate with him through Amazon reviews!
    Sunnier, Lil Steve, CodyP and 7 others like this.
  14. Aug 6, 2021 at 3:54 PM
    I was half tempted to buy a MAF just to leave a review "hey Heather, are you by chance a professional hand model? ".
  15. Aug 6, 2021 at 3:58 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    You know if you post a question on that part he will get an email...
  16. Aug 6, 2021 at 4:03 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Damn I should have ended that with "can I paint the cover black" so he would know who it is.
  17. Aug 6, 2021 at 4:20 PM
    Why would that send him an email? I've left reviews before and I don't get emails when people ask questions.
  18. Aug 6, 2021 at 4:22 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    There is a setting on there I think. I get emails for questions on stuff I bought and I never left a review. We'll see, I think he would have it set to send him questions.
    This feels very ouija board.
    bmf4069, CodyP, NUDRAT and 1 other person like this.
  19. Aug 6, 2021 at 4:26 PM
    Cummins3500
    Logan
    Not to derail the topic but my Mind is blown…… I just noticed that my wife’s 07 sequoia has no radio antenna. Like never even registered until I swapped mine
    NUDRAT and Darkness like this.
  20. Aug 6, 2021 at 4:28 PM
    look at the back window, it’s probably embedded there, or maybe it has the sharkfin on the roof
    BubbaW and Cummins3500[QUOTED] like this.
  21. Aug 6, 2021 at 4:29 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I never noticed that. Not even a little shark fin. Wonder how they did that, pretty cool.
  22. Aug 6, 2021 at 4:55 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    If it’s 100 out I’ll see 180’s cruising at 60 and 195-205 going up prolonged hills.
    jerryallday[QUOTED] likes this.
  23. Aug 6, 2021 at 4:56 PM
    Cummins3500
    Logan
    I’m pretty sure it’s in the back glass, like @FrenchToasty mentioned. I can’t tell though cause the tints so damn dark lol. Makes for a super clean look though
    @Darkness if Toyota was doin no antenna back in 07 looks like all the oem manufactures could do a better job hiding their antennas
    Darkness likes this.
  24. Aug 6, 2021 at 5:06 PM
    Filthyphil
    Phil
    This has literally made my evening been reading all these cracking up… man I miss Fred and or Heather.
  25. Aug 6, 2021 at 5:15 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Alright which one of you fuckers is Shuan?
    :quickdraw:fuckin up the bait here!
  26. Aug 6, 2021 at 5:21 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    If it's like a 2005, it's in the rear RH back window.
    NUDRAT, Darkness and daveeasa like this.
  27. Aug 6, 2021 at 5:26 PM
    empty_lord
    05 rollover special
    Antenna is in the rear quarter glass if I remember right
    NUDRAT and Darkness[QUOTED] like this.
  28. Aug 6, 2021 at 5:32 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Post the link so we can fuck up shauns day.
  29. Aug 6, 2021 at 5:41 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    I’m not sure how long I’ve been gone but I missed you all! Man Darness and FrenchToasty are turtles now, what’s been goin on while I was away? Lol
    Today I’m changing my rear diff oil after hitting 500 miles on the new gears. Looks like they’ve broken in well from the shavings on the drain plug magnet.
    For those breaking in gears on 4WDs… Nitro Gears recos you break in the rear alone for all 500 miles/no 4WD during this time. Once rear is broken in, then start breaking in front/4W in 30 min drive/rest intervals. Their gear package doesn’t come with any break in instructions, told this is their reco after calling them.
    oh and they said don’t break in 4w/front on road. You wanna be off-road cause there’s tension when in 4wd and you wanna be on dirt so tires can spin and relieve the tension.
    Hope you all are well my dudes.
  30. Aug 6, 2021 at 5:43 PM
    So why not order one from Mishimoto? Didn't you go with a custom unit from someone else?
