Key fobs
Discussion in '1st Gen Tundras (2000-2006)' started by Larry6464, Aug 5, 2021.
  1. Aug 5, 2021 at 10:29 AM
    Larry6464
    Larry6464 [OP] New Member
    Larry
    North Carolina
    2008 toyota tundra crew cab
    Here is a question for anyone that can answer it. I have a 2002 Toyota tundra SR 5 crew cab. In that year was the key fobs not standard for those years. I have two key fobs . One is messed up. So I bought the ones in the picture below. I took them to a locksmith and he couldn't get them to program to truck. He said he thinks the key fobs are after market ad on. And I need to go to dealer and check with them So any thoughts to this would be appreciated. Thanks.
  2. Aug 5, 2021 at 10:30 AM
    jskeyes2
    jskeyes2 New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    ADS Shocks 35” Yokahama M/T
    All I will say is that for my truck, I had none. Tried two locksmiths and neither could do with their remotes. Ended up giving VIN to the dealer, they ordered, I programed, and they work great. Sometimes you have to go to the dealer...
  3. Aug 5, 2021 at 10:34 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  4. Aug 5, 2021 at 10:54 AM
    Larry6464
    Larry
    North Carolina
    Ok thanks For info
    BubbaW likes this.
  5. Aug 5, 2021 at 2:14 PM
    TBinky
    TBinky Wassup weirdos
    2000 black tundra
    I got the cheapo China universal kit from Amazon and wired it and it works great
  6. Aug 5, 2021 at 4:55 PM
    Just do the programming yourself. For programming the factory security system and other functions like the immobilizer stuff, check reply # 20 over here: https://www.tundras.com/threads/need-help-disabling-automatic-door-locks.33158/#post-1931311
    The PDF attached to the post talks through the security system and whatnot. It's a pain in the ass to get it into programming mode. The first time it took me like 10 tries. Even now, after doing it a number of times to adjust things like auto-locking the door after start/gear, add new remote fobs, etc. it STILL takes me at least 2-3 tries to get it in programming mode per the instructions.
    Seriously. F going to the dealer. If that company says they'll work, try programming it using the factory manual attached to the reply I just linked to.
  7. Aug 5, 2021 at 4:56 PM
    Oh wait - I just realized, the ones you bought are listed as for the Sequoia and have the rear rolldown button. May not be the same remote, but Toyota reused a lot of transmitter parts over the year so TRY IT!
