2015 platinum AUTO on headlight not working [SOLVED]
Discussion in 'General Tundra Discussion' started by TundraLLama, Aug 4, 2021.
  1. Aug 4, 2021 at 6:02 PM
    TundraLLama
    TundraLLama [OP] New Member
    Massachusetts
    2015 Black Platinum Tundra
    Color matched mirror caps and door handles TRD dual exhaust TRD shift knob TRD Pro FOX shocks Spray in LINEX bed liner TRD 18” wheels FOX TRD Pro suspension Michelin 275/65r18 LTX AT2 Soft top Roll up bed cover Go Rhino RB10 running boards TRD Pro LED blackout headlights TRD Pro LED blackout fog lights TRD Pro grille AJT DESIGN blackout vent/shift/cup holder Wireless charging tray Remote starter Upgraded alpine speakers, amp, dual sub box. Rear underseat storage.
    It’s time to get rid of this piece of junk! Kidding. This is my first issue in two years of ownership. My headlights do not turn on when it gets dark when set to auto. There’s nothing blocking the photocell sensor and I checked the settings in vehicular customization. If anyone has has this issue I’d love some feedback before the enters the dealership vortex. Thanks!
  2. Aug 4, 2021 at 6:07 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Have you checked all the fuses? Could be something in the dial itself, maybe a corroded or dirty contact? It'd be worth taking apart and checking that too. It's not hard for sweat and grease to get into the crevice if you use your blinkers alot
    TundraLLama[OP] likes this.
  3. Aug 4, 2021 at 8:54 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Did you pull up that speaker grill thing and make sure the wires are plugged in? Maybe they rattled loose.
    Also the light switch/blinker stalk on our trucks are known to fail or be glitchy. I had a problem where my headlights would turn off when signaled left at times.
  4. Aug 6, 2021 at 2:05 PM
    TundraLLama
    Massachusetts
    I brought it to my local garage to see if they could resolve my issue before bringing it to the dealership. They had it for about a day and a half and found the problem. It was a broken wire in the steering column. I’m not sure of specifics because the mechanic who fixed it was not there when I picked up my truck. It cost me $225 which in my opinion was well worth it. They say it could’ve happened just overtime or some weird combination of turning the wheel and the directional. I hope this helps somebody.
    Black Wolf likes this.
  5. Aug 6, 2021 at 2:12 PM
    $225 was fair. It takes time to search for that gremlin. Glad it got fixed!
