under seat storage wire harness interference
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by mtodd62, Apr 20, 2020.
  1. Apr 20, 2020 at 4:52 PM
    mtodd62
    mtodd62 [OP] New Member
    Mark
    2020 Mag Grey Tundra TRD Pro
    Center console wireless charger, Husky floor liners, tonneau cover, bed extender. So far...
    I'm looking into under seat storage options for my 2020 TRD Pro Tundra. I recently saw a video (https://www.youtube.com/watch?v=ksQh10t1Dw8&t=113), shown at about 4 minutes into the video, which shows a wire/harness that might interfere with the installation of a storage unit where your'e required to cut away some of the styrofoam under the seats. This is for newer Tundras that have the keyless entry system. Have any of you experienced this problem with the installation of these types of under seat storage units? I want to make sure I don't order a storage unit that I can't install because of this wire/harness, and I won't know for sure if it's there until I cut away styrofoam.
    StihlBuckin likes this.
  2. Apr 20, 2020 at 4:54 PM
    TaquitoBandito
    Joel (AKA Bif)
  3. Apr 20, 2020 at 8:32 PM
    Vin63
    Vin63 New Member
    2022 Tundra SR5 DC
  4. Apr 21, 2020 at 6:19 AM
    Tag520
    Tag520 New Member
    CT
    '20 Army Green Tundra Trd Pro
    From what I understand, your '20 will have that wire. But it doesn't prevent you from installing these. Only that you need to go slow on the cutout of the middle one, and as long as you cut from left to right and go slowly, the worst you'll do is bump up against the casing.
    But i haven't installed them yet.
  5. Apr 21, 2020 at 6:10 PM
    mtodd62
    Mark
    Thanks Tag520! I'm less worried about damaging the wire (if I go slow), than I am the metal sire harness interfering with the installation of the storage bin, so I appreciate your insights.
  6. Apr 21, 2020 at 6:32 PM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Installed ESP in my 20 no issue. If you cut the other 3 sides and lift up you'll know what to avoid, even then simple to work around. ESP made them now to fit around the sensor and cable, make sure you get the new one. If you specify your year they will know not to send the older version. Nice storage, hard to believe Toyota wastes that space.
    bulldog93 likes this.
  7. Apr 21, 2020 at 6:58 PM
    mtodd62
    Mark
    Thanks rebmo. I was originally looking at the lockable storage at Sparkspart.com. Even though the unit from ESP is $50 more expensive, I think I'll go with that. It clearly stated on in their website that the center compartment is a little more shallow to accomodate the 2020 vehicles with smart key.
    bulldog93 and TaquitoBandito like this.
  8. Jul 15, 2021 at 12:03 PM
    ToyTRD21
    ToyTRD21 New Member
    2021 Wht TRD PRO
    will the Toyota Tundra CrewMax Long Box Under Seat Storage work with 21 Trd Pro? it has a wiring harness at the middle.
  9. Jul 15, 2021 at 1:25 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Yes, the 2020's have the same wiring harness. You just have to be extra careful when cutting the foam out.
    ToyTRD21 likes this.
  10. Jul 15, 2021 at 2:20 PM
    ToyTRD21
    ToyTRD21 New Member
    2021 Wht TRD PRO
    @Bakershack thank you, will order it now before sells out again.
    Bakershack likes this.
  11. Jul 20, 2021 at 8:15 AM
    DerfM
    DerfM Knows nothing about trucks
    South Dakota
    2021 TRD Pro MBM
    Jealous of my buddy's Sierra under seat storage, scared to cut the carpet and foam out of my Tundy.
    :shrug;
  12. Jul 20, 2021 at 11:37 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I understand. Just look at the "after" pics of the installed storage units. It helps to see what you're going to end up with.
  13. Aug 5, 2021 at 9:28 PM
    Wgusler
    Wgusler New Member
    2021 TRD Pro
  14. Aug 6, 2021 at 2:13 AM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    But, it is a big deal, you shouldn't have to do it at all!!!
  15. Aug 6, 2021 at 5:36 AM
    trails-end
    trails-end New Member
    NWGA
    2021 Tundra SR5 4x4 crewmax trail white
    TRD antisway bars front and rear.
    No shit. I have to add my own underseat storage in a space that is wasted from the factory. I have to add a transmission cooler. The trail boxes that try to mimic what Dodge has been doing for years leak like a sieve. The rear suspension needs help if you want to do truck things. What am I missing?
  16. Aug 6, 2021 at 6:42 AM
    Wgusler
    Wgusler New Member
    2021 TRD Pro
    Yes, the Tundras are a flawed product.....^^^^^^^^ seems you guys should have bought a Dodge. Geez, the guy asked a simple question and now it's a " What do you hate about a Tundra thread". Trade in values are really high right now......just sayin.
  17. Aug 6, 2021 at 7:35 AM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    I would love the long box but not paying 700 for that lol.
    I’m probably gonna copy the member here who cut out the holes and put cake pans in. Total cost $15
