Beware of Third Party Oil Changers
Discussion in '2nd Gen Tundras (2007-2013)' started by SCUBAMAN, Aug 6, 2021.
  1. Aug 6, 2021 at 10:39 AM
    SCUBAMAN
    SCUBAMAN [OP] New Member
    2008 5.7 Tundra
    New User, First Time Blogger, sorry for the bathroom read
    Apologies if someone has already posted this up as I am a newbie to this. So bought the 2008 Tundra new, with it bought the extended service plan (5 yrs I think) for oil changes and what not. At some point in time I decided that I didn't have enough time to change my oil and took it to one of the drive-in, drive-thru places. As you all know an oil change in these trucks are not as quick as a normal car as you need to remove the front skid plate. I got tired of paying >$100. for an oil change so I've done them myself. I've religiously change my own oil for the past 8+ yrs. Fast Forward to this week, when I got a couple engine checks, local mechanic said he had a similar check on another Tundra which was the two modules on the port side of the motor, valve cover. So we went with his fix. The fix did not resolve the issues. He added a 1/2 quart then cleared the code. Then he proceed to tell me about his son's Tundra that JL had changed oil and <5 miles on the freeway blew up the engine which JL eventually replaced. The reason was they removed the inner filter support tube on the oil filter canister, the filter collapsed, lost oil pressure. Back to my issue. On the way home, check engine light come back on. I look at the idiot gauge and at idle oil pressure is 1 needle above low. OMG, this is my issue with oil filter collapsing. YEP sure enough that was the problem. Had to buy a new canister which came with the tube. Since I didn't know about this tube, it wasn't there when I started changing oil. So if you have had someone else change your oil make sure this tube is in the canister.
    TheBeast, Ktate, Vr0ck and 1 other person like this.
  2. Aug 6, 2021 at 10:42 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    One thing thats a bit alarming, he suspected it was your oil filter canister missing the tube but didn't check it?
    Good info for others though. Hope you caught it before damage happened.
    TheBeast and Ktate like this.
  3. Aug 6, 2021 at 10:56 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Exactly why I won't let anyone touch my vehicles for routine maintenance like an oil change. I had one horrible experience that almost turned catastrophic. Never again.
  4. Aug 6, 2021 at 11:01 AM
    SCUBAMAN
    2008 5.7 Tundra
    He offered to change oil, but I figured I could do that and wanted to discover this myself.
  5. Aug 6, 2021 at 11:03 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Ahh, that is more understandable.
  6. Aug 6, 2021 at 1:09 PM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    Wow! Change it yourself from now on! Like most people I was given two free oil changes when my truck was new. Never used them.
    coldcanuk likes this.
  7. Aug 6, 2021 at 1:29 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    What u expect, only high school drop out work in those dumps. No ase master mechanic work there
  8. Aug 9, 2021 at 7:57 AM
    SCUBAMAN
    2008 5.7 Tundra
    I used Amsoil in my dirt bikes, but it has been awhile, do they have an Synthetic oil and has anyone sent in the used oil for test results.
  9. Aug 9, 2021 at 8:02 AM
    CallsignKodiak
    CallsignKodiak New Member
    Bear
    Iiawah
    2021 CrewMax 4x4
    So would anyone suggest I not use the free two years of ToyotaCare I'm being given with my new 2021 truck? Two years of free oil changes is 'bout impossible for me to ignore after dropping 40k+ on this truck. I think the answer for me is obvious, but asking anyways as I value the opinions of the more experienced Tundra owners. No, would never use a quick lube type of place.
  10. Aug 9, 2021 at 8:05 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    I just ordered 3 jugs of amsoil 0w-20 signature series. Testing it for 10k miles. All my vehicles take the 0w-20, tundra, tacoma and even the wife's Malibu. Makes buying oil easier.
  11. Aug 9, 2021 at 8:45 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    that's only 2 oil change and 2 tire rotation. but have to bring the truck in and wait for an hour, if you have hours of free time and got nothing to do...
  12. Aug 9, 2021 at 8:58 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    The Amsoil faithful can't resist a threadjack.
    crewmaxlmt, hagrid and Uhhhh.... like this.
  13. Aug 9, 2021 at 9:08 AM
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    Even at a dealership, they're having the 18y/o do your oil changes - the least experienced/cheapest-per-hour one in the bunch. It's a big no-thanks for me. Not worth the risk when it can be done at home easily & inexpensively....& you have peace of mind knowing it's done correctly. As stated above - it's only 2 oil changes anyway.
  14. Aug 9, 2021 at 9:08 AM
    DirtyHulk
    DirtyHulk New Member
    2020 Pro 2006 DC
    I used to work at Toyota and I will not take my 20 Pro for them to do my free services.
    I do it myself.
  15. Aug 9, 2021 at 9:34 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Oil places have a bad habit of breaking these filter canisters and replace them with the dorman POS. The Forman’s have a Center piece that can be removed and it usually falls out when you change the filter.
    We’ve dealt with all the quick lube places at work due blowing up motors with these things. They’re always a headache to get to cover repair costs too
    CallsignKodiak likes this.
  16. Aug 9, 2021 at 9:38 AM
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    Lol! This speaks volumes. I'd love to hear some of your stories...
    Mr Badwrench and Tyman like this.
  17. Aug 9, 2021 at 9:51 AM
    DirtyHulk
    2020 Pro 2006 DC
    I've seen it all after writing services for Toyota for 2 years.
    Uhhhh....[QUOTED] likes this.
  18. Aug 9, 2021 at 10:12 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Does Amsoil have a lubricant series that doesnt have signatures all over it?
    crewmaxlmt, xJuice and PKFan like this.
  19. Aug 9, 2021 at 10:22 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Yeah that was my bad, in my original post I actually wrote, "I didn't even know amsoil had oil filters." So I proceeded to their site, checked em out and with that type of reinforcement, the OP wouldn't encounter that problem again.
    Somehow it fell off the keyboard along the way.
  20. Aug 9, 2021 at 10:28 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    The John Hancock of lubricants, petroleum or water based. They're expanding markets.
    At any rate, thanks for the PSA, OP.
    hagrid[QUOTED] likes this.
  21. Aug 9, 2021 at 3:21 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    Wix xp filter an Castrol full synthetic high milage 0-20 is the only stuff I use , convinced on it after several vehicles I been around consuming oil like its nothing but then holding oil after this switch. Don't know why , also considering the Service pro oil Toyota uses , alot of other manufactures use. Much comfortable using Castrol that oiled a bunch of legendary Toyota racing vehicles. also remember if your ever buying a oil filter for use with full synthetic that the filter is rated for it.
