Tail pipe loose
Discussion in '2.5 Gen Tundras (2014-2021)' started by UTAHRTK, Aug 4, 2021.
  1. Aug 4, 2021 at 5:02 PM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I have an aftermarket exhaust and the pipe is loose and rotates easily- I believe this is a result of wear & tear. Wondering if I should replace gasket and clamp? Suggestions.Thanks.
  2. Aug 4, 2021 at 5:24 PM
    AZTundra
    Paul
    Phoenix, AZ
    Sounds like it's maybe an issue with the rubber hangar? Or are you referring to a clamp on exhaust tip that is loose?
  3. Aug 4, 2021 at 6:24 PM
    MSU Tundra
    MSU Tundra Numerous rodeos experienced
    Mississippi
    2017 Tundra and 2013 LC200
    AZTundra likes this.
  4. Aug 5, 2021 at 5:47 AM
    UTAHRTK
    SOCAL
    yes I believe it is the clamp and the gasket. Pretty sure it is not a banana.
    MSU Tundra likes this.
