Sidewall load ratings
Discussion in 'Wheels & Tires' started by doggiecareman, Aug 5, 2021.
  1. Aug 5, 2021 at 5:59 PM
    doggiecareman
    doggiecareman [OP] YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    Curious if there are other AT tires with E load rating of 3400ish lbs per tire like the BF Goodrich KO2's? The sidewalls are so thick you can run them practically flat. Are there others similar?
  2. Aug 5, 2021 at 6:46 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    bias ply
