Wheel and tire sizes
Discussion in '1st Gen Tundras (2000-2006)' started by mbreed2, Aug 6, 2021.
  1. Aug 6, 2021 at 2:49 PM
    mbreed2
    mbreed2 [OP] Is not right
    Allentown PA
    2001 Tundra 4x4
    I know this has been posted before, but I cant find the answers I'm looking for. I need help.
    "Mbreed2 shouldn't you be more concerned with your timing belt and transmission??"
    Yes, those projects are underway. But I'm at work now and this is on my mind.
    I have tire rub.
    I have a leveling kit.
    I have spidertrax 1.25" wheel spacers.
    My tires are 265/70 R17
    My rims are...
    I got them off a guy who had them on his newer Tacoma.
    As of now my rear and front wheels sit visibly parallel. So I don't want that to change.
    Are these specs within acceptable range? Or do I need to change something?
  2. Aug 6, 2021 at 8:28 PM
    jberkut4
    jberkut4 Shake and Bake
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    Suprised you have rub with that setup, is it rubbing on body or frame? could be the spacers, might not even need them
    mbreed2[OP] likes this.
  3. Aug 7, 2021 at 10:24 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Spacers will make you poke out more cause rubbing on the pinch weld and outer fender. The -6 offset on the wheels and the -31.75 offset on the spacers is causing you to stick out a lot. You will need to do some trimming and hammering, or ditch the spacers.
    Glock 40 and mbreed2[OP] like this.
  4. Aug 8, 2021 at 10:35 AM
    Cummins3500
    Logan
    How much tire rub we talking?your at a little less than 3.5 inch backspace, which is pretty aggressive but not unheard of.
  5. Aug 8, 2021 at 1:23 PM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Currently rubbing the front bumper lower trim when I turn and back up. I'm going to get an alignment to make sure my caster is where it should be, then go from there.
